Old 08-09-2013, 06:07 AM   #13396
CCCC
Oddometer: 300
Originally Posted by french horn View Post
Great idea, I've been think'n of something along these lines BUT .... I'm concerned about going too wide ... ADR's limit width of a m/cycle to 1meter disregarding mirrors..... so I haven't looked around much as yet ... if your setup is less than 1m packed, please post here.
cheers
Just measured in the dark.....93cm. They are stuffed full as we are heading off on a trip tomorrow
CCCC is online now   Reply With Quote
Old 08-10-2013, 02:52 AM   #13397
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 999
I'm about to graft a DRz400 front end onto my DR.
I'm running a safari tank and I weigh around 100kg.
I'm wondering if anyone else has done this with a similar setup.
Mostly what I'm looking for is the approximate spring rate I should be looking at. I'll redo the stack myself but I'd like a starting point for the spring so I don't end up with half a dozen different ones.
Anyone?
http://lupineandboogowandering.blogspot.com
Dropped from full Team F5 sponsorship due to family commitments.
Stupid family.
Lupine128 is offline   Reply With Quote
Old 08-10-2013, 02:57 AM   #13398
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,428
Originally Posted by Lupine128 View Post
\Mostly what I'm looking for is the approximate spring rate I should be looking at. I'll redo the stack myself but I'd like a starting point for the spring so I don't end up with half a dozen different ones.
Anyone?
maybe around 0.5 as a rough starting point. i'm 93kg without riding gear and that's worked very nicely. just the standard tank though, could probably beef them up a tad if using a massive tank.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 08-10-2013, 05:02 AM   #13399
gavo
Slacker
gavo's Avatar
Oddometer: 1,856
I agree with B1 maybe even a wee bit heavier
gavo is offline   Reply With Quote
Old 08-10-2013, 06:40 AM   #13400
DRjoe
DRjoe's Avatar
Oddometer: 5,204
I've got a drz front end on my dr but I can't remember what the spring weight is I do know there springs to suit the 48mm wp forks, Mpe did the job years ago.
DRjoe is online now   Reply With Quote
Old 08-10-2013, 02:10 PM   #13401
Phreaky Phil
Oddometer: 1,880
Anyone?
I've got 0.48s in mine, if I remember right 0.43 is stock. I find the 0.48 fine, a good compromise. Don't want to be to stiff as the fuel load lightens.
Phreaky Phil is offline   Reply With Quote
Old 08-10-2013, 02:27 PM   #13402
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,244
Anyone?
Pick me
I was about 87kg when I had the DRZ forks on mine. I had .52s in them. Safari tank and the works.
MPE allowed me to try .49s and .52s
So I reckon the .52 would be a good starting point for you and if they're no good, I'll take them off your hands
He has a vairwee good fwiend in Wome you know
Big Willy is online now   Reply With Quote
Old 08-10-2013, 02:28 PM   #13403
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,244
Well that's not a lot of help is it?
Old 08-10-2013, 02:33 PM   #13404
B1
B1's Avatar
Oddometer: 3,428
correct me if i'm wrong, but i think the stock springs are only 0.4. then they are also dual rate so the first bit of the spring is a very light 0.38 or thereabouts. part of the problem with the stock spring is that the softer rate applies for quite a bit of the spring, hence the problem with too much static sag when stock.
Old 08-12-2013, 06:59 PM   #13405
CaptainFur
CaptainFur's Avatar
Oddometer: 24
Swap Fork/Shock Springs
Hi all,
My DR has Technik 0.6 and 9.0 springs on it and is way over sprung for me. Has anyone with an under sprung bike (not standard springs - I also already have those) want to do a swap?
2005 DR650
1974 DT100A
1969 Ural M63
CaptainFur is offline   Reply With Quote
Old 08-12-2013, 10:44 PM   #13406
B1
B1's Avatar
Oddometer: 3,428
Originally Posted by CaptainFur View Post
Hi all,
you could always drop one stock fork spring in one side to bring yourself to an effective rate of 0.5. a suspension shop gave me 0.6 springs and they barely moved until jumping the DR hard. a mate of mine used to work on suspension for racers for years, he said to try substituting the stock spring on one side.
i was very dubious, thinking for sure it would stress the axle and/or triple clamps. spoke to another suspension shop and they said sure, go for it. anyway, went ahead and it's perfect. done some jumps and fairly gnarly high speed riding and the forks haven't cracked or fallen off (yet).
Old 08-12-2013, 11:22 PM   #13407
wheelruts
aka speedbump
wheelruts's Avatar
Oddometer: 100
I knew it !
Every time you went hurtling past me, showering me in dust and gravel.
I always said to myself "there's something wrong with his setup".
wheelruts is offline   Reply With Quote
Old 08-13-2013, 01:47 AM   #13408
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
cheers
Hmm a Safari Tank actually looks quite cool on a white dr.
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 08-13-2013, 04:00 AM   #13409
NZSHAKER
Oddometer: 155
Mine has
Front has 0.52 springs and Rear has 9.0 spring which was set up by the PO and he was saying set up for 110kg rider.
I do need a bit hard spring rates as I may or may not ok am be larger than that
I have 30 ltr tank as well....poor poor DR
NZSHAKER is offline   Reply With Quote
Old 08-13-2013, 11:03 AM   #13410
french horn
Just Add venture
Oddometer: 475
Thanks for that CCCC, reckon I'll be looking for those bags.
french horn is offline   Reply With Quote
Times are GMT -7.   It's 05:05 PM.
