Old 03-28-2010, 03:30 PM   #271
gronk
HIGH ANGLE RIGGER
gronk's Avatar
Location: Very High Above Ground!North of The 49th parallel
Oddometer: 343
Thumb BMW R100GS hand grips
I put a set of Progrip 714 Rally grips on my stock bars ,these grips are bomber!! A vast improvement over stock. Cheap at $12.00 CDN
gronk is offline   Reply With Quote
Old 05-11-2010, 01:45 PM   #272
kpick
Free Range Human
kpick's Avatar
Oddometer: 702
Hi All,
just getting a old /5 back on the road after sitting for years and years.
The headlight (actual light not bucket) and chrome ring needs replacing.
Any info on tracking down these items?
Thanks,
K
The cause endures, the hope still lives, and the dream shall never die.
www.NationalCPRCertification.com
kpick is offline   Reply With Quote
Old 05-12-2010, 11:43 AM   #273
dotdash
scarecrow n hometown
dotdash's Avatar
Oddometer: 57
I think it's still available as a spare part. Hucky's has them. The stock head light is a bit weak. Your upgrade options are getting the OEM H4 upgrade (expensive), finding a used R65 headlight, or getting a cheap H4. I have a barely used Zitzen H4 and a rashed ring, if you wanna go real cheap...
going ninety miles an hour down a dead end street
dotdash is offline   Reply With Quote
Old 06-02-2010, 10:39 AM   #274
weggieman
Oddometer: 311
starter
OK, without having to scan this entire thread.
I need a starter, or starter parts for my '84 R100RS, ????? Who, where, how much?
Same questions for diode board.
I'll sit and wait for wisdom.................
The difference between genius and stupidity is genius has its limits....
weggieman is offline   Reply With Quote
Old 06-04-2010, 04:36 PM   #275
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
http://www.motoelekt.com/
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 06-15-2010, 05:10 PM   #276
svejkovat
svejkovat's Avatar
Oddometer: 856
Hi All,
Thanks,
K
On my 83R65 I replaced the reflector, lens, and bulb, with an off the shelf Sylvania round automotive headlamp from an Autozone. It was just a couple of bucks and was the right diameter so I thought it was worth a try. Got it home and to my amazement not only was it the right size, but the harness plugged right into the back without any modification! There were a couple of alignment tabs molded into the glass under the rim of the lens that had to be carefully ground off. After that, it was a direct replacement.
Don't know if this helps you at all.
svejkovat is offline   Reply With Quote
Old 06-16-2010, 06:01 PM   #277
P B G
Oddometer: 10,001
Originally Posted by ChemistOnWheels
Hey all!
There was a question earlier in this thread about an OEM Air filter
I haven't had much luck on this ever.
What I know is, for my R80/7 the filter is a Mahle LX-56 which is BMW PN 13721337080
I haven't yet found anything other than those two numbers. It stumped napa, it stumped another parts source I use. I have been thinking about using the rubber surround and cutting out the middle, but that rubber seems to get rather hard over time, the new ones always feel more like they seal up.
Ironically Real Oem lists the casting that goes over the filter for less money than the filter.
Old 07-05-2010, 07:57 AM   #278
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
As much as I hate to plug out of country suppliers, Motobins in the U.K.
has a "Reisen" brand airfilter for $13.50 or so.
Group buy?
Save on some shipping?
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 07-05-2010, 08:01 AM   #279
gronk
HIGH ANGLE RIGGER
gronk's Avatar
Oddometer: 343
Moto bins has treated me great!! Lets set up a group oil and air filter buy.
Old 07-06-2010, 05:19 AM   #280
Beemerboff
Oddometer: 2,311
Caltric on ebay has new Valeo starters for $102.00
I bought one a couple of months back when they were $90- .
They are not the branded Valeo starters which are now made in Poland or somewhere and are available elsewhere for around $190, but the quality looks OK and so far it has has worked perfectly.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 07-12-2010, 06:02 PM   #281
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Be VERY careful how you word this....
The starters you speak of are Asian Knock-offs of a Valeo starter.
Valeo is a brand name (good or bad), his $100.00 starters are copies, and although tempting at that price I would rather pay the $170.00 from John at EuroMotoelectrics, because he will stand behind what he sells.
It's all moot anyhow, because I'm a dinosaur and usually run Bosch starters.
Just saying........
Robert
www.wirewerkes.com
Old 07-12-2010, 07:06 PM   #282
Beemerboff
Oddometer: 2,311
I stand corrected- I should have said unbranded copies of the Valeo.
However, given the state of global manufacturing these days they may well be made in the same plant that makes the Valeos, and the Bosch!
And I agree with you on Euromotoelectrics, good man to deal with.
However , if you decide to order a starter relay from him for a 86 G/S MAKE CERTAIN YOU GIVE HIM THE PART NUMBER AND PIN CONFIGERATION ON THE OLD ONE- the one he sends has the wrong pin layout.
As an aside the old relay was a source of a baffling "charging fault" - it wasnt switching completly off every time and it somehow would drain the battery etc.
Old 07-19-2010, 05:29 AM   #283
eepeqez
eepeqez's Avatar
Oddometer: 2,068
Standard circular headlights are 7" or 5-3/4" diameter.
I don't know what the /5 models use.
The standard Bosch headlight on the R65 twin shock models (1978 to 1984) is an unusual size, about 6-1/4" diameter.
Cibie used to do a good quality halogen replacement in this size in the early 1980s; I bought one in 1981 to fit a 1978 Honda CB250T.
It turns out Honda have continued using this odd size headlight for later bikes based on the CB250T/CB400T motor, such as the CB250N/CB400N and CM250.
The CB250NB (about 1983) onwards had halogen headlights, whereas the NA and the T had abysmal prefocussed globes in a miserable headlight.
If you can't find a headlight for an R65, try looking at Honda 250 parallel twins.
Also, most headlights are specific to one side of the road, with a low beam which is higher on the kerb side to illuminate roadside signs. Many motorcycle headlights are symmetrical however, since this is the only feature of a bike which is specific to left or right side of the road driving. The assymetry or symmetry is clearly visible when inspecting the front of the lens.
eepeqez is offline   Reply With Quote
Old 07-21-2010, 09:20 PM   #284
XTrovert
chick magnet
Oddometer: 120
fork seal replacements
If you do not want to buy the OEM fork seals you can buy
ARIETE brand also know as ARI. They have most measures for airheads at a fraction of the price of the blue ones.
ebay vendor has them transcocasse
Also there are alternatives with this vendor in Germany 4motos_de
They will post to you worldwide if you ask nicely.
Hope the info helps
XTrovert is offline   Reply With Quote
Old 07-21-2010, 09:32 PM   #285
XTrovert
chick magnet
Oddometer: 120
oil filters
Fram has a great filter and in this link you can see all the other filters that will fit your airhead
http://www.framcatalog.com/PartDetai...?b=F&pn=CH6061
Applications Where Used
BMW R100 S 1000cc [1988-1976]
R100 T 1000cc [1984-1976]
R60 600cc [1984-1969]
R65 650cc [1984-1978]
R65 LS 650cc [1985-1978]
R80 800cc [1983-1976]
R80 G/S Paris-Dakar 800cc [1990-1987]
Competitor Cross Reference
Competitor Name Competitor Part
BALDWINP149
BIG A96946
BMW11 42 1 253 919
BMW11 42 1 337 198
BMW11 42 1 337 572
CARQUEST89946
CHAMPP7019
EMGO10-26700
HASTINGSLF609
NAPA4946
PUROLATORML36811
WARNERP7019
WIX24946
Times are GMT -7.   It's 09:59 AM.
