Old 01-02-2014, 06:46 PM   #13621
ER70S-2
ER70S-2's Avatar
Oddometer: 6,775
I luv dirt.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 01-03-2014, 06:51 PM   #13622
Tomocan
Tomocan's Avatar
Oddometer: 110
Carb float adjustment Perth
Looking for a perth local who is good with carb's.
Mine is leaking through the over flow pipe and I have tried pulling it apart and adjusting the tab. Stopped leaking then and even after I let it idle for a while but then started again after a ride (freeway and some first and second gear in sand).
Any advice or assistance would be appreciated as I'm trying to skill up mechanically by doing anything I can on the bike myself.
Mods: Sorry if this is in the wrong spot but thought with the local request it was best suited here.
Something inspiring or something!
Tomocan is offline   Reply With Quote
Old 01-03-2014, 07:27 PM   #13623
ER70S-2
ER70S-2's Avatar
Oddometer: 6,775
These two O-rings fail regularly because of ethanol and should be replaced every other year or so. The older the bike the more likely. Just because they may look good doesn't matter. They will allow flooding just like a leaking needle.
2013 WR250R
Old 01-03-2014, 09:43 PM   #13624
racca
racca's Avatar
Oddometer: 331
I got told this as well, but I just told the missus the carby was stuffed and put a pumper on
racca is offline   Reply With Quote
Old 01-03-2014, 10:04 PM   #13625
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,412
and they can bugger awful fast. my last DR was only 9 months old when those o-rings stuffed up. took ages to work out what was wrong because i figured the bike was too new to have those rings perish.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 01-03-2014, 10:05 PM   #13626
BergDonk
BergDonk's Avatar
Oddometer: 3,719
Try the Perth riders thread too.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-04-2014, 12:41 AM   #13627
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,915
I've put this in the wanted section,but some of you might not have a look so..
i am looking for a FMF or staintune slip on if you know of one going for a dr650 2009 onwards
thanks mick
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is offline   Reply With Quote
Old 01-04-2014, 01:25 AM   #13628
Tomocan
Tomocan's Avatar
Oddometer: 110
What were the symptoms?
Old 01-04-2014, 09:59 AM   #13629
motolab
motolab's Avatar
Oddometer: 2,742
A misadjusted float height alone will not cause a BST40 carburetor to overflow.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-04-2014, 10:03 AM   #13630
motolab
motolab's Avatar
Oddometer: 2,742
Inspect the tip of the float needle with and without magnification to see if it has a witness line where it has been contacting the seat. If so, fuel is leaking past or will do so soon.
Regards,
Derek
Old 01-04-2014, 10:55 AM   #13631
ER70S-2
ER70S-2's Avatar
Oddometer: 6,775
Witness line
2013 WR250R
Old 01-04-2014, 08:56 PM   #13632
B1
B1's Avatar
Oddometer: 3,412
initially just stalled on bumpy ground. got progressively more sensitive to this. eventually would only run if using at least half throttle. worst point was overflow of fuel back into the airbox and leaking out. had the carbie apart about six times over a two month period, plus posting on various forums and taking it into suzuki for their mechanics to inspect.
only got it sorted when someone who had this happen to their near new DR said replace the o-rings even if they look perfect.
Old 01-05-2014, 02:52 AM   #13633
greendude
greendude's Avatar
Oddometer: 1,134
the moral of the story is avoid ethanol when you can
greendude is offline   Reply With Quote
Old 01-05-2014, 08:01 AM   #13634
rhino_343
Southern Explorer
rhino_343's Avatar
Oddometer: 2,131
Thumb Fat bar mounts help please
What have you guys used to mount fat bars on the DR? Is there a recommended mount? I have been looking at some generic bar mounts with a 60mm thread length and 10mm diameter bolt, but the guys at the bike shops seem reluctant to sell them to me and say they think they won't work... I can't see why not?
BTW I don't want the riser style ones that sit on top of the stock mounts, I actually want as little rise as possible, just want to convert to pro taper fat bars 1 1/8" size.
Help appreciated!
Moto Guzzi Griso 1100
Suzuki DR650SE P I G
Husaberg FE350
Tenere XT600 34L 1983 classic
rhino_343 is offline   Reply With Quote
Old 01-05-2014, 08:03 AM   #13635
rhino_343
Southern Explorer
rhino_343's Avatar
Oddometer: 2,131
Question
Just bought a DG slip on, anyone else got one and had to adjust the holes on the mount brackets because they didn't line up with threaded holes on frame?
Husaberg FE350
Times are GMT -7.   It's 05:39 AM.
