Old 04-28-2013, 01:20 AM   #13126
sidetrack one
Boss STAG
sidetrack one's Avatar
Oddometer: 5,249
Mucho easier with the clutch off, IMO, but you need to be tooled up a bit!
I reckon that top screw would be fairly fustrating, but I dont know, I took the clutch off!
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 04-28-2013, 01:42 AM   #13127
BergDonk
BergDonk's Avatar
Oddometer: 3,350
My preference is to take the clutch off, it just opens up the access and it is a simple enough job, but like Dave says, needs a few tools, and an accurate torque wrench. 10 nm for the clutch springs and 50 nm for the 27 mm centre nut. The lock washer can be recycled with care, so no extra parts required. Doing it with the clutch on is tight and fiddly and will entail adapting a screwdriver of some sort. If you take one screw out at a time then the plunger and spring in the switch can't go walkabout. If you use Loctite, flushing all the oil out of the threads is not necessary, but nevertheless nice. I use aerosol brake cleaner. most evaporates off, but after its all buttoned up its due for an oil change anyway so any contamination is flushed out then. Stick it in fifth gear and you can hold the rear wheel to get 50 nm no worries.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-28-2013, 07:34 AM   #13128
KIZ
Marty
KIZ's Avatar
Oddometer: 511
Nsu
Thanks for the replies guys , looks like another job to do soon, always looking to keep the DR in a good and reliable condition. Might be ready for the OCR next year. People keep worrying me with posts of explodeing 3rd gears. Keep the rubber side down Marty
KIZ is offline   Reply With Quote
Old 04-28-2013, 11:32 AM   #13129
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
Not my photo.
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-29-2013, 03:13 AM   #13130
rutsthematter
rutsthematter's Avatar
Oddometer: 149
Here is a pic of the genuine Suzuki CS retainer PN 24751-32E00. They should start installing them on new bikes.
rutsthematter is offline   Reply With Quote
Old 04-29-2013, 04:10 AM   #13131
Croney
Croney's Avatar
Oddometer: 261
Rotopax with Wolfman panniers
Has anyone strapped a set of soft panniers over some rotopax ?
Ive tried mine and the locking devise sticks out and into the pannier bag….is this normal.?
Can anyone share a photo for me please ?
Cheers..
Its all a matter of grip on the tyres.
SPOT - http://share.findmespot.com/shared/f...lCtPyqSCbXkmID
Croney is offline   Reply With Quote
Old 04-29-2013, 04:30 AM   #13132
td42dan
td42dan's Avatar
Oddometer: 27
Want more comfort!!!!
so whats the best seat for comfort ?????
also wheres the best place / price to get one from???
ive a standard DR seat....
also after a seat thats comfy for a pillion....
td42dan is offline   Reply With Quote
Old 04-29-2013, 04:41 AM   #13133
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,731
http://www.seatconcepts.com/products...358&id=7268100
http://www.seatconcepts.com/products...58&id=13933398
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-30-2013, 05:12 PM   #13134
Maso
Maso's Avatar
Oddometer: 35
Rotopak solution
Cheers..
I have cut some thick dense foam spacer plates to build the bag out from the locks.
A slot cut in the middle for the lock to sit into.
Makes it a bit wider but gives a flat surface for the bag to sit on
I will take some photos tonight and post them up.
If it's not broken.
Fix it until it is.
Past Ride DRZ400E Now DR650
Maso is offline   Reply With Quote
Old 04-30-2013, 07:09 PM   #13135
0405canvet
Oddometer: 360
400 to 650
Hey maso, could you report on the good and bad going from your 400 to the 650 please?? Just thinking about doing the opposite.
0405canvet is offline   Reply With Quote
Old 04-30-2013, 09:09 PM   #13136
Maso
Maso's Avatar
Oddometer: 35
The main reasons I went to the 650 is the 400 was struggling in my opinion once it was loaded up with gear and fuel especially on the tar at 100 KPH temprature would climb noticably.
The 650 handles the long tar sections a lot more comfortably.
Having had the suspension done on the 650 compared to the standard 400 suspension for the riding I do, you do not have to work as hard on the 650 so don't end up as tired at the end of the day.
I am not interested in single track anymore so the 650 was a better suited bike for my riding.
If it's not broken.
Fix it until it is.
Old 05-01-2013, 06:34 AM   #13137
Croney
Croney's Avatar
Oddometer: 261
Thumb Rotopaks
Cheers Maso thanks.
Pretty much what I had figured I needed to do....would be good to see it though.
Old 05-01-2013, 04:23 PM   #13138
Maso
Maso's Avatar
Oddometer: 35
Crony
I do not have them on the bike at the moment but here is what they look like.
They are a sheet of foam from Clark Rubber about 10 or 12mm thick glued togeather with contact cement then cut to shape.They did not have 20mm thick when I was there or I would have gotten that.
If it's not broken.
Fix it until it is.
Old 05-01-2013, 05:53 PM   #13139
DR Ozzy
Suzuki scum
DR Ozzy's Avatar
Oddometer: 647
Where did you get your rotopax's from? ... US?
DR Ozzy is offline   Reply With Quote
Old 05-01-2013, 08:09 PM   #13140
Maso
Maso's Avatar
Oddometer: 35
A group of us got togeather and did a bulk buy of all sorts of DR stuff from Procycle in US but Adventure Moto do have them.
If it's not broken.
Fix it until it is.
Times are GMT -7.   It's 05:28 AM.
