Old 02-24-2007, 04:38 PM   #1
Hollywood OP
Oddometer: 210
Pissed Help me remove a stuck outer wheel bearing race.
The bike: 2001 DRZ400e
The bearing: Front wheel, non-speedo drive side (left if you're sitting on the bike)
The what: Trying to push out the shot wheel bearing and the inner race popped free, and out along with the bearings and leaving behind the outer race stuck to the inner-circumference of the hub.
Tips for removal w/out paying somebody at the stealership, or a machine shop to remove it? I've tried tapping with a flat blade driver and using a race removal tool, but no luckie.
thanks,
Mike
Everybody's gotta believe in something... I believe I'll have another BEER!
Hollywood is offline   Reply With Quote
Old 02-24-2007, 06:41 PM   #2
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
Use a long tapered punch from the opposite side. And use a heavy hammer, at least a pound. Hit it like it owes you money. One pop will loosen it enough to move the bearing spacer out of the way so you alternate hits, 180 degress apart. It will work it's way out. Use man tools, not a screwdriver and a lil' ball peen.
If that doesn't work, borrow your Mom's Dremel, buy some cutoff wheels for it and cut a groove, almost to the hub. Whack it hard with a chisel and that will relieve the stress and it will fall out. If you go a bit far and slice into the hub, sand the high points down before installing the new bearing.
You know how to install a bearing properly, right?
BMW 650 KDX 220 TS 400
If they can't hear you, they won't know you're there.
Scottysix9 is offline   Reply With Quote
Old 02-24-2007, 06:49 PM   #3
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
+1 on the dremel tool act, we used a die grinder to cut a groove to relieve preassure and they just about fall out
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Old 02-24-2007, 07:04 PM   #4
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,103
thanks,
Mike
Before doing any damage I'd try warming up the entire assembly pretty hot. Something like a propane torch would do. Then when it's all good and warm rub the offending race with ice. It might just fall out.
Riding season is finally getting in gear!<br><br>Pat<br>aka Geeeze
daGeeeze is offline   Reply With Quote
Old 02-24-2007, 07:16 PM   #5
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
No. It won't.
Old 02-24-2007, 07:22 PM   #6
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
One more thing...
Replace both bearings and their seals.
"If you're gonna do something, do it right"- my mom.
Old 02-24-2007, 07:40 PM   #7
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,320
If you can you get at it from the opposite side, I find the best tool is an old 3/8" extension, hit the drive end with the hammer and use the female end to hook the exposed rim of the outer race and drive it out like that.
GreaseMonkey is offline   Reply With Quote
Old 02-25-2007, 02:20 AM   #8
Hollywood OP
Oddometer: 210
Thanks for the replies. Yep, I know how to set a bearing and I have Man tools, one especially useful one , I've just never dealt with a bearing coming apart the way this one has and I do have new bearings and a new oil seal to go in.
I had the idea of using a cutoff wheel to notch it and then bust it free with a chisel or a heavy drift but I was concerned about the inner hub surface. Like you said the if there are any high points I can smooth them with a rounded file prior to pressing in the bearing.
thanks for the replies.
Mike
Old 02-25-2007, 02:51 AM   #9
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,784
I have a bunch of small conveyor rolls that when the bearing fails you end up with the outer race still in there.
What I do, and use this method at your own risk, is run a bead of weld on the inside of it, it will work with mig but works best stick welding.
As the weld cools it shrinks the race along with it and they normally just fall out with a tap on the side of the workbench.
katbeanz is offline   Reply With Quote
Old 02-25-2007, 04:34 AM   #10
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
As for the dremmel method, you may have to cut many grooves to get it to release.. If you cut one and try to wack it nothing will happen, as what you are doing is forcing the bearing to expand outward from the cut but the hub will give the bearing support and no crack will happen. Several deep cuts around the perimeter will give you better results.
Just be careful not to cut into the hub.
Old 02-25-2007, 04:35 AM   #11
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
Do you need to run a bead all the way around, or just a couple of inches?
Old 02-25-2007, 04:58 AM   #12
GSPD750
GSPD750's Avatar
Oddometer: 1,456
Know anyone with a blind bearing puller set that you could borrow from.
Slide hammer the SOB right outa there.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 02-25-2007, 05:04 AM   #13
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,382
Do you have a welder, any welder...!?!?
ussually they just come off just by welding on them, don't ask me why, it works.
but if that is not the case just weld any piece of metal as a bridge in between the two sides of the races (on the metal oviuslly, just cut a piece of anything and weld it one) and then you will have a surface to push aka hammer the S^^t out of it.
oviuslly heating the hub help to expend the aluminum too.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 02-25-2007, 05:22 AM   #14
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,103
Ah. That's the procedure I was told. I found out the backwards way when I tried to weld some kind of tang into a bearing race so I could drive it out. The one I was dealing with had NO lip to catch. I finally got a washer welded into the race, flipped the wheel over, and the bearing fell out. Now that you've reminded me I need to anchor that in my brain this time.
Old 02-25-2007, 05:42 AM   #15
Hollywood OP
Oddometer: 210
No welder here... of any type, or a blind bearing puller.
Maybe time for a trip to sears.
EDIT: Sears has a Blind Bearing Puller and slide hammer... $169 though :(
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Hollywood screwed with this post 02-25-2007 at 05:50 AM
Times are GMT -7.   It's 11:55 PM.
