Old 02-25-2013, 01:36 AM   #12901
ER70S-2
ER70S-2's Avatar
Oddometer: 6,267
Originally Posted by DRjoe View Post
Thanks uncle gra and ER70-s (how do you pronounce that?)
That's the info I was after.
I need to take a supporting strut from the chain roller bolt hole up to about where the passenger peg is now.
Looks like i'll need to put a 5mm spacer in just to make sure it clears that switch.
Thanks again fellas
ER70S-2 is the welding wire used for MIG and TIG, and it's a pain to type (I never thought of that when I was picking a user name). A weld shop would know it as eee-arr-seventy S-2. ER is ok by me.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 03-01-2013, 07:26 PM   #12902
Born-to-ride
GSXR!!!
Born-to-ride's Avatar
Oddometer: 100
Installed the IMS today an also added an inline filter in fuel feed to the carbie from the tank. Only concern I have is there is now a air bubble in the line and I can not seem to ride or flow it out. Is this normal for the inline filter???
Born-to-ride is offline   Reply With Quote
Old 03-02-2013, 02:41 AM   #12903
backtodirt
backtodirt's Avatar
Oddometer: 133
yep.... well I have had one there for 8000 k's and still going strong!
P.s looking good!
Jeremy
'08 DR650 (bushpig), '04 Zx10r (green meanie)
You don’t stop riding because you’re getting old, but you get old when you stop riding.
backtodirt is offline   Reply With Quote
Old 03-02-2013, 04:25 AM   #12904
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 652
How long does your DR battery last?, I'm coming up to two years now from when I bought the bike new, I'd like to replace it before it fails instead of afterwards when I'm out in the middle of nowhere, I'm thinking it won't be too much longer. .
DR Ozzy is offline   Reply With Quote
Old 03-02-2013, 04:48 AM   #12905
Ausfossil
Oddometer: 143
My 08 has still got the standard battery and doesn't seem to have any troubles turning over. That's probably jinxed it now.
Iain
Ausfossil is offline   Reply With Quote
Old 03-02-2013, 03:08 PM   #12906
BergDonk
BergDonk's Avatar
Oddometer: 3,467
My 09 DR is still original. Sits on a CTek charger/tender when in the shed which I think helps. 14 years out of the original battery in my zx9R must be close to a record I reckon. 11 years for my Courier, just replaced my 07 650 Berg at 6 yrs, missus KLX is still original at 6 years too. All on tenders other than the Courier. Also tractor, buggy, mower on solar tenders for 7-10 year lives.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-02-2013, 03:13 PM   #12907
Aussie Trev
aka DRTrev
Aussie Trev's Avatar
Oddometer: 5,610
My DR was on a tender for four years no problem. Little used 08 DRZ and an oft used 10 Tenere are also on tender and both on original batteries.
2011 Triumph Tiger 800XC
1982 PE175Z
Full member......Quorn Schnitzel Club
"Just having a crack"
Aussie Trev is offline   Reply With Quote
Old 03-02-2013, 03:13 PM   #12908
gavo
Slacker
gavo's Avatar
Oddometer: 1,817
My 07 still had the original battery until August last year and I only replaced it because I was doing a Simpson crossing, it still worked fine. No battery tender, nothing just ridden 3or4 times a month
gavo is offline   Reply With Quote
Old 03-02-2013, 03:17 PM   #12909
UncleGra
CRASHING BORE
Oddometer: 2,984
I have a DR too..what is this " tender " of which you speak...oh mighty gurus..
.. I fixt it...my way....gjr
Done good...Played strong... J.G.
UncleGra is offline   Reply With Quote
Old 03-02-2013, 03:43 PM   #12910
gavo
Slacker
gavo's Avatar
Oddometer: 1,817
Never used one but from what I've heard, like a battery charger with a brain keeps battery charged but doesn't overcharge. I'm sure someone will correct this if wrong
Old 03-02-2013, 03:44 PM   #12911
BergDonk
BergDonk's Avatar
Oddometer: 3,467
http://www.google.com.au/#hl=en&suge...w=1456&bih=815
http://www.google.com.au/#hl=en&scli...w=1456&bih=815
Aldi even does them from time to time. A mate who's into things electronic pulled one apart and couldn't tell the difference inside from a Ctek that sells for $125. The Aldi one in $25 when available.
Repco routinely does good deals on the CTek which is when I got those that i have.
The Solar ones I got most recently were from eBay, not this one, but similar:
http://www.ebay.com.au/itm/12V-Solar...item1e720f4118
Yep
Old 03-02-2013, 03:56 PM   #12912
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,733
Can also refer to the state of your bum after a 100kms on a standard seat
fayeslane
Faster than a speeding pullet
2002 Yamaha TDM900
various BMW airheads
fayeslane is offline   Reply With Quote
Old 03-02-2013, 04:12 PM   #12913
UncleGra
CRASHING BORE
Oddometer: 2,984
Today I have a seriously stuffed lower back..no doubt due to the Date Roll..
a battery tender is imminent...I just watched the Ctek vid...clever isnt it...
thanks chaps..
Old 03-02-2013, 05:02 PM   #12914
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 652
Better leave the battery for another year then I guess
Old 03-03-2013, 03:55 PM   #12915
Thumper Dan
Oddometer: 325
[QUOTE=cognac;18874694]I fitted the Procycle TM40 Kit two weeks ago along with a Jason Barrett slip on. I removed the Airbox snorkel and ground down the weld in the header pipe. Runs great with increased low down power and great throttle response. Only problem I had was the outlet manifold adapter fitted by procycle to fit standard intake boot was loose and sucking in air. Quick refit with araldite and problem solved. Follow the instructions from procycle and the fitting is pretty straight forward.
Cheers
Steve[/QUOTE
Do you get better performance out of a Jason Barrett slip on then the standard exhaust, or is it only making for better sound improvements. I was thinking of getting a staintune but are expensive and maybe this is an alternative.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Times are GMT -7.   It's 04:40 PM.
