Old 01-14-2014, 01:49 PM   #13666
BergDonk
BergDonk's Avatar
Oddometer: 3,596
And if anyone has a spare bracket/clamp that goes over the top of the battery I'm after one. Posted in WTB too.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-14-2014, 10:58 PM   #13667
ER70S-2
ER70S-2's Avatar
Oddometer: 6,483
Originally Posted by Tomocan View Post
Thanks to
ER70S-2
racca
B1
BergDonk
motolab
Put in new float and rings and no more leak. Seems to be running a bit smoother to just by ear.
Cheers!
Don't hesitate to ask again if this doesn't solve the problem.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 01-17-2014, 03:52 PM   #13668
petemoss
Having a look around
petemoss's Avatar
Oddometer: 411
Just put a deposit on a DR It had fallen over in the workshop and bent the bars a bit. They're going to put a set of protaper/renthal on it. Haven't talked to the parts bloke yet to work out what exactly what..........
So a couple of questions for the knowledgeable folk in here. Will a set of high bend bars mean it's unlikely I'll need risers? (I'm about 5' 10") What are the most commonly used/favoured options? Fat bars to get rid of the centre support or standard diameter and use the support for GPS/phone cradle type gear? Thanks!
Edit - Talked to the sheila in accessories. They will be protaper. I've been searching and reading and tapping into the general wisdom in here and I'm leaning towards fatbars with a high bend and add risers later on if I need them.....unless somebody has advice against this? (risers with fatbar adaptors don't work? Any tips on specific models would be appreciated. If I read too much on my own without some words of wisdom I'll overload and hurt my brain
Faster Horses, Younger Women, Older Whiskey, More Money
petemoss screwed with this post 01-17-2014 at 05:30 PM
petemoss is offline   Reply With Quote
Old 01-18-2014, 09:18 PM   #13669
BergDonk
BergDonk's Avatar
Oddometer: 3,596
Handlebars are a personal thing, torso height, arm length etc. There is no doubt however that a nice strong alloy bar will take more punishment than the stockers.
Note that bar risers go up and back, but there are other solutions that go up and forward like those from ROX.
http://www.motorcycleadventure.com.a...rice&order=ASC
A really useful spreadsheet is linked here that has lots of bar dimensions for comparison:
http://www.yamahasupertenere.com/index.php?topic=6749.0
Big effort by the author!
Old 01-18-2014, 09:49 PM   #13670
Tenerrod
Backyard Hack
Tenerrod's Avatar
Oddometer: 1,307
Question Rear shock wanted.
Anyone got a used rear shock laying around?
I only need the housing but a complete one would be easier to source.
The one l have was damaged when the guts of the reservoir decides to escape.
The circlip took a big nick out of the housing when it busted out of its groove, rendering the housing useless.
The little bladder inside also got lunched but that's no problem to replace.
Any leads appreciated.
Cheers
XT660Z Tenere - Ol' Smokey
CARRIER OF THE PUDDING Perth - Melbourne Dec 2014 - 3 Days
QUORN SCHNITZEL CLUB MEMBER Dec 2014
Tenerrod is offline   Reply With Quote
Old 01-18-2014, 10:48 PM   #13671
DRjoe
DRjoe's Avatar
Oddometer: 5,117
How the fuck did you do that?
Old 01-18-2014, 11:14 PM   #13672
petemoss
petemoss's Avatar
Oddometer: 411
Cheers
Old 01-18-2014, 11:18 PM   #13673
greendude
greendude's Avatar
Oddometer: 1,132
us DR owners get very creative
greendude is offline   Reply With Quote
Old 01-18-2014, 11:48 PM   #13674
Tenerrod
Backyard Hack
Tenerrod's Avatar
Oddometer: 1,307
Dunno.
Lightly loaded, easy pace with 10 others.
Suddenly there was a lot of smoke as all the shock oil hit the exhaust.
Old 01-19-2014, 03:25 AM   #13675
DR Steve
DR Steve's Avatar
Oddometer: 325
Originally Posted by Tenerrod View Post
Dunno.
So is it the bladder reservoir circlip thats damaged and not the actual shock body ?
If it's the bladder reservoir, you should be ok to put it all back together as it all sort of holds itself in place once gassed. I can't see how it could have come out unless you lost all the pressure in the bladder first and the bladder seal head moved allowing the circlip to come out.
Even with a few gouges in the circlip grove it should still hold.
'13 DR650
DR Steve is offline   Reply With Quote
Old 01-19-2014, 11:29 AM   #13676
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Could've been too much oil put in there methinks
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 01-19-2014, 03:07 PM   #13677
Tenerrod
Backyard Hack
Tenerrod's Avatar
Oddometer: 1,307
Nah it's the actual shock body. Where the bladder circlip sits it had taken a decent nick out of the body as it came out. I'd rather rebuild another body to a higher spec than anything else.
Too much oil? It has been played with but all to OEM specs. Could be though.
May have sourced a second hand shock already.
PM received.
I will try and get a pic up for interests sake.
Thanks fellas.
Old 01-19-2014, 06:31 PM   #13678
micko01
another DR650 rider
micko01's Avatar
Oddometer: 211
The circlip took a big nick out of the housing when it busted out of its groove, rendering the housing useless. fail at spell
Cheers
hey Tenerrod I've got one - two actually. One standard, perfectly functional, can sell with standard spring or 7.6 spring or no spring. Plus another revalved one with 8.0 eibach. Plus I've got a fair bit of other stuff from 2 x DR rebuilds which will be going on the flea market over the next couple of months.
I'm in Kalamunda - but wont be around for a couple weeks. Gotta go to japan for some snowboarding..... sigh.
micko01 screwed with this post 01-19-2014 at 06:34 PM Reason: Eye failed at the spellings
micko01 is online now   Reply With Quote
Old 01-19-2014, 08:23 PM   #13679
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,901
hi all
i am looking for wider foot pegs for the dr that don't cost a arm & a leg if possible less than $100 any info links would be good
mickd
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is offline   Reply With Quote
Old 01-19-2014, 08:52 PM   #13680
BergDonk
BergDonk's Avatar
Oddometer: 3,596
Get a pair of Ballards rebuilders and use two, or cut one into two and widen the stockers. Even an old peg cut in two will do. Just an angle grinder and a bit of weld.
Times are GMT -7.   It's 02:55 AM.
