Old 06-21-2015, 01:09 PM   #1
oJOEYo OP
Oddometer: 34
BMW R80RT mono wiring scheme's in PDF!
Hi all,
I might finally be able to actually contribute something to you airhead lovers after all.
I'm working on a BMW R80RT '88. The previous owner messed up the wiring pretty bad. Half of the colors where mismatched, relays were placed wrongly. So I started with some scheme's I found online. Boy I was wrong when I thought that duo and mono schocks had 100% the same wiring. Messed that up twice, until I found a scanned scheme online for a R80 from my year. Since that was really, really hard to read after printing the scheme, I decided to start up Illustrator and work on a scheme myself. I have now exported a scheme for the bare basics (the things needed just to start) and the full scheme (albeit without volt meters / clocks )
Because I used a bad scan to start out with, not all colors might match perfectly, however, I used my basics scheme and that one works perfectly! I'm currently wiring all the other stuff but that can't be that bad, right?
Anyways, the scheme's can be found here!
http://joeyvanboxel.com/bmwcafe/
oJOEYo is offline   Reply With Quote
Times are GMT -7.   It's 08:09 PM.
