Old 02-17-2013, 12:20 AM   #12886
Ausfossil
Oddometer: 133
Originally Posted by DRjoe View Post
I'm not very familiar with the TM I'm more of an fcr kind a guy but yea just T off any of the hoses as long as they are a vent for the float bowl.
Some people just put one of the vents up and this will help with water crossings but can cause the bike to flood when laid over at certain angles.
Sweet, thanks mate, 1 T and a bit of rerouting coming up.
Iain
Ausfossil is offline   Reply With Quote
Old 02-17-2013, 06:16 PM   #12887
woodsy4
woodsy4's Avatar
Oddometer: 17
Originally Posted by Ausfossil View Post
Just put a TM40 on the DR and wondering about these vent lines. Do you have to put a T in all three vent line and reroute all up to the airbox or just in one of them. If just one is it anyone in particular.
Cheers
Iain
I put a T in all 3, doesn't cost much, stuck in a creek once was enough for me, wish Procycle had included that as a hint somewhere on their web or instructions. Love mine, runs great, but first creek crossing cough - stop, feet down in water over the top of the boots, pushed it out and eventually got it restarted.
DR650 '07, TM40, Staintune, Air Box Mod, IMS Tank, Eibach springs, DDCs, Cogent Shock, Corbin Seat, Procycle lowered pegs.
woodsy4 is offline   Reply With Quote
Old 02-17-2013, 09:23 PM   #12888
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,256
is this T-joint a good idea for the stock carb as well? i found it annoying that the DR often stalled for no reason in deeper creek crossings and this sounds like it could have been the cause. just wondering as i'll probably be buying another of these mean mothers soon.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 02-17-2013, 11:21 PM   #12889
Ausfossil
Oddometer: 133
I had a few T's lying around so did all three. I had done it on the stock carb which only had one breather. Never had any issues with water crossings so I guess it did something.
Iain
Old 02-18-2013, 12:29 AM   #12890
BergDonk
BergDonk's Avatar
Oddometer: 3,350
Yep
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 02-18-2013, 10:36 PM   #12891
TRTN
Oddometer: 28
Any recommendations for a road worthy check plus a rear tyre + install in Melbourne?
Would like a Mitas E07, Shinko 705 or similar. Cheaper is better at the moment ;)
TRTN is offline   Reply With Quote
Old 02-19-2013, 12:27 AM   #12892
live4daride
Oddometer: 129
I had the seat off yesterday doing the valve clearances and noticed some unused electrical plugs up near the airbox. Anyone here know the purpose of these?
On a separate note, an example of DR awesomeness:
At work we have a new guy just started, a toolmaker by trade, who amongst other things, has raced proddies and owned a turbo Hayabusa. So i imagine he doesnt take it to easy when on a DR!
This said person had a 96 DR650 and clocked up 250,000 kms without any breakdowns!! Whist working on it, unknowingly kinked the engine breather which caused the engine to blow smoke.
Thinking naturally by now a rebuild is due, pulled the motor apart and found everything measured in spec, including the bore and cylinder. He changed the oil every 2500 kms.
live4daride screwed with this post 02-19-2013 at 12:42 AM
live4daride is offline   Reply With Quote
Old 02-20-2013, 02:51 AM   #12893
0405canvet
Oddometer: 360
B1
Just have a hard time picturing B1 on a little DR. It's a big step up from the H thou!!
0405canvet is offline   Reply With Quote
Old 02-20-2013, 03:20 AM   #12894
rutsthematter
rutsthematter's Avatar
Oddometer: 149
Originally Posted by TRTN View Post
rear tyre + install
DIY I'ts good practice for you if you plan riding all the good spots.
rutsthematter is offline   Reply With Quote
Old 02-20-2013, 03:51 AM   #12895
KIZ
Marty
KIZ's Avatar
Oddometer: 511
+1, I carry spare tubes and have needed them a few times.
KIZ is offline   Reply With Quote
Old 02-24-2013, 04:33 AM   #12896
DRjoe
DRjoe's Avatar
Oddometer: 5,055
Hi dr gurus
I'm designing something for the dr and I need to know how big the side stand switch is.
My dr650 does not have it anymore.
Has anyone got a photo of the side stand switch fitted to the bike and could someone measure how far the switch sticks out, I want to make use of the chain roller mount hole next to the side stand switch but I think the switch might stick out too far and get in the way.
Cheers
DRjoe is online now   Reply With Quote
Old 02-24-2013, 06:06 PM   #12897
B1
B1's Avatar
Oddometer: 3,256
yes it does take a bit work... high bend bars mounted and inch forward and up, pegs moved down and to the rear, seat padded higher. had to sell the first one as i just wasn't ready for the knob ripping power. but i'm hoping after a year on the berg i might be halfway ready for what is rightly known as the world's best bike.
Old 02-24-2013, 06:38 PM   #12898
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
Cheers
UncleGra, good pics.
Reading this a bit different: I laid a straight edge across the threaded chain roller boss and the outer edge of the side stand switch (front to rear). The switch and boss are real close to the same 'depth'; the straight edge almost ran parallel to the bike's center line, like the chain. It's angled out just a tiny bit toward the rear.
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-24-2013, 08:43 PM   #12899
UncleGra
CRASHING BORE
Oddometer: 2,887
The chain roller hole is in 5mm from flush with the frame alignment....and I flunked General Maths English Conprehension Science ..but waqsnt bad on Goegraphy and French ...and spelling....
.. I fixt it...my way....gjr
OK OK....it might be 98% fat free...but I wana know how much fat's in the other 2%....gjr
UncleGra screwed with this post 02-25-2013 at 12:28 AM
UncleGra is offline   Reply With Quote
Old 02-25-2013, 01:18 AM   #12900
DRjoe
DRjoe's Avatar
Oddometer: 5,055
Thanks uncle gra and ER70-s (how do you pronounce that?)
That's the info I was after.
I need to take a supporting strut from the chain roller bolt hole up to about where the passenger peg is now.
Looks like i'll need to put a 5mm spacer in just to make sure it clears that switch.
Thanks again fellas
Times are GMT -7.   It's 08:21 AM.
