Old 09-10-2013, 07:00 AM   #13456
KIZ
Marty
KIZ's Avatar
Oddometer: 514
[QUOTE=CaptainFur;22291518]Hi All, Heading to Tassie with some friends and after some new tyres. Will have touring bikes with us so will be mainly on tar and good dirt/gravel. So after something with good dry/wet grip on the tar and will handle secondary dirt roads OK.
Thinking mainly Mitas E07 or Pirelli MT90AT - how do they compare? Or possibly Shinko 705, Kenda 751? Any recommendations?[/QUOTE
They put Trailwings on standard for that type of rideing. Used them on a trip to PI and in the rain was held up by the guys on sports bikes in the twisties. I like E07's for their longevity on long dirt/bich rides up to 14k.
KIZ is offline   Reply With Quote
Old 09-10-2013, 09:01 PM   #13457
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,270
i'd agree. much as we like to bitch about the stock deathwings they should suit the riding you describe, if you still have them fitted. given how fast they wear out, they should actually grip quite well on road.
i'm a big fan of the E07 rear, i get 6000km which is triple what i'd get with the trailwing or typical D606 etc. a lot of riders pair it with the MT21 on front which is still quite good on the road but grips nicely on the dirt roads - good insurance to stop that front end washing out. just one opinion but you'll probably find its one of the most popular combinations used when there's a fair bit of bitumen involved - at least for DR650s.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 09-10-2013, 10:02 PM   #13458
CaptainFur
CaptainFur's Avatar
Oddometer: 18
Thanks for that. I've currently still got a E09 on the back (close to worn out) and a Scorpion Rally on the front (heaps of tread) from a Birdsville trip and will use the front again when required but will replace both with something more road oriented for the Tassie trip.
2005 DR650
1974 DT100A
1969 Ural M63
CaptainFur is offline   Reply With Quote
Old 09-11-2013, 01:02 AM   #13459
backtodirt
backtodirt's Avatar
Oddometer: 132
Mitas' do seem popular but have not used them myself. I have 606's front and rear and like them, my favourite for what you are talking about is a mefo explorer I keep my 4000 k mefo in the garage and swap it over when doing tar/firetrails it his probably still got 70% left but I do ride like Ewan McGregor....
Jeremy
'08 DR650 (bushpig), '04 Zx10r (green meanie)
You don’t stop riding because you’re getting old, but you get old when you stop riding.
backtodirt is offline   Reply With Quote
Old 09-17-2013, 03:51 AM   #13460
The Cougar
Barry Dawson's Twin
The Cougar's Avatar
Oddometer: 446
IMS fuel petcock
My IMS fuel petcock has developed quite a leak. Source tells me the IMS supplied ones are not much chop and suggested a Yamaha Raptor one may fit.
Any advise re a suitable replacement for the IMS tank petcock?
thanks
The Cougar is offline   Reply With Quote
Old 09-17-2013, 03:58 AM   #13461
gavo
Slacker
gavo's Avatar
Oddometer: 1,800
gavo is offline   Reply With Quote
Old 09-17-2013, 06:42 AM   #13462
bushdog89
Oddometer: 15
thanks
Had the same problem with my safari tank. I called them up and told me the rubber seals were european made, where fuel is apparently better. They then sent me some new seals (apparently) made of a different rubber. So far they have lasted longer than the original and no leaks. I don't know about the raptor petcock, I did buy a brand new yamaha petcock off ebay for $19 (tap facing backwards) It was a ripper.
bushdog89 is offline   Reply With Quote
Old 09-17-2013, 01:43 PM   #13463
B1
B1's Avatar
Oddometer: 3,270
yep, if you check the procycle website you'll see they are selling that yamaha fuel tap there so it works on the DR tank or aftermarket tanks fine. it won't be vacuum-operated of course, so you'll need to plug up your vacuum hose with a suitably sized bolt.
Old 09-17-2013, 05:08 PM   #13464
willows
Oddometer: 298
Pirelli Scorpion Trail front and trailwing rear..... Once had a pair of Mitas 7's on a Transalp. Excellent on the dirt, loose gravel, sand and even a little mud. Worked well on dry tar, but shocking on wet! That particular ride put me off Mitas forever. Now use Heinenou.
2005 KLR650
willows is offline   Reply With Quote
Old 09-23-2013, 06:23 AM   #13465
paynebrody
¯\_(ツ)_/¯
paynebrody's Avatar
Oddometer: 34
Hi all
Just checking in from Clifton Hill (and the North East). Better late than never?
paynebrody is offline   Reply With Quote
Old 09-23-2013, 04:07 PM   #13466
panhead_pete
Oddometer: 1,135
Put a helmet on. Skin will repair, your noggin wont.
More gear and still no idea.
panhead_pete is offline   Reply With Quote
Old 09-23-2013, 10:18 PM   #13467
paynebrody
¯\_(ツ)_/¯
paynebrody's Avatar
Oddometer: 34
I knew someone would get me on that...
Old 09-25-2013, 07:48 PM   #13468
mat@jiggi
mat@jiggi's Avatar
Oddometer: 7
output shaft bearing
Just testing the combined knowledge of the dr community. Last week while riding home from work stopped to get mail at bottom of driveway, went to change into 1st but bike wouldnt go past neutral. made it up driveway in second and into shed, tried 1st again only to be greated to a crunching sound. Trailered bike to mechanic and the outcome is a destroyed output shaft bearing. Has anyone heard of this happening before and why? Mechanic has never seen/heard of it happening to a Dr. Hoping there is not to much internal gearbox damage, fingers crossed.
mat@jiggi is offline   Reply With Quote
Old 09-26-2013, 02:33 AM   #13469
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 330
Could be the result of an over tensioned chain.
grrant1058 is offline   Reply With Quote
Old 09-26-2013, 03:13 AM   #13470
mat@jiggi
mat@jiggi's Avatar
Oddometer: 7
Thanks Grrant, owned bike since new, 31000kms, chain never tight (probably usualy too loose). Anyone else got any ideas?
Times are GMT -7.   It's 03:17 PM.
