Old 06-03-2014, 04:23 PM   #766
Zebedee
Zebedee's Avatar
Oddometer: 833
Originally Posted by frasermanx View Post
Or I might just cut, solder
... and that might just be fine for you, but it's not what I want. Besides, soldering is hardly a dark secret ...
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 07-16-2014, 06:16 AM   #767
David4
Oddometer: 226
/ 2 owners....Apex Battery has the Adventure B38-6A on sale at $27.25.
http://www.apexbattery.com/adventure...batteries.html
1966 Triumph TR6R Trophy
1967 Triumph T120R Bonneville
1968 BMW R60/US
1969 Triumph T100R Daytona
David4 is offline   Reply With Quote
Old 08-04-2014, 10:07 AM   #768
Gripsteruser
Service Monkey
Oddometer: 853
In working out why I have (had?) no headlight I got into researching relays after trying to find one at the autoparts store and failing.
This link shows the standard terminal numbering system that you find on the pins of automotive relays. The numbers give indication of what each of the prongs do-
http://en.wikipedia.org/wiki/DIN_72552
With this you can do more skillful troubleshooting of electrical issues.
1988 R100GS (since new)
Previous- XT350, CB900F, XL185S, GS425E
Gripsteruser is offline   Reply With Quote
Old 08-04-2014, 04:55 PM   #769
jackafrica
sinking low in the saddle
jackafrica's Avatar
Oddometer: 432
/6 Tachometer cable; choose genuine, why.
Bought a Venhill cable from an aftermarket supplier in the UK.
Here's what I found compared to the genuine cable.
No extra protective outer cable in the right places. Inner secured only at one end, with a cheap crimped collar.
The inner cable square is poorly shaped ( not square), ends cut rough at an angle. Doesn't affect performance, though effective longevity could be questioned.
No detents on the upper outer sleeve to prevent the cable sleeve nut from falling down the cable into places you can’t reach. Poorly defined knurling on the upper threaded sleeve.
The lower sleeve was too tight AND the cutaway from the lower cable securing bolt was for a 5mm bolt rather than 6mm.
In addition, the position of the cutaway was higher than that of the original.
Good thing I have a lathe.
I turned the end down for a snug but comfortable fit, as well as reshaping the radius deeper and slightly lower.
A trial fit and all is well.
You get what you pay for.
The BMW genuine cable is twice the price and comes with the outer cover seal, effectively lowering the unit cost, provided you wanted to renew the seal of course.
cheers
richo
jackafrica is offline   Reply With Quote
Old 08-04-2014, 04:59 PM   #770
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
I used Venhill cables in the past. Here's what my experience was:
Snapped two clutch cables in 10 years, never snapped a BMW clutch cable
Carb synching is a b*tch with the Venhill cables. BMW cables ... hmmm... it's been 5 years since I synched my carbs I think, if not more.
They work, in a pinch, but I would never rely on the them.
(+350,000 kms on two bikes and two around the world trips.... so lots of experience with cables... :-)
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 08-04-2014, 08:28 PM   #771
Ben Carufel
Boxer Addict
Ben Carufel's Avatar
Oddometer: 737
Originally Posted by datchew View Post
I would check out the TOYO brand batteries from www.beiterbattery.com
the skinny /5 style battery is a perfect fit on the BMWs. 12v20p
I bought one 2 years ago and it is awesome!!!
Especially at $40.00 plus shipping!!!!!!!!!
Holy crap, it fits and works perfect!!!!
(thx to Wirewrkr)
Bumping this old post. Is this the battery you were referencing?
http://www.beiterbattery.com/Toyo3FM4.56V4.5ah-2.aspx
Ben Carufel
'02 BMW R1150GSA - '72 BMW R60/5
Recovering BMW Addict...
Ben Carufel is offline   Reply With Quote
Old 09-10-2014, 02:27 PM   #772
MacEntyre
MacEntyre's Avatar
Oddometer: 51
What's in a carb kit for R75/5 Bing 32mm type 64?
BMW wants $69 for a carb gasket kit, part# 13111258051.
I saw posts in this thread talking about getting O-rings from O'Reilly's and Harbor Freight. But how do you know what to get, if you have never torn one down before?
What's in the kit?
- MacEntyre, VIU lurker
airhead and thumper
'73 R75/5, '90 XT350
MacEntyre is offline   Reply With Quote
Old 09-10-2014, 02:32 PM   #773
Zebedee
Zebedee's Avatar
Oddometer: 833
What's in the kit?
You can probably go straight to Bing for the genuine parts, or motoworks/motobins in the UK is you're happy to go with pattern parts ... hth
John
Old 09-10-2014, 02:43 PM   #774
MacEntyre
MacEntyre's Avatar
Oddometer: 51
Found what's in the kit here. Looks like it is probably worth it for the diaphrams. I'll check with Bing after I get my numbers. Thanks!
airhead and thumper
Old 09-10-2014, 06:01 PM   #775
Ben Carufel
Boxer Addict
Oddometer: 737
I just used this kit last week. You'll also need 4x throttle shaft screws, vacuum port fiber washers (1 per side), and you might want to replace at least the floats ($20ish/each from BMW) as well as the float needles ($8-10ish each from BMW).
Ben Carufel
Old 09-10-2014, 06:54 PM   #776
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,926
The secret may surprise you! Bing carb parts are usually cheaper at your BMW dealer. Same parts sold by Bing, for less.
EDIT; I guess I should add that this is the case generally in the US of A. Also might add that carb parts from dealers may only be in stock at Airhead friendly dealers.
---Albert Einstein
disston screwed with this post 09-10-2014 at 07:06 PM
Old 09-10-2014, 07:02 PM   #777
Zebedee
Zebedee's Avatar
Oddometer: 833
I can't comment on Bing vs dealer pricing in the US of A, but it's *MUCH* cheaper for me to have parts shipped half way round the planet from the UK, rather than consider sourcing them locally ...
[edit] ... but you live and learn ... [\edit]
John
Old 09-11-2014, 09:19 AM   #778
garthg
garthg's Avatar
Oddometer: 392
If you pull the throttle shafts, the screws have to be properly staked in place. A throttle screw sucked into the engine can destroy the engine.
Personally, I'd leave the throttle shafts alone. I've had good experience just rebuilding the carb with the kit shown, minus the diaphragms. The diaphragms alone are about half the cost of the kit. If the old ones don't have any tears or rips, they should still be usable.
"The motorcyle is a constant challenge to the man; a challenge to experience the adventure of man's command over the machine--directly, unadulterated. Over and over again, wind, weather and road must be conquered and mastered anew.
For this, the machine--"
garthg is offline   Reply With Quote
Old 09-11-2014, 02:14 PM   #779
MacEntyre
MacEntyre's Avatar
Oddometer: 51
...you might want to replace at least the floats ...as well as the float needles...
I changed my mind and bought the full rebuild kit and the rebuild manual from Bing. Figured I don't want to do this again for many years!
Only alcohol free fuel for my airhead from now on!
airhead and thumper
Old 11-08-2014, 12:40 PM   #780
sayonora
doesnt like airplans
Oddometer: 52
found this for sale at burton bike bits: dual cable wassel throttle tube, might be usefull for cafe bike or anyone else who wants.
http://britishbikebits.com/clearance...l#.VF5_MoelD-k
You're never lost if you don't know where you are.
sayonora is online now   Reply With Quote
Times are GMT -7.   It's 03:23 AM.
