Old 03-19-2013, 05:25 PM   #12946
UncleGra
CRASHING BORE
Oddometer: 2,985
Originally Posted by NordieBoy View Post
Looks like you were sent the 2-stroke version.
They sell 2 and 4 stroke ones.
so do I multiply the reading by half..or divide the reading by half..
.. I fixt it...my way....gjr
Done good...Played strong... J.G.
UncleGra is offline   Reply With Quote
Old 03-19-2013, 10:12 PM   #12947
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Originally Posted by BergDonk View Post
But don't we have a waste spark on the DR650 like almost all bikes? In which case, 2 and 4 stroke are the same.
Well, yes. Sort of. Ish.
But if that were the case then they wouldn't sell a 2 stroke and 4 stroke version.
NordieBoy is offline   Reply With Quote
Old 03-19-2013, 10:13 PM   #12948
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Divide it by 0.5
Old 03-19-2013, 10:29 PM   #12949
DRjoe
DRjoe's Avatar
Oddometer: 5,096
Bikes that run there trigger off the cam need a four stroke one and bikes that run the trigger off the flywheel use a two stroke one.
Old 03-19-2013, 10:35 PM   #12950
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
And a tach that's displaying half actual revs on a wasted spark DR650 is from a ???
Old 03-19-2013, 10:43 PM   #12951
DRjoe
DRjoe's Avatar
Oddometer: 5,096
I supose its one of the great mysteries of the world.
Maybe Black magic?
Old 03-19-2013, 11:06 PM   #12952
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Maybe Black magic?
The Kiwi Americas Cup boat?
Old 03-20-2013, 02:32 AM   #12953
DRjoe
DRjoe's Avatar
Oddometer: 5,096
It's possible
Old 03-20-2013, 07:09 PM   #12954
Benz-in-Oz
Benz-in-Oz's Avatar
Oddometer: 187
Wobbly Head
The speedo. on my DR has been quite wobbly for some time, it dances around and shakes as you go along, I reckon there's about 8-10mm movement in it. It's annoying and I figured it probably doesn't do the instrument any favours being shaken like that. I was going past the Suzuki dealer in Queanbeyan yesterday so I picked up some new mounting grommets thinking that was obviously the problem.
Fitted the new grommets this morning, thinking this will fix it, it was heaps better but there was still a little slop, seems the groove around the middle of the grommet is slightly wider than the thickness of the mounting bracket and when the mounting nuts bottom out on the thread there's no pressure on the grommets, after a few thousand k's. I think it would have been back to the way it was. i disassembled it again, I got three washers 6mm ID about 1.5mm thick and placed them on the three spigots under the speedo put all back together, tightened the nuts and "hey presto" no more slop. There's just enough pre load to stop the grommets moving in their holes but not enough to make the mounting "firm" and prevent vibration damping. A small thing I know, but a virtually free fix to a small annoyance.
Benz
Benz-in-Oz is offline   Reply With Quote
Old 03-20-2013, 07:52 PM   #12955
ER70S-2
ER70S-2's Avatar
Oddometer: 6,291
Benz:
Nice attention to detail, seems to be a lost gene anymore.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-24-2013, 12:24 AM   #12956
Gee1
Oddometer: 169
5th Gear noise
I've just taken my DR out for a spin after loading it up for next weekend and in fifth gear it makes a hell of a noise. I didnt notice it before it was loaded but I am not sure if I hit fifth on my road when it had no load. The noise is only when power is applied, there is no noise evident on overrun but the slightest bit of throttle and it makes the noise. At any speed at any revs, just in fifth.
Has anyone had a similar problem?
Gee1 is offline   Reply With Quote
Old 03-24-2013, 12:37 AM   #12957
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 982
Can you describe the noise?
Gear whine?
A rattle?
Three hamsters having an orgy instead of running in the wheel to provide power?
http://lupineandboogowandering.blogspot.com
Dropped from full Team F5 sponsorship due to family commitments.
Stupid family.
Lupine128 is offline   Reply With Quote
Old 03-24-2013, 12:43 AM   #12958
Gee1
Oddometer: 169
Gear whine?
A rattle?
Have you ever heard that noise the DR starter makes? It's a fairly common noise caused by a dry bushing. Its like that only quite a bit louder and you can kinda feel it right through the bike. Dunno bout the hamters though
Old 03-24-2013, 01:54 AM   #12959
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 982
Unpack it and ride it the exact same.
See if its the same.
If it only happens loaded up, that will help narrow it down.
Stupid family.
Old 03-24-2013, 02:33 AM   #12960
Gee1
Oddometer: 169
Yeah, I will be unpackin the thing and I'll try it again another day. It's pissin rain here now and I'm enjoying whisky, so we'll see what develops
Times are GMT -7.   It's 08:17 AM.
