Old 01-16-2012, 12:57 PM   #511
_cy_
Oddometer: 6,057
only on page 9... eyeballs are glazing over... ahhhhhh gotta stop
Old 01-16-2012, 05:34 PM   #512
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,546
Originally Posted by Havingfun View Post
Has anyone found a substitute to the BMW Rubber Boot used on the forks? My '91 GS uses the 15 rib boot. I'm starting to look at some of the local 4-wheel drive shops to see if they have any rubber boots they use on shocks that might be usable on the forks.
Any help is appreciated and I'll report back on what I find.
And I have the 11 Ribs......even more expensive than the 15s.
I was looking a little while ago and found this, matches (or close) the fork/lowers for size. 30mmx60mm.
They give the total lenght as 10.5", also a match.
http://www.ebay.com/itm/gl1000-cb900-cb1100-cbr600-honda-39x60mm-10-5-fork-gator-rat-bike-brat-style-/120841610918?hash=item1c22b8a6a6&item=120841610918&pt=Motorcycles_Parts_Accessories&vxp=mtr#shId
Have tools, will travel!
Old 01-17-2012, 09:22 AM   #513
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 980
I put Rancho shock boots on. They look good and fit perfect on the top and bottom. They are not meant to be on a show bike. I repeat. I am not Perry B. I resurrect bikes, not restore them. They do the job and look good but the faithful ones go ape shit over not using original parts sometimes. I do use BMW clamps. More into function on a non-museum daily rider than some...
Rancho RS1952 - Rancho Shock Boots for $4 locally...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 01-17-2012, 02:28 PM   #514
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,546
Thanks...always tought those would fit from eyeballing too many lifted pick-up trucks up this way.
Don't care much about faithfulness myself but have to stay very close to the stock look. Collector's plates= much cheaper insurance.
OK I'll get a set, if any issues,as in the insurance assessor counting ribs, I'll just trade them with the OEMs I gave a friend 15+ years ago for his old Bonneville, that bike still hasn't moved.
Found a pic....if anyone cares about counting ribs.
Rancho RS1952:
Old 01-22-2012, 07:13 AM   #515
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,083
Do they have vent holes?
Old 01-22-2012, 08:25 AM   #516
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 980
They fit at the top perfect. Have to drive the pin into the brace. At the bottom them have two “slits” on each side. I wrap the fork leg with a mess cloth that acts like a filter for dirt and than clamp. Seems to work good. Sure better than none at all.
Terry, look for a PM from me soon about some speedo work. Thanks.
Old 01-22-2012, 12:53 PM   #517
Wirespokes
Wirespokes's Avatar
Oddometer: 8,083
Thanks for the tip on those fork gaitors! I've spent the rediculous sum of $70 for the correct gaitors and don't intend doing that ever again. Thanks for the 'heads up' - will watch for your PM.
Old 01-23-2012, 08:44 AM   #518
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
$70 for fork gaiters? That's nothing. I spent something like $76 for speedo and tach eyebrows. I was one week into quitting cigarettes tho and this was approximately how much money I spent every week on cigarettes. So I did it on poipose.
Charlie
---Albert Einstein
disston is online now   Reply With Quote
Old 01-23-2012, 10:48 AM   #519
pkboxer
Oddometer: 87
Fork gaitors
Don't know if anyone is replacing theirs because they look all "saggy" or because of cracks.
Mine were "saggy" they would touch the front of the fork tubes, do to time/gravity.
I drilled a vent hole on the other side and turned them 180 deg. Now, no sag.
Is that being too Anal?
pkboxer is offline   Reply With Quote
Old 01-23-2012, 05:01 PM   #520
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 980
Most the time I replace because they are not salvageable, even cracked ones that dont go all of the way through are replaced and 60% of the bikes I find dont have any. Good excuse to rebuild the forks and put new seals in anyway, most of the bikes I get have been sitting for some time...
Old 02-07-2012, 02:36 AM   #521
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 15,962
Where can I get 2 new pushrods for my R80 G/S?
Good and cheap.
Don't ask.
7th Day Adventourist.
Re-incarnated
Terrafied
The best cure for Sea Sickness, is to sit under a tree.
davorallyfan is offline   Reply With Quote
Old 02-09-2012, 05:30 AM   #522
moosehead
moosehead's Avatar
Location: south of the checkerboard....Bruce Penninsula
Oddometer: 274
Fork gaitors
http://www.motobins.co.uk/bmw-parts.php?model=R Series 2 valve Twin
Excellent price and quality ...no affiliation just happy customer ....9 GBP ea = approx $12 USD ea
retired from work - not life
moosehead is offline   Reply With Quote
Old 02-09-2012, 02:01 PM   #523
Zebedee
Zebedee's Avatar
Oddometer: 799
Good and cheap.
Don't ask.
I assume you've tried the usual suspects ... Munich, Motobins and Motoworks
John
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 02-09-2012, 05:30 PM   #524
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,195
Originally Posted by Mallard View Post
I'm on the lookout for a right fork slider for a duel disk conversion on the '76 R90/6 with 40mm ATE calipers. They're somewhere between rocking horse poo and hens teeth.
Can I use the fork slider from a R100RS? My reading on the Haynes suggests the stanchion diameters won't match. Is that correct, is there no other right-hand slider, other than a R90S right slider that will fit?
Cheers.
Here is some info on making a fork lower for the right side from a left side part.
http://advrider.com/forums/showthread.php?t=738951
Charlie
---Albert Einstein
Old 02-15-2012, 08:08 AM   #525
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Question WTB Right side plate for /5
I have a 1971 /5 and it is missing the right side cover. The left one is perfect just missing it's mate. I found them new but $250 for a SET of tins? Any right side for a /5 would do, powder coat is cheap. If you have one do PM me.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Times are GMT -7.   It's 01:51 AM.
