Old 03-14-2009, 07:31 PM   #181
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,122
Enduralast Alternator Question:
Where did you guys hang the rectifier/regulator unit on your GS?
The recommended location is only going to work on the standard /5,/6,/7 type bikes, not the GS and maybe none of the mono-shock bikes.
Where'd all ya'all hang yours?
I'm thinking under the tank where the original regulator lived, but would prefer a location a little windier.
Bob Loblaw
Old 03-15-2009, 11:26 PM   #182
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,566
On the far left. I put all the warning stickers that came with it on the reg in case I decide to move it later. this is where I saw a lot of other folks mount it. Another popular place is where the stock horn mounts behind the front fender for people that have put on Stebel air horns.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-16-2009, 10:15 PM   #183
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,122
Thanks for the tip, bgoodsoil.
I had to move a few relays around to make room, but it fits under there quite nicely.
Hopefully it'll get enough cooling air in that location.
I used the coil's power lead to supply "keyed power" to the unit. Anyone else wire theirs in a similar manner? Should I be concerned about over taxing the coil's power lead?
I have no idea how much current the unit draws and was sort of at the mercy of the instructions that advised to use any keyed power source that was handy. Guess it's not a big current draw or they wouldn't have been so liberal in their recommendations?
Here's hoping.
Has anyone on the board used one for a lengthy period of time can report on reliability, durability etc?
thanks again,
Lornce
Old 03-30-2009, 12:04 PM   #184
bereahorn
Oddometer: 1,070
Originally Posted by datchew
Wirewrkr is correct on the stiffer spring. Also, the striped "tiger tail" has a plastic bracket that rides on the cam, the other one has a fiber-ish material.
Bosch number for the 79-80 bikes is 01011 for the points, and 02093 for the condensor.
Also, here's a pic of the old and the new.
Top left is the condensor as they come from BMW. German made. Top right is the brazil part that you get nowadays.
Bottom left is the striped "tiger tail" points. Spring is stiffer. Bottom right spring isn't as stiff, but the throw of the pivot arm is almost twice that of the striped one, and the bracket material that rides the cam is different as I mentioned above.
THis pic might be rotated... i clicked rotate about 4 times and smug didn't catch up. Shoot me.
Thanks for the info. Very helpful as I have also acquired a points-in-a -can and correct coils for my PD.
bereahorn is offline   Reply With Quote
Old 03-30-2009, 07:04 PM   #185
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Anytime.
datchew is offline   Reply With Quote
Old 04-06-2009, 09:21 PM   #186
mattygeee
Oyster Gardener
Oddometer: 87
Originally Posted by wirewrkr
HOWZABOUT A even BETTER deal??
I would check out the TOYO brand batteries from www.beiterbattery.com
the skinny /5 style battery is a perfect fit on the BMWs. 12v20p
I bought one 2 years ago and it is awesome!!!
Especially at $40.00 plus shipping!!!!!!!!!
Holy crap, it fits and works perfect!!!!
ROBERT
Can someone confirm that this is the battery? http://www.beiterbattery.com/toyo12v...labattery.aspx
I need to order a new one ASAP. Thanks!
mattygeee is offline   Reply With Quote
Old 04-07-2009, 06:26 AM   #187
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
I cannot confirm that this is the battery that wirewrkr used, but I have that size on my /6, and it has worked perfectly for a year plus. The 18ah should be OK. These pack a lotta punch in their little package. SLA= sealed lead acid, which is a no-maintenance type which will not spill acid on the bike as it charges and discharges. All around, a good choice, especially given the $$$...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 05-29-2009, 08:50 PM   #188
ChemistOnWheels
Batteries ... Included!
ChemistOnWheels's Avatar
Oddometer: 52
Air Filter!
Hey all!
There was a question earlier in this thread about an OEM Air filter ... I need a new on for a /7. Any Fram or such that would work? I could *make* one from the old filter by cutting holes in it, and then wrapping the old air filter with 'air filtration' cloth ... but I'd like a source for a new one ...
Any hints out there?
Fred
1978 R100rs/7 named Greta
- Not all who wander are lost. - J.R.R.Tolkien
- Only a biker knows why a dog sticks his head out of a car window.
ChemistOnWheels is offline   Reply With Quote
Old 05-31-2009, 11:19 AM   #189
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 411
R100 parts
Looking for a seat for a R100Rs, also looking for rear sets and bar backs for the same bike.Any ideas where to start looking?
thanks
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV screwed with this post 05-31-2009 at 11:40 AM
StevefrmGV is offline   Reply With Quote
Old 05-31-2009, 12:55 PM   #190
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 798
Cheap ICM replacement for electronically-fired Beemers!
Fellow FF nothing says,
Originally Posted by nothing
An ICM from an eighties to early nineties VW can be used. I don't remember the exact year ranges or models, but my bike is currently running an ICM from a first generation Jetta - cost me all of $2 at the junkyard. Just look for an ICM that looks identical to the one on your airhead - if it looks the same and it's from a VW, then it will work.
baldwithglasses is offline   Reply With Quote
Old 05-31-2009, 02:16 PM   #191
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,667
thanks
Try www.siebenrock.com
R1150GS
R80GS Basic
Kokopelli is online now   Reply With Quote
Old 05-31-2009, 03:26 PM   #192
djaabrams
BMW GS Addicted
djaabrams's Avatar
Oddometer: 49
R100RS parts wanted
thanks
Try Omar's for the rearsets, http://omarsdtr.com/BMWvrs.html
Original seats can be had from Bob's BMW in Jessup, MD. If you want a good aftermarket to mate up with the RS rear seat cowl, try Corbin seats. They have a lot of BMW seats.
As far as the barbacks, you might consider changing the bars with BMW K75S handlebars. More comfortable riding position than the RS bars, without the worry of having to change wiring and cables like barbacks may make you do. I did this conversion on my R100S which someone had put some off brand bars on, and I am happy with the riding position.
Good luck!
'03 BMW F650GS
'10 BMW F800GS
'80 BMW R100S Cafe
'02 BMW R1150GS
'99 BMW R1100S
djaabrams is offline   Reply With Quote
Old 06-02-2009, 01:26 AM   #193
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,688
UniFilter
Originally Posted by ChemistOnWheels
Hey all!
Fred
www.unifilter.com
Rucksta is offline   Reply With Quote
Old 06-03-2009, 12:10 PM   #194
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
ICUs and Hall sensors
Have not seen the list here:
http://www.advrider.com/forums/showp...27&postcount=4
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 06-03-2009, 02:30 PM   #195
ChemistOnWheels
Oddometer: 52
Thanks Rucksta!!!
Times are GMT -7.   It's 12:59 AM.
