Old 04-01-2013, 07:31 PM   #13006
backtodirt
backtodirt's Avatar
Oddometer: 133
Originally Posted by slapper View Post
yup - if that float valve is leaking .. then it's most likely doing it whilst the bike is running as well as when it's sitting still. If it's leaking faster than the engine's using fuel (eg. at idle or v low revs) then simply switching the tap off when not running is not stopping the fuel from leaking into the oil.
Fuel in the oil is bad for all sorts of reasons (reduced lubrication, cooling etc even a low risk of an explosion is present) ... fuel leaking back through your air filter is also bad for all sorts of reasons (which might happen if you stop on an incline etc) ...
Plus .. it might get worse and you could finish up stranded :(
The risk of something bad happening is probably low if you turn the tap off every time the bike's not running. Any leaks whilst the engine's running will probably just get burned off as it dribbles into the cylinder .. in my opinion, it's not worth the risk though.
Still it's probably too late to mention all this as you've probably already gone!
cheers (hope it went okay),
Slap
haha, nah I took heed of issues and decided to postpone it, carby is apart, and am doing research as we speak to work out what to replace if needed, thanks for the help, I will yell if I run into any difficulty. Thanks again!
Jeremy
'08 DR650 (bushpig), '04 Zx10r (green meanie)
You don’t stop riding because you’re getting old, but you get old when you stop riding.
backtodirt is offline   Reply With Quote
Old 04-02-2013, 12:18 PM   #13007
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,730
Back to basics. Though prob too late by now.
Is it the original tank with vacuum operated fuel tap or after market tank & taps?
How long had the bike been standing when you changed the oil?
Could you replicate the problem?
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-04-2013, 04:21 AM   #13008
fatgut
Oddometer: 639
18 inch rear
I am currently changing the rear wheel to 18inch, just wondering what width tires anyone has been running with the 18 inch rear wheels . I was looking at a 18\130- EO9, I have been running a 17\130- E09 and it was good tire.
Kev.
fatgut is offline   Reply With Quote
Old 04-04-2013, 04:33 AM   #13009
KIZ
Marty
KIZ's Avatar
Oddometer: 532
Kev.
I've been running 130/18 E09 and E07,s OK. I dont think a 140 would fit but might just get in. Marty.
KIZ is offline   Reply With Quote
Old 04-04-2013, 03:17 PM   #13010
BergDonk
BergDonk's Avatar
Oddometer: 3,685
Kev.
Depends on the rim width. Typical enduro 18s are 2.15. I think the stock 17 is 2.5, and the 18 I fitted is also 2.5". You can squeeze a 140 onto a 2.5 but it wraps the tread and sidewall around and there is no advantage, and it wobbles about. 120-130 is fine, but for a more definitive tyre specific answer, ask the tyre manufacturer or local agent.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 04-04-2013, 04:51 PM   #13011
fatgut
Oddometer: 639
Hi BergDonk.
The rear rim is a 2.15 to suit the Tubliss system ,looking at manufacture information a tyre width 110/120 is norm some say to 130 max.
Kev.
Old 04-04-2013, 06:42 PM   #13012
BergDonk
BergDonk's Avatar
Oddometer: 3,685
Hi BergDonk.
Kev.
As ever, the relationship between quoted tyre sizes and actual measurements are not always easy to follow. Some 130s might be OK, but normally I'd say a 120 is max for a 2.15 rim. Mind you, I've seen some huge 120s over the years too. Your retailer might have a clue, or might not. The importers are always up for a chat in my experience and normally know their product fairly well, so if in doubt, ask them.
This thread happening on DRR right now might be of interest too:
http://drriders.com/post83533.html#p83533
Old 04-07-2013, 06:38 PM   #13013
slapper
Oddometer: 95
525+520 vibration ...
well ... it's still there but not enough that I'd have especially noticed it.
well .. I think I've finally worked out what's causing it.
When I put the factory rear sprocket back on, I could still feel the vibrations, but they weren't bad enough that I would have noticed it if I wasn't looking for it (in stark contrast to the 44 which really felt like something was wrong). As usually happens when things get slowly worse, I didn't notice it happening but, Friday on the way home I thought "that vibration's actually pretty bad, I might as well put the 44 back on". Which I did yesterday.
When I went to remove the sprocket, I discovered that 3 of the bolts holding it to the carrier were loose enough to turn by hand. Now that I've stuck the 44 back on with freshly tightened bolts, it feels "not bad" (the vibes are there, but I'm pretty sure I'm just noticing them because I'm being extra sensitive) - so I reckon that's it. Nothing to do with 525+520 mix, the sprocket bolts are just coming loose over time.
Thread lock next weekend I reckon :)
cheers all.
slapper is offline   Reply With Quote
Old 04-07-2013, 07:32 PM   #13014
robmoto
robmoto's Avatar
Oddometer: 3,858
Blue locktite
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 04-07-2013, 08:45 PM   #13015
TRTN
Oddometer: 28
Think the factory applied threadlocker is a red compound. Needs heat and a fair bit of force to remove.
Loctite 263 would be similar. I reckon 243 (blue) would be good enough. Not a qualified mechanic though.
TRTN is offline   Reply With Quote
Old 04-08-2013, 01:25 AM   #13016
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 991
Quick question before I suck a screw into my engine and lunch it.
Left work and the neutral light worked properly.
Pull up in traffic 25k later and its flickering.
Pull up 5 k later and it's gone.
I'm at a shopping center so I've checked the bulbs and they are fine.
Chances it's the NSU and I'm about to suck a small 5c piece of metal into my motor and destroy it?
Do I ride 5 k home?
Help?
http://lupineandboogowandering.blogspot.com
Dropped from full Team F5 sponsorship due to family commitments.
Stupid family.
Lupine128 is offline   Reply With Quote
Old 04-08-2013, 01:46 AM   #13017
BergDonk
BergDonk's Avatar
Oddometer: 3,685
Originally Posted by Lupine128 View Post
Do I ride 5 k home?
Help?
I wouldn't
Old 04-08-2013, 02:01 AM   #13018
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 334
Talking
Do I ride 5 k home?
Help?
Dear Mr Lupine,
Unfortunately it sounds like it is knackered. PM me ASAP and I will whip around in the ute, pick you and the poor old DR up, drop you safely home and sling you a $1,000 for what's left of the broken down old beast!
grrant1058 is offline   Reply With Quote
Old 04-08-2013, 05:23 AM   #13019
Boo82
Boo82's Avatar
Oddometer: 385
The muppet rode it home, it didn't die, but he nearly did when I found out what he had risked. And now he expects me to let him ride my bike instead . At least he has a sense of humour still. He can ride the DT.......
He mummbled something about the light coming back on and it is probably a wire or something and is going to open it up and look at it.
Time decides who you meet in life, your heart decides who you want in your life, but your behaviors decide who will stay in your life.
Boo82 is offline   Reply With Quote
Old 04-08-2013, 11:02 AM   #13020
ER70S-2
ER70S-2's Avatar
Oddometer: 6,671
Check this plug, it's by the upper shock bolt, just behind the tank.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 01:24 AM.
