Old 10-05-2008, 07:43 AM   #151
co_g30
Solo Rider
co_g30's Avatar
Oddometer: 297
Send a message via Skype™ to co_g30
another battery replacement option?
Got a quote from local beemer dealer for my 1987 R80 Airhead
BMW Dealer
Westco W49-1209
measures 7" in length, 3" wide, 6.5" tall.
12Volt 20ah
Weight 14.5lbs
MSRP on Westco site: $99, $115 @ dealer.
or you could go to digikey.com:
Digikey.com
Panasonic LC-X1220P
measures 7.126 in length, 2.992" wide, and 6.575 tall.
12Volt 20Ah
Weight 14.56 lbs
$75+shipping(figure about $20-25)=$100
same dimensions, almost, and cheaper. I'll be going with Digikey when its time to replace. Best part? Same battery should work just fine for my 2004 R1150RT! Or if in a rush, I'll just get it at the dealer I guess.
CO_G30
2011 Ural Patrol, 2006 Suzuki V-Strom Sidecar Rig, 1987 BMW R80
My Personal Blog
co_g30 is offline   Reply With Quote
Old 10-20-2008, 10:24 AM   #152
RandyB
Oddometer: 5,072
R100gs Cheap Voltage Regulator replacement option
I just picked up a cheap replacement from National Auto for $9.00. The part is made by KEM #KVR502. It has a wire pig tail with a plug(fem) end that matches up perfect. Just a pass along...
Found this buried in Old Skool from Drewb5.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 10-21-2008, 10:57 AM   #153
jbolivar46
Oddometer: 3
/7 gauges substitution
Hello,
Anyone know of or used different gauges than the stock? I've got a 77 R100S and 78R80 that use the cable ran gauges.
jbolivar46 is offline   Reply With Quote
Old 11-16-2008, 11:46 AM   #154
dmack
96 R1100gs
Oddometer: 171
Napa Oil Pressure Switch - NOT
Well, I just ordered and received the NAPA OP6065 oil pressure switch. It's threads are a lot coarser and the diameter is larger than the stock switch in my 1972 R75/5. Strike one.
I tried Western OR BMW (2.5hr drive yesterday) and they were out of stock. Strike two.
Went back to NAPA and they found one that fits. It is the OP6066, made to fit many european cars (BMW, Audi, Alfa, etc). Fits fine, just about 1/2" longer overall.
Dave
dmack screwed with this post 11-16-2008 at 05:19 PM
dmack is offline   Reply With Quote
Old 11-16-2008, 11:29 PM   #155
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,758
That would probably fit the later airheads (/6 - onwards). Your /5 takes a fine threaded switch.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 11-24-2008, 01:52 PM   #156
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
CHEAP!!!!! batteries for your BEEMER
BMW Dealer
Westco W49-1209
12Volt 20ah
Weight 14.5lbs
Digikey.com
Panasonic LC-X1220P
12Volt 20Ah
Weight 14.56 lbs
HOWZABOUT A even BETTER deal??
I would check out the TOYO brand batteries from www.beiterbattery.com
the skinny /5 style battery is a perfect fit on the BMWs. 12v20p
I bought one 2 years ago and it is awesome!!!
Especially at $40.00 plus shipping!!!!!!!!!
Holy crap, it fits and works perfect!!!!
ROBERT
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 11-24-2008, 08:33 PM   #157
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
Dave
Does it list the pressure in bars on the part? I ask because I took a used oil pressure switch from an R100 to the VW shop the other day and the only ones he had (several) were almost double the pressure rating in bars.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 11-25-2008, 12:02 AM   #158
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,758
I actually prefer to use those. I get an earlier warning so to speak. I believe the BMW rating is 0.3 bar, while what I use on my PD is rated at 0.5 bar.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
07 R1200GS
Old 11-25-2008, 07:18 AM   #159
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 789
Anhy recommendations for a good aftermarket (non-stock) voltmeter?
baldwithglasses is offline   Reply With Quote
Old 11-25-2008, 07:43 AM   #160
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,428
I know you're asking for a voltmeter, but thought i'd put in a plug for "BackOff" LED monitor: http://www.signaldynamics.com/products/Modules/HUVM.asp
And installed: http://advrider.com/forums/showpost....6&postcount=28
So far it's working great. Just enough to get my attention, but cheap and discreet installed. It's been educational to see how V drops when idling and how even turn signals being on can make a difference!
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 11-25-2008, 04:01 PM   #161
krehmkej
krehmkej's Avatar
Oddometer: 243
Front Brake Light Switch
To replace the brake light switch on the under tank master cylinder I used NAPA part #SL143 ($9.25) replacing BMW part #61311244334 ($36.58). Fit and functions perfectly. This part is for a mid 60s VW beetle.
krehmkej is offline   Reply With Quote
Old 11-25-2008, 09:41 PM   #162
dmack
96 R1100gs
Oddometer: 171
Oil Pressure Switch
Dasch,
Sorry, there are no markings on either the switch or the box.
Old 11-29-2008, 01:57 AM   #163
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,758
VDO voltmeter does it for my PD. New and cheap on eBay.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
07 R1200GS
Old 12-14-2008, 02:40 PM   #164
meijer's trails
meijer's trails's Avatar
Oddometer: 403
Cry Does anyone have an easy to find instrument bulb substitute?
the 12v 3w instrument bulbs for an r80g/s might be a sylvania 2821. or a napa 17037.
do you guys think this is correct?
being in NYC there is not much in stock at the NAPA on 125th so it will be good to know first.
of course, i dropped the bulb and it shattered and i now only have the spades
jason
meijer's trails is offline   Reply With Quote
Old 12-15-2008, 07:08 AM   #165
meijer's trails
Oddometer: 403
found it LMP 17097 at napa
part number LMP 17097 at napa is the generator light bulb
Times are GMT -7.   It's 11:05 AM.
