Old 03-19-2014, 07:46 PM   #13936
XRman
XRman's Avatar
Oddometer: 3,099
We got them out!
Used a 11mm socket and a big hammer to swage it on the upper shock bolt head,thenused a bar. I could then slip the shock out lf thr frame.. Heat and similar hammer action with a 11mm socket.
Sent from my MB525 using Tapatalk 2
Green Triangle OZ ADVrider
Suzuki DRZ400 wide ratio : Tiger 800 XCx
XRman is online now   Reply With Quote
Old 03-19-2014, 08:06 PM   #13937
ER70S-2
ER70S-2's Avatar
Oddometer: 6,891
Thanks for the follow-up, everyone learns from your solution. Even over here.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-20-2014, 03:13 AM   #13938
dobbo
dobbo's Avatar
Oddometer: 1,007
valve clearance & lean?
Hi,
Did a valve clearance check today, made some adjustment.
Bike seems to be running lean now..... any ideas?
I am going to recheck them again, when l get the time.
Was, sure l had it at TDC on the compression stroke, would this cause it to be lean if l had it on the down stroke?
dobbo is offline   Reply With Quote
Old 03-20-2014, 04:45 AM   #13939
gavo
Slacker
gavo's Avatar
Oddometer: 1,857
Originally Posted by dobbo View Post
Hi,
Shouldn't alter your mixture at all but if they're out it can cause problems like hard starting and burnt exhaust valves.
gavo is offline   Reply With Quote
Old 03-20-2014, 09:19 AM   #13940
ER70S-2
ER70S-2's Avatar
Oddometer: 6,891
If you set them at overlap instead of compression, they'll be too loose which probably won't cause burnt exhaust valves as they'll be seated for much longer; transferring heat to the head.
2013 WR250R
Old 03-20-2014, 08:14 PM   #13941
BergDonk
BergDonk's Avatar
Oddometer: 3,790
Amcross
Natural terrain grass track MX Round 1 is near Cooma this weekend. Juniors Sat, Seniors Sun. At Muddah lake off the Shannons Flat Rd.
If you are in the area, worth a visit to see some fast people on dirt bikes. Good viewing at the track and normally no entry fees, but maybe gold coin, not sure as I'm no longer involved. But I do plan to be there for lunch tomorrow.
http://www.amcross.com.au/
http://www.foxsportspulse.com/assoc_page.cgi?c=1-7068-0-0-0&sID=176894
http://www.sportingpulse.com/get_file.cgi?id=2924871
http://www.sportingpulse.com/get_file.cgi?id=2875585
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-21-2014, 07:12 PM   #13942
Pottz
Oddometer: 83
Dumb Question
I have never professed to be any sort of mechanic but to do the basics - but need a little help despite the embarrassment....I had heavy duty clutch plates installed before xmas however the clutch cable has literally slid out from the arm on the crankcase and hanging by one thread....but for the life of me I can't work out how so and how to get the bolt/head out...or does it wrap around? or did it fall out because of some 'crimp' falling off from the other side...of course it is something I have never closely looked at and of course can't find diddly squat in the manual...any help would be appreciated....
Current: 2015 Triumph Bonneville; 2011 DR650SE; 2001 XT250 'Gentle Annie'
Past: 2010 DR650SE; 1979 Yamaha XT500; 1981 Yamaha XT500; 1978 Honda Elsinore 250
Pottz is offline   Reply With Quote
Old 03-21-2014, 07:37 PM   #13943
ER70S-2
ER70S-2's Avatar
Oddometer: 6,891
If I understand the question: your cable is about to break, you're on the last strand. The cable ends are factory and usually permanent (once-upon-a-time some were soldered and could be redone).
On the right side of the hole in the arm, by my finger, you can see the slot that lets you insert the cable end. You have to remove the arm to do that. If this is your question, you need a new cable. A drop of oil on all exposed cable ends will allow the barrel to rotate in their socket so the cable won't bend right there.
Is it something llike this? Internet photo.
2013 WR250R
ER70S-2 screwed with this post 03-21-2014 at 07:45 PM
Old 03-21-2014, 08:32 PM   #13944
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,245
Where are you Pottz...I can come and have a look if you like
He has a vairwee good fwiend in Wome you know
Big Willy is online now   Reply With Quote
Old 03-22-2014, 02:32 AM   #13945
dobbo
dobbo's Avatar
Oddometer: 1,007
Hi,
Just a bit of follow up on my issue of bike running hot/lean after valve clearance check/adjustment.
I have it sorted now.
I believe I must not have had it at TDC when I did the check. I used the cam lifter method to find TDC, I think this may have been my problem.
This time around, I just removed one spark plug, then placed my finger over the hole to ensure I was on the compression stroke.
When I said running lean, I guess I meant I could smell it cooking. so maybe not lean, just running really hot. When I checked the spark plugs again, they were black, with just 15 minutes running time on them.
Anyhow, thanks for your help, as I was a bit worried with an upcoming ride looming.
cheers
Dobbo
Old 03-22-2014, 04:37 AM   #13946
Pottz
Oddometer: 83
Ahhhh - you've nailed it and now it makes sense on how it fits together - I still have one thread hanging on but your pics explain it all and why I couldn't figure it....thanks heaps - new cable it shall be....
Old 03-22-2014, 04:40 AM   #13947
Pottz
Oddometer: 83
Thanks for the offer mate. The pic above explains it perfectly so a new cable will be the go. If I have any further dramas I'll drop you a line. Thanks again for your help. Cheers
Old 03-22-2014, 09:38 AM   #13948
ER70S-2
ER70S-2's Avatar
Oddometer: 6,891
Before you take the arm off, mark its position on the spline so you get it back in the same rotation.
2013 WR250R
Old 03-22-2014, 12:14 PM   #13949
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,245
No worries at all. Glad you've got it sorted
Old 03-26-2014, 03:41 AM   #13950
Thumper Dan
Oddometer: 328
Riding on the North Coast
Here is some footage from a trip on the weekend with another inmate....TRBaron. Unfortunatley there isn't any sound as Mr Baron didn't have the mic plugged in but you get the general idea of the terain we went through. I'm on the DR650, camerman is riding Honda Transalp.
Here is a link to the "Northern Rivers NSW ADV Riders" forum and recent converstation: http://www.advrider.com/forums/showt...625349&page=25
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Times are GMT -7.   It's 03:14 AM.
