Old 01-12-2014, 03:43 AM   #13651
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,453
Originally Posted by Fulldeck View Post
Hi CCCC,
When I fitted my 14T the boss (raised section on the sprocket) went towards the engine. Also I hope you received a new triangular retention plate with the sprocket otherwise you are going to have grind down the original retainer edge as the chain can bind on the original retainer when used with the 14T sprocket.
Cheers and Good Luck
I don't see why there are issues grinding down the stock retainer. It only holds a worthless supposed vibration dampner band around the outer circumference that does nothing. The ground down retainer will still retain the stock size and any size sprocket exactly the same way. It's not like it is going to affect the re-sale or anything and grinding it down is a 5 minute job, even if it's not perfectly round, it won't harm anything. I used mine since new like this with numerous sprocket changes and simply use a bit of blue locktite on the retainer bolts without any issues ever.
Just saying...
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 01-12-2014, 04:37 AM   #13652
rutsthematter
rutsthematter's Avatar
Oddometer: 149
Originally Posted by kimmie View Post
Bikes in neutral, no neutral light
Check your nsu screws. May have come out and got stuck somewhere in the engine. Dont ride the bike anywhere.
rutsthematter is offline   Reply With Quote
Old 01-12-2014, 09:57 AM   #13653
sh4kes
Oddometer: 64
Long shot, but does anyone have a clear/translucent safari tank they'd like to swap for a yellow one? I'll be riding around most of Aus later this year if there's anyone keen.
sh4kes is offline   Reply With Quote
Old 01-12-2014, 01:48 PM   #13654
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 174
We already loctited the NSU screws. I have traced the entire NSU loom form CDI to bulb (which is OK) and I think the sender just flakes out when it gets hot. Tonight I am going to hotwire it, so it thinks its always in Neutral and see if the problem persists. If not then only course is to replace NSU.
K
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Karlxx is offline   Reply With Quote
Old 01-12-2014, 03:09 PM   #13655
Portly
Plodder
Portly's Avatar
Oddometer: 299
Maybe a Carb service will help Kimmies hot starting.
I don't think Neutral system would effect it if the stand is up and the clutch is pulled.
Correct me if I'm wrong, but if the engine turns over on the starter then the safety cutouts would be working properly.
Tight gearbox when hot maybe oil type/viscosity or warped clutch plate dragging a bit.
Portly screwed with this post 01-12-2014 at 03:16 PM Reason: addition
Portly is offline   Reply With Quote
Old 01-12-2014, 04:56 PM   #13656
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 174
It will not crank at all until it cools. press starter and nothing, no click even.
I did not try to bump start it, that may work if the bike just is inhibiting start.
Aparently with clutch in and sidestand up it wont crank either... But I was not there when she tried that.
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Old 01-13-2014, 02:07 AM   #13657
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 174
OK so I disconnected the connections to the NSU and worked out what made it tick. The blue wire has to be at ground to light the neutral lamp. Then I warmed up the bike and it eventually flickered and went out and the engine stopped. Then I grounded the blue wire and everything fires up. So it works now, albeit the neutral light stays on. So a new NSU is probably the only solution, about $75.
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Old 01-13-2014, 02:22 AM   #13658
KIZ
Marty
KIZ's Avatar
Oddometer: 513
My DR starts in gear as long as the side stand is up and clutch lever pulled in. Engine cuts out when side stand is pushed down while in gear(and neutral light off). A safety thing. I high sided off a TX500 years ago when the sidestand (left down) dug into the bitumen on a left turn.
KIZ is offline   Reply With Quote
Old 01-13-2014, 06:57 AM   #13659
Tomocan
Tomocan's Avatar
Oddometer: 89
Leaking Carb
Thanks to
ER70S-2
racca
B1
BergDonk
motolab
Put in new float and rings and no more leak. Seems to be running a bit smoother to just by ear.
Cheers!
Something inspiring or something!
Tomocan is offline   Reply With Quote
Old 01-13-2014, 09:52 AM   #13660
motolab
motolab's Avatar
Oddometer: 2,520
Originally Posted by Tomocan View Post
Thanks to
ER70S-2
racca
B1
BergDonk
motolab
Did the tip of the float needle have a witness line?
Did you change the oil?
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-13-2014, 01:38 PM   #13661
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 174
OK, so thats why she could ride when the lamp had gone out but it stopped when I warmed it up on the side stand (side stand was down). All our bikes stop if you engage gear when the stand is down, the DR is the only bike you have to pull clutch in to start in neutral on the stand.
Thanks all, I will let you know how replacing the NSU goes. Pity I have to rip the clutch out twice in a month...
K
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Old 01-14-2014, 01:47 AM   #13662
gavo
Slacker
gavo's Avatar
Oddometer: 1,795
After a DR speedo anyone ditched their's for a vapor and be willing to part with it. I put this on wanted also
GOT ONE TA
gavo screwed with this post 01-14-2014 at 09:04 PM
gavo is offline   Reply With Quote
Old 01-14-2014, 07:15 AM   #13663
Tomocan
Tomocan's Avatar
Oddometer: 89
Regards,
Derek
To be honest I did not check the needle.
Oil change is happening this weekend.
Cheers Rob.
Old 01-14-2014, 09:31 AM   #13664
sh4kes
Oddometer: 64
I'll have one available in a month or so. So if you dont have any joy by then, drop me a line.
Old 01-14-2014, 10:04 AM   #13665
motolab
motolab's Avatar
Oddometer: 2,520
I consider that to be kind of risky.
I don't recommend riding it beforehand.
Regards,
Derek
Times are GMT -7.   It's 05:59 PM.
