Old 07-07-2014, 02:26 AM   #14251
rutsthematter
rutsthematter's Avatar
Oddometer: 165
Got a clutch question. The one different clutch plate (the black one) does it go bike side of the basket or on the outside. Fiche shows it on the inside but mine was on the outside. Thanks.
rutsthematter is offline   Reply With Quote
Old 07-07-2014, 02:55 AM   #14252
Philmeup
Philmeup's Avatar
Oddometer: 102
I was just about to post my own clutch problem, when I saw your post.
These photos are from the cyclepedia press 1996-2012 DR650 workshop manual.
Hope it helps.
I don't suppose you know why my clutch release arm isn't springing back after I put my clutch cover back on.
Philmeup is offline   Reply With Quote
Old 07-07-2014, 03:11 AM   #14253
Philmeup
Philmeup's Avatar
Oddometer: 102
Hi guys, so I thought a bit more info might help me get a more accurate response. I was pulling my head off too inspect my combustion chamber after dropping dirt in the spark plug holes. I know doh. When after reading the part in the manual that said don't drop anything down the timing chain cavity. I dropped a sealing washer down there. I know doh again. So that led me to taking my clutch cover off to retrieve the washer. I figured I better change the gasket ( which by the way took a bloody long time to remove the old one) anyhow that all I did to the clutch. After Re-installing the cover I don't have any return in the clutch release arm. It's got me stumped. Any help would be much appreciated. Thanks Phil.
Old 07-07-2014, 04:56 AM   #14254
rutsthematter
Oddometer: 165
Thanks for your reply, so the fiche is actually wrong looks like I will be rearranging my stack again. Last time I had the clutch cover off I remember having to play with the clutch lever arm a bit to get it to engage properly on the gear. Good luck.
Old 07-07-2014, 08:44 AM   #14255
ER70S-2
ER70S-2's Avatar
Oddometer: 6,780
There isn't any spring tension on the arm, it swings freely until it's connected to the clutch cable.
More info here, scroll down to pic 4 & 5 for the short version.
http://www.advrider.com/forums/showp...7&postcount=32
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 07-07-2014, 04:50 PM   #14256
dobbo
dobbo's Avatar
Oddometer: 1,005
Check this link, it might help:
http://drriders.com/topic11236.html
I had similar issues, I installed the clutch without the wire retainer & had the odd friction plate on the outside, then found I had no clutch.
I found that with out the wire retainer, the concave washer was able to move around which did not allow pressure to applied.
(not sure if you removed the inner most steel plate, held in position with the wire retainer?)
Might pay to check the concave washer has been installed the correct way around, as per link above. I have read where it has come from the factory the wrong way round.
I finally put the odd friction plate in towards the clutch basket (innermost position), now my clutch is working great.
Additionally: the steel plates have to go in to the basket with the 'sharpest lip' towards the outside, what I mean here is feel the outside edge of the steel plate and you will notice one edge is sharper, this edge has to be towards the outside (away from motor).
Also, cleaned my piston up with gasket stripper.
good luck
Dobbo
dobbo is offline   Reply With Quote
Old 07-10-2014, 04:19 PM   #14257
slapper
Oddometer: 98
any thoughts before I start diagnosing?
Monday night, the DR got me half way from the carpark at work to the street before stopping ... has not run since :(
Symptoms: on the way to work it intermittently would "bog" at lowish revs - I'd open the throttle and nothing much would happen. Same sort of feeling as "oops, better switch to reserve" so I'm guessing it's fuel related. However, it would pick up slowly and, when past a certain point, it would again accelerate smoothly. On the way home, it did it again but died completely and I have not been able to start it since.
Opening the drain screw on the carby shows there's fuel in the bowl but the exhaust does not smell of fuel despite repeated attempts to start (tried again last night to no avail). ON a side note, the starter motor squawk is constant now so I guess that troublesome bush will also need replacing!
It's done this on and off as long as I've owned the bike - once every few months so never consistent enough to work out what was going on. Each time, a few minutes rest has been enough to get it going again, leading me to blame fuel tap, non-venting tank lid, carby inlet filter and a host of other things (in that approximate order) .. until now! I don't yet know what to blame, but my gut feel is carby. Any thoughts?
Hopefully tonight I'll get a chance to start checking things - I haven't even had time to pop the tank and check for spark yet!
Oh .. and another thing .. the included Suzuki tool kit stopped being useful when I tried to get the seat off. Bugga!
slapper is offline   Reply With Quote
Old 07-10-2014, 05:00 PM   #14258
BergDonk
BergDonk's Avatar
Oddometer: 3,726
First ones to check are:
Filter in pipe in carb fuel intake?
2 pin connector to coil under tank partly disconnected for intermittent connection?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 07-10-2014, 07:40 PM   #14259
slapper
Oddometer: 98
I will get there tonight but neither seems to fit with the "minimal power at low revs, then getting better when revs pick up".
.. we'll see
Old 07-10-2014, 11:01 PM   #14260
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,209
Or sticky choke?
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Old 07-12-2014, 12:02 AM   #14261
duckslider
unintentionaldrifter
duckslider's Avatar
Oddometer: 3,333
Took carby off to change main jet,but can't loosen the 2 farkin bowl screws.Even tried vice grips....but they will not budge!!
any helpful suggestions appreciated.
Part of an Internet Forum ''Gang'' of Cyber Punks...........apparently.
2010 Deeaaaah 650(Black Pearl)
Wash it? It's a workhorse,not a bloody showpony.
duckslider is offline   Reply With Quote
Old 07-12-2014, 12:10 AM   #14262
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,744
They are JIS screws Bob, not Phillips. Phillips will "cam" out,you need the correct bit. Also give them a tap with a small hammer can help
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 07-12-2014, 12:34 AM   #14263
duckslider
duckslider's Avatar
Oddometer: 3,333
JIS hey.If ''cam'' out means burred,then they're cammed out.Tapped 'em with hammer but temper nearly took over!Will get ''proper'' bit tomorrow.
Thanks Dave.
duckslider screwed with this post 07-12-2014 at 12:45 AM
Old 07-12-2014, 12:36 AM   #14264
rutsthematter
Oddometer: 165
Try an old chizel and hammer. Dig into the screw head and tap around. The screws are soft metal.
Old 07-12-2014, 12:42 AM   #14265
duckslider
duckslider's Avatar
Oddometer: 3,333
I'll only do this as a last resort.
Times are GMT -7.   It's 11:37 AM.
