06-06-2011, 06:20 PM
#436 | |
BigBrowedNeandereer
Oddometer: 1,004
06-08-2011, 08:55 AM
#437 | |
the thread-killer
Oddometer: 4,297
That has been an issue for several years now. Browns was not real concerned and indicated to me when we spoke that there wouldn't be any changes made to this. |
06-08-2011, 10:59 AM
#438 | |
BigBrowedNeandereer
Oddometer: 1,004
The have done it. Cruised around the Redmond rally last year specifically looking for Brown stands on /7's. Saw a few like mine, owner install with the ground out area. Then I saw looking near new, a chrome Brown with the divot requied perfectly radiused. I thought oh, good, they are making them right now. Why would they revert back to WRONG?? To save $2 machine time?? Fouling the shifter can become very dangerous. It's not just engaging 1st, it also affects downshifting at speed in higher gears. |
06-08-2011, 01:13 PM
#439 | |
the thread-killer
Oddometer: 4,297
Browns were not chromed. Luftmeister copies were. |
06-08-2011, 04:18 PM
#440 | |
BigBrowedNeandereer
Oddometer: 1,004
Also, there would be no great difficulty in taking a brown, adding the relief properly on a mill and having it chromed. |
06-08-2011, 05:53 PM
#441 | |
the thread-killer
Oddometer: 4,297
![]() ![]() ![]() ![]() ![]() ![]() Ask Craig Vetter about that sometime. Pack your lunch, you'll be there awhile. |
06-08-2011, 06:06 PM
#442 |
Nanu-Nanu Adventurer
Oddometer: 7,016
i have been looking at ways to mount my Browns side stand and have just about come to the conclusion that if I want it on the bike, the exhaust is going to have to go back to stock. Not that there is anything wrong with that.
![]() Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 |
06-08-2011, 10:40 PM
#443 |
Oddometer: 2,052
Have a non stock stand on all my bikes - the Browns on my R75/7 is the least satisfactory.
I have a right hand side 2 into 1 exhaust , so the Micky Mouse idea of clamping a structural support to the exhaust pipe was a non starter. Wasnt hard to rig up a bracket back to the frame but remember it turns the opposite way srom what you would think when it is loaded, that is the LH end goes up. My secong grouse is the light springand poor geometry on the stand - if I kick the stand down the frigging thing bounces back up again ! The best stand I have seen is the one on my G/S made by a inmate here and sold on the vendors forum. The mounting plate for the stand is threaded for the engine mount bolt so the existing bolt is plenty long enough , and the front of the mount plate extends forward and is bolted to the pivot bolt for the G/S footrest, secure and safe. The spring geometry and strength are better than the Brown too - clunks solidly down and up , with no hint of a bounce.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST |
06-09-2011, 07:01 PM
#444 |
Should be outside
Oddometer: 447
Anybody know where one might find a replacement cylinder base o-ring for a 1976 R90/6 without resorting to ordering from a parts place? How about the cylinder stud o-rings? (I assume those are easier to find at an auto-parts joint.)
I've got NAPA and Advance Auto and various other hardware and auto-parts houses around. The nearest Beemer dealer is a four-hour round trip and I really don't want to wait for the UPS guy. Thanks!
2012 Honda NC700X '90 PW50 ![]() IBA# 49512 |
06-12-2011, 06:02 PM
#445 | |
the thread-killer
Oddometer: 4,297
If you've got one PLEASE shoot a pic and share! BMW used just the stud Orings until mid to late 80, when they introed the base orings. |
06-13-2011, 09:43 AM
#446 | |
Le Poulet du Désert
Oddometer: 282
Andrew
Big Ass Titties! |
06-14-2011, 09:39 AM
#447 | |
the thread-killer
Oddometer: 4,297
Not true. The standard 76 to 80 models did not use a base gasket either. There was one available from BMW to lower compression when pinging occurred. But not from the factory. Basically cylinder was glued directly to the case. |
06-14-2011, 09:40 AM
#448 |
Oddometer: 145
My '79 R100T with a build date of 12/78 has cylinder base o-rings. FWIW.
06-14-2011, 01:35 PM
#449 | |
the thread-killer
Oddometer: 4,297
Here a couple of shot of what they are supposed to look like. This first pic is a 93 GS block. wirewrkr screwed with this post 06-14-2011 at 01:43 PM |
06-14-2011, 01:42 PM
#450 |
the thread-killer
Oddometer: 4,297
1980 R100T Block, build date 11/79
