Old 10-27-2008, 09:45 AM   #61
willsy
willsy's Avatar
Oddometer: 15
I have just bought an FCR41 MX from a 2007 450 SXF and I am hoping to make this work with my 2003 625 SXC (which currently has a BST-40).
Does anyone know if I will need new throttle cables ?
Also, I will probably order a JD Jetting kit. Am I likely to need anything outside of what they supply in their standard kits ?
Thanks !
willsy is offline   Reply With Quote
Old 01-01-2009, 01:43 PM   #62
Desertpistons
80s dakar
Desertpistons's Avatar
Oddometer: 254
Bst
Anyone who has a bst at home to get rid of after the switch to a fcr? i am looking for one. thanks
Desertpistons is offline   Reply With Quote
Old 01-01-2009, 03:57 PM   #63
woodworkernyc
dirty
woodworkernyc's Avatar
Oddometer: 288
I have the BST40 from a '00 Lc4e that's available. PM sent
woodworkernyc is offline   Reply With Quote
Old 08-14-2009, 09:57 AM   #64
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
I can get fcr40 from 07rmz450 for a good price. Does anyone think it wouldn't work for 00 640?
My reasoning is that 39 and 41 works, why 40 wouldn't work?
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 08-24-2009, 11:01 PM   #65
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
Well, I decided to give it a try anyway. Now the question is how to make this work with stock airbox?
Any ideas? I may have to ebay it afterall.
666 screwed with this post 08-25-2009 at 08:10 AM
Old 08-25-2009, 03:52 AM   #66
kg4lho
Outside Sellin'
kg4lho's Avatar
Oddometer: 1,081
I have that carb also. I just need to clean it up, install the JD Jet kit, and figure out the bell to air box boot that I need. Let us know how it goes, Wes
"Behold, I stand at the door and knock. If any man hear my voice and open the door,
I will come in to him and will sup with him, and he with me." Jesus, Revelation 3:20
My KTM 620 RXC & Where I Ride.
Whats in the stable
'91 Honda ST1100
'98 KTM 620RXC
'99 Honda VFR800
kg4lho is offline   Reply With Quote
Old 08-25-2009, 04:43 AM   #67
halfcab
Oddometer: 681
If that is a 40mm FCR it's the first one I have heard about.
Air box to carb was not a big problem on my 01 LC4-E. I'm thinking the 2000 Adv and my 01 E should have the same boot.
halfcab is offline   Reply With Quote
Old 08-25-2009, 05:17 AM   #68
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
same here, i dont know that you are gonna be able to make that one fit. i wish you lot's of luck though!
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is online now   Reply With Quote
Old 08-25-2009, 08:09 AM   #69
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
it's from 07 rmz 450. Google it and that's what they have in it.
JDjetting suggested to use 625smc kit and it should work fine.
I think I need to make an aluminum ring adapter to match an existing airbox boot's ID and then epoxy it to the carb. I looked through SUDCO catalog and didn't find right adapter.
My 450 has FCR with 2 threaded holes so you can mount whatever intake you want. Why did they changed it?
Will keep updated. I pull bst out tonight and take some measurements.
PS. This carb also has hot start hole but no actual "pull knob" should I bother with it?
666 screwed with this post 08-25-2009 at 08:26 AM
Old 08-25-2009, 10:57 AM   #70
overlandr
Dystopist
Oddometer: 5,899
What are the 2 sets of code numbers stamped on the body of the FCR you have? The one I have is from a KTM 450 (from memory) 39mm FCRMX and the numbers are 3900B CRG02 and it only has the black choke knob but no Red hot start knob. I gather the hotstart feature is not critical. Even though mine's a 39mm nominal, when the engine side choke diameter is measured its 40mm!
I think you'll find that you MAY be able to get the "boot" or adapter parts you need if you look at the KTM parts on a fiche for a 625SMC or 450 or similar as those bikes used an FCR.
overlandr screwed with this post 08-25-2009 at 11:11 AM
overlandr is offline   Reply With Quote
Old 08-25-2009, 11:14 PM   #71
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
My fcr p/n is 35G4UG26. I measured OD on BST and air side is 58mm and 46mm on engine side. length is 98mm.
my FCR on air side 54.5mm and engine is 58.5, length is 82mm(16mm shorter).
Engine side almost works, but boot is slightly wider than needed. Could feet if I cut slot for the key on FCR manifold.
Something has to be made for the airbox side.
I kind of put FCR in and it goes very easily into the frame, enough clearance if I pull of crankcase vent hose. Stock cables should work, hopefully.
I don't think there is TPS on my year bike.
I am not sure if any of SXC boot's would work because it was for older FCRs , pre 07. Just look at the 07 525/450 fcrs, different air side and airbox goes directly over it, no additional boots.
Old 08-25-2009, 11:56 PM   #72
halfcab
Oddometer: 681
From what little I can see. The cylinder end bell side looks kinda strange, or is that two groves instead of the normal single grove?
You will find your air box boot adapter at LOWE'S or some pluming supply store.
I used a 1.5 rubber water pipe cap. I then cut off the cap part leaving a large flat/thick band to fill the small gap between air box boot and carb.
"With care" slide the new band on carb then mate the boot over the band and hose clamp.
The air box boot supports nothing, make sure it is so. All the support for carb is the cylinder head boot.
Somebody has got some nice RED TOES in the pic there ...666. They are not yours, or are they.?
Old 08-26-2009, 10:11 AM   #73
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
My wife was helping me by walking around and talking hell knows what about something.
I was browsing at lowes this morning and nothing was quite right, but could work. as you suggesting.
Would be nice if some ktm dealer had various cylinder boots in stock, so i could measure them and find the right one. I doubt it's going to happen. Anyone knows such a dealer?
Cylinder side on the carb has two grooves. Same on my 450exc.
Old 08-26-2009, 10:37 AM   #74
overlandr
Dystopist
Oddometer: 5,899
Re boots et al, probably worth checking Creepster's original text, ie ....
"The head to carb intake boot.
First, you can run both the original boots… they don’t fit as well as boots for an FCR, but the do fit and you save about $50.
If you do chose to buy the head to carb intake boot, it is in your best interest to buy the corresponding clamps as well. They are narrower by a few mm and smaller in diameter as well.
The BST boot clamps will fit, but they distort the boot shoulders and you can’t tighten down the carb end one enough to get a good, happy-snuggie fit."
Re your diameters 666, I measured the choke or internal diameter of the main air/fuel mix exit port that fis on the engine (not filter) side. 40mm
Old 08-26-2009, 11:13 AM   #75
djchan
djchan's Avatar
Oddometer: 1,173
My FCR39 went on perfectly with the airboot from a 625SXC. 12ish dollars from cheapcycles.com.
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
