Old 09-18-2008, 05:56 PM   #136
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Voltage regulators ...
.... under $50 to replace $140 OEM:
Borg Warner R588
Neihoff WA 709 (Echlin, different shape)
NAPA VR503 (short harness and connector instead of pins, but works)
(Source: http://boxerworks.com/phorum/read.ph...38403&t=238403 )
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 09-18-2008, 07:09 PM   #137
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
updated. Thanks Stephen!
datchew is offline   Reply With Quote
Old 09-23-2008, 06:16 PM   #138
co_g30
Solo Rider
co_g30's Avatar
Oddometer: 328
Main Relay for 87 R80 Airhead - an alternative
found out that at Carquest, their p/n Ry116 is a direct replacement for the main relay on this Airhead and it was less than $15!
How did I find out? By being an airhead: LINK
The bmw stock relay is p/n 61321244411
so, if yours actually goes out, and there's not a beemer dealer nearby.....
CO_G30
2014 Ural Patrol, 1987 BMW R80
My Personal Blog
co_g30 is offline   Reply With Quote
Old 09-24-2008, 06:18 AM   #139
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,075
I think it's time I collect all the parts info from this thread and the Tips & Tricks thread and prepare a list of alternative parts numbers that are available from auto parts stores and stash it in the tool bag. Then when something goes south on the road, I'll have the info readily at hand.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 09-24-2008, 06:05 PM   #140
Beemerboff
Oddometer: 2,334
Dont forget to post it when you''re done
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 09-24-2008, 07:37 PM   #141
mark1305
mark1305's Avatar
Oddometer: 6,075
Will do!
Mark J
Merritt Island, FL
Old 09-25-2008, 08:10 PM   #142
roadrage
roadrage's Avatar
Oddometer: 1,022
Didn't see this tip.
Harley sealed battery for evo era softail (90's) works fine in the older airhead battery boxes. Same width and height, narrower by about 1/2". Same neg/pos orientation. More CCA's! Maybe $85 nowdays.
bob
roadrage is offline   Reply With Quote
Old 09-25-2008, 08:13 PM   #143
roadrage
roadrage's Avatar
Oddometer: 1,022
Originally Posted by bpeckm
The real eye-opener about zip-ties, to me anyway, was the way they were used as quickie handcuffs when making lotso arrests... Can you imagine trying to get out of them?
They work great, actually. Just be aware that sharp metal edges and vibration will eventually cut through. so, use lots of them!
and trim em tight to the locking part, unless you like getting cut when you reach into a tight place... they may as well be knife blades
Old 09-27-2008, 02:21 PM   #144
David_S
David_S's Avatar
Oddometer: 1,130
Another OPS option
NAPA Oil Pressure Switch OP6065 (C$16) is a direct replacement and works fine. Advrider inmate tested and approved.
***Datchew's note: Make sure the one you get is not a tapered fit. A 66 vw uses a tapered fit oil pressure switch and that will not fit properly. Stephen says this one is not tapered. ***
(thx to StephenB)
Also Duralast PS158 just paid 7 bucks at auto zone.
(thx to TxDieHart)
Might want to add a Standard part number since it's a brand available at a lot of mom & pop part stores. I just installed one and it is perfect. Cost $15.00 Standard part number PS177
David_S is offline   Reply With Quote
Old 09-29-2008, 09:50 AM   #145
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
updated. Thanks guys.
Old 09-30-2008, 03:11 AM   #146
DucatiPete
In denial
DucatiPete's Avatar
Oddometer: 162
I believe the tapered oil pressure switch David_S mentioned fits a /5... At least the one i got from my local vdub guy does.
2002 1150GSA (non-ABS) - 21st C Highway Adventures
1982 R100RS - new rolling project
1980 R80G/S - gearbox still needs attention + & etc
1973 R75/5 - Black Beauty - love @ 1st ride
1972 Ducati Sport - must look at the 'ol girl again soon
DucatiPete is offline   Reply With Quote
Old 09-30-2008, 03:22 AM   #147
David_S
David_S's Avatar
Oddometer: 1,130
The one I installed was not a tapered fit. It has straight threads with a gasket. I installed it on a /7 just a few days ago. It was a cross reference from the NAPA PN not looked up by any application.
Old 09-30-2008, 04:56 AM   #148
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
no biggy. I expect most airheads will be savvy enough to take their old part with them.
And if not, we'll hear about it and change the info. It's an iterative process... kinda like how they "practice" medicine.
Old 10-01-2008, 11:38 AM   #149
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 994
Headlight????
what about a reasonable replacement for the /5 headlight/reflector and rim other than the R65 conversion. I mean a stock one you can get from JCWhitney or others...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 10-01-2008, 08:58 PM   #150
Beemerboff
Oddometer: 2,334
The female thread is usually parallel , so whether you fit a taper male or a parallel with a washer is up to you.
Times are GMT -7.   It's 12:43 PM.
