Old 03-16-2014, 04:33 AM   #13921
CCCC
Oddometer: 300
Hi All
Want to get some new rim locks for my DR. What's do you guys think are the best. Some times I run really low pressures and want to make sure I get the best rim lock out there.
Cheers
CCCC is offline   Reply With Quote
Old 03-16-2014, 12:20 PM   #13922
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,428
Originally Posted by CCCC View Post
Hi All
Cheers
don't go the cheap plastic ones, they do very little no matter how tight you clamp them down. i'm after advice on decent ones too as i ripped out a rear valve stem running 15psi and came close to the same issue on the front.
B1 is offline   Reply With Quote
Old 03-16-2014, 02:45 PM   #13923
BergDonk
BergDonk's Avatar
Oddometer: 3,785
Rim Locks
The Torpedo7 Talon clones work fine, but they don't do a 1.85 for the front. Ballards do though. And of course make sure you use the right width one. DR stock is 2.5 up back and 1.85 front. Most MX and enduro bikes use 2.15 and 1.6 widths, so their locks are too narrow for the DR.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-16-2014, 10:46 PM   #13924
DR Steve
DR Steve's Avatar
Oddometer: 332
Rim Locks
I'm using the Torpedo 7 lighweight Talon clones. They had a 1.85 for the front when I got mine some time back.
Be careful if you get your tyres fitted by a shop. One of my riding mates had rim locks fitted to his DR at one of Melbournes biggest bike shops (a few big stores around the metro area) only to have the rear come off the rim mid corner on the tar. Scary stuff to see right in front of you.
Shop had used 2.15 rear and 1.6 front rim locks and damaged the bead on a new MT21 rear while fitting it. Rim lock wasnt holding the tyre at all so it just rolled straight off the rim when the bead failed !
'13 DR650
DR Steve is offline   Reply With Quote
Old 03-17-2014, 01:49 AM   #13925
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,244
Phark!!
I never ever let a bike shop change my tyres when tubes are involved. Rather throw it over the shoulder and take it home and do it
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 03-17-2014, 02:42 AM   #13926
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,652
rim locks
All this talk of ripping off valve stems and rims locks breaking and rolling tyres off beads further reinforces to me that the DR is not a motocrosser. Why do you need to run your tyres at 15PSI? To me the dangers far outweigh the advantage in grip...Just my opinion.
Recent ride in muddy conditions T-63 Rear and Desert Front with much more than 15 PSI in them
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson screwed with this post 03-17-2014 at 02:58 AM
kezzajohnson is offline   Reply With Quote
Old 03-17-2014, 03:05 AM   #13927
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 344
Almost 150,000 km's now on DR's and have never run a rim lock and never had a tyre creep. Let my tyres down by feel at Purnie Bore and reinflated at Birdsville. Had inadvertently let the rear down to 8psi and not a problem.
Don't bother.
grrant1058 is offline   Reply With Quote
Old 03-17-2014, 03:19 AM   #13928
DR Steve
DR Steve's Avatar
Oddometer: 332
Rim Locks
I think the requirement for rim locks depends a lot on the terrain you ride/tyres you use.
I like to ride Vic High Country tracks when I can. For the most part they are steep, loose, and rocky. The technique required to get to the top of some of those long climbs is the same on the DR as it is on an enduro/mx bike - it asks a lot of the rear tyre and too much pressure bounces off the rocks and gives a small contact patch.
Before fitting rim locks on the DR I span the rear 606 on several occassions @ 20 psi. I don't see any down side to fitting rim locks.
'13 DR650
Old 03-17-2014, 04:20 AM   #13929
XRman
XRman's Avatar
Oddometer: 3,096
Houston we have a
In an attempt to remove the rear shock both top and bottom bolt heads have been rounded off.
We used quality six sided sockets and a rattle gun.
I suspect that a high strength loctite product has been used on the bolts.
It is either that or Suzuki uses reired Sumo wrestlers to torque their bolts.
Seeing as there are Teknik stickers on it, I suspect the former.i.e. it has been worked on post factory.
The bike has been dumped in the tray of my trailer to see if the local bike shop can heat the area and loosen the bolts.
Any other bright ideas??
XRman is offline   Reply With Quote
Old 03-17-2014, 06:25 AM   #13930
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 999
Cut 'em off and replace them with some hi-ten bought at the bolt shop.
It will be cheaper than a shop working on them.
I work in a shop and it's most likely what I'd do anyway.
Whole job should take about an hour and cost around $15 if you do it yourself.
http://lupineandboogowandering.blogspot.com
Dropped from full Team F5 sponsorship due to family commitments.
Stupid family.
Lupine128 is offline   Reply With Quote
Old 03-17-2014, 12:56 PM   #13931
B1
B1's Avatar
Oddometer: 3,428
they seem to come like that from the factory, i stripped my lower bolt head trying to take the shock out. i'd prefer suzuki redirect the two cents spent o loctite per bike to putting a decent amount of grease in the steering head bearings etc.
free enduro training vids for gumbies here
Old 03-17-2014, 01:02 PM   #13932
XRman
XRman's Avatar
Oddometer: 3,096
Cut them off,how?
Sent from my MB525 using Tapatalk 2
Green Triangle OZ ADVrider
Suzuki DRZ400 wide ratio : Tiger 800 XCx
Old 03-18-2014, 12:45 AM   #13933
dave43
Oddometer: 250
Cut them off,how?
Interesting dilemma, given the bottom bolt screws into the shock clevis. For future ref some sockets have a bit of a bevel for 2mm or so inside the open end and do not grip very much metal on the head. Maybe grind the end of the socket a bit so it is flat and see if there is enough bolt head to grip and try carefully with a bar instead of rattle gun. Good luck!
Dave
dave43 is offline   Reply With Quote
Old 03-18-2014, 01:57 AM   #13934
rutsthematter
rutsthematter's Avatar
Oddometer: 167
Bottom shock mount bolt torque is the same as the top according to the specs but the top is into steel and the bottom is into alloy. There is post somewhere which suggests a lower torque and low strength loctite for the bottom bolt to prevent problems like stripped heads threads etc.
Found it.
http://www.advrider.com/forums/showthread.php?t=466791
rutsthematter screwed with this post 03-18-2014 at 03:32 AM
rutsthematter is offline   Reply With Quote
Old 03-18-2014, 04:09 PM   #13935
ER70S-2
ER70S-2's Avatar
Oddometer: 6,870
Found it.
fwiw: Rick has changed the recommended torque from 37Nm to 46Nm. He posted on the DRRiders forum sometime last summer; so I corrected my post in Krusty's suspension index.
NC Rick:
An important note:
DO NOT use the Suzuki manual torque specification to tighten the lower shock mounting bolt (on the shock clevis).
The prescribed torque will often rip the aluminum threads out of the clevice on the OEM or our shock.
There is an error in the manual.
We suggest 46 NM as the correct torque to tighten the M-10 fastener in the aluminum thread.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 08:19 AM.
