Old 06-15-2011, 07:35 PM   #451
bmwrench
Oddometer: 2,352
'79 and '80 used the cylinder base o-rings without a relief in the case-these were the 2.0mm white o-rings which now seem unavailable.
bmwrench is offline   Reply With Quote
Old 06-15-2011, 10:57 PM   #452
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
thanks Bud.
Mystery solved
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 06-16-2011, 11:28 AM   #453
Jim K in PA
Jim K in PA's Avatar
Oddometer: 1,332
Interesting. BTW - I ordered a set of O-rings from Jeff Trapp at Northwoods Airheads back in April or so and they were readily available then.
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is offline   Reply With Quote
Old 06-16-2011, 08:55 PM   #454
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
The smaller size went nla from BMW many years ago, but obviously Jeff is sourcing them from elsewhere if they are the smaller of the two.
They used to list two sizes, does Jeff?
www.wirewerkes.com
Old 06-17-2011, 01:35 PM   #455
Jim K in PA
Oddometer: 1,332
I don't see more than one size, but I did not ask Jeff when I ordered what size I was even getting! Ignorance was bliss in that instance. Here is the page with his o-rings: http://www.northwoodsairheads.com/ma...nce-parts.html
I can say that the o-rings looked like the same size as the white ones I took off, and they worked fine and are not leaking after 500 miles or so.
Jim K in PA
Old 06-19-2011, 08:16 AM   #456
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I guess I don't understand why one would buy parts from a non BMW source when the prices are pretty much the same. That's just me though.
Oh and as I've seen with lots of other venders just starting out in the parts business, There are more than one application mistakes in his listings.
I like Jeff Trapp, he's a good guy, but the mistakes need to be rectified so people don't buy the wrong stuff. That makes for upset customers.
www.wirewerkes.com
Old 06-26-2011, 01:48 PM   #457
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,479
So, if these are NLA what is the appropriate substitute? Sealant w/out an o-ring?
ozmoses is offline   Reply With Quote
Old 06-27-2011, 03:01 AM   #458
Beemerboff
Oddometer: 2,348
Some folks like 3 Bond sealant, instructions are on the pack - it is still sealing after 10 years on my 75/7.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 06-27-2011, 10:59 AM   #459
Fudmucker
ex-lurker
Oddometer: 268
Eh? Pricey plastic rings
Has anybody found an alternative source for this?
BMW Part number 31421241649 - 'guide ring'
There is one in virtually every Airhead front fork damper since 1980 and they cost US$21.76 each!
Due to Regional pricing were I live, they cost the equivalent of $37.50 apiece.
I haven't actually weighed one, but I suspect this tiny teflon trifle of a part is more costly than its equivalent weight in pure gold!
Airheads are an admirable addiction...
Fudmucker screwed with this post 06-29-2011 at 08:04 PM
Fudmucker is offline   Reply With Quote
Old 06-28-2011, 02:33 PM   #460
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,566
Expensive little part. I would think someone could make this part for under $10.00.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-01-2011, 08:39 AM   #461
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,764
*subscribed
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Old 07-01-2011, 10:13 PM   #462
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,570
Originally Posted by Zodiac View Post
*subscribed
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is offline   Reply With Quote
Old 07-02-2011, 04:59 AM   #463
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,764
Old 07-08-2011, 05:44 PM   #464
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
I've searched this thread and can't kind the info I need, so I'll ask.
I've got a 1978 r80 with points ignition. (not the bean can) this there any points from the local store interchangable with the originals?
also, I read in this thread that points from china don't last. I've looked at bobsbmw site and they have the parts I need. are these quality parts?(oem) price is a little high but if they're good quality I would rather get those.
thanks for any info.
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor is offline   Reply With Quote
Old 07-09-2011, 06:42 AM   #465
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,145
The points for the early Airheads are a one off type. Much like the oil filters, low volume equals high cost. You will not find an equivalent anywhere. Bobs has a great rep with regard to knowledge for correct parts for these machines. You're on the right track.
If you add the Dyna Booster, the points will last 3 or 5 times as long. Update to the Dyna III ignition and no more points at all.
DoktorT is offline   Reply With Quote
Times are GMT -7.   It's 04:38 PM.
