Old 02-25-2007, 05:46 AM   #16
Grumpy
Grumpy
Location: Lower South Coast, Kwa Zulu Natal, South Africa
Oddometer: 319
Originally Posted by katbeanz
I have a bunch of small conveyor rolls that when the bearing fails you end up with the outer race still in there.
What I do, and use this method at your own risk, is run a bead of weld on the inside of it, it will work with mig but works best stick welding.
As the weld cools it shrinks the race along with it and they normally just fall out with a tap on the side of the workbench.
This works 100% providing you have a arc welder and can weld.
Grumpy is offline   Reply With Quote
Old 02-25-2007, 05:53 AM   #17
Hollywood OP
Oddometer: 210
No welder... looks like it is time to learn. I've had a number of occasions lately that I've farmed out that could've been done at home.
What to buy for home use...?
Everybody's gotta believe in something... I believe I'll have another BEER!
Hollywood is offline   Reply With Quote
Old 02-25-2007, 12:13 PM   #18
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,221
Weld a bar in place as per my post on this thread:
http://www.advrider.com/forums/showthread.php?t=192590
Worked for me years ago.
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 02-25-2007, 01:07 PM   #19
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,780
Originally Posted by Gramps
Do you need to run a bead all the way around, or just a couple of inches?
I usually go all the way around for dramatic effect, it doesn't have to be pretty and 6011 or junkyard rod works pretty good.
These are steel rolls so obviously you don't want to accidently weld the race in place.
As I said use it at your own risk, I don't know how it might effect your hub. I would imagine you would want to have your ground clamp right on the race.
With an aluminum hub you don't have to worry about accidently welding the race in place.
I think it was motion pro that makes a tool for steering head races, spring steel fingers that pop out and grip the edge of the race, I think I'd rather weld it.
katbeanz is offline   Reply With Quote
Old 02-25-2007, 01:30 PM   #20
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
just a minor point here
about DRZ bearings, but EVERY bearing I replace I get the number off the old one (or look at a new one and let the dealer keep it)
call your local bearing house
ask for an SKF or Timken and get double sealed (both sides)
usually they're less expensive and better quality
and no mo re-greasing after a mud ride
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 02-25-2007, 03:32 PM   #21
Hollywood OP
Oddometer: 210
OK, got it off - what a motherfucker. I don't have a welder, or a blind hole bearing puller set but I do have one hell of a dremel tool setup. I dremeled a slot in the race every 6-7mm and then with a good chisel, it popped out pretty easily.
thanks for the tips.
Old 03-31-2012, 04:01 PM   #22
vxweers
Oddometer: 1
usually forums are full of crap but if you just touch the bearing race with a stick welder in two places 180 degrees from one another the race will practically fall out.
I know. I just did it.
vxweers is offline   Reply With Quote
Times are GMT -7.   It's 04:37 AM.
