Old 12-07-2007, 10:43 AM   #91
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,669
Saftey wire
Originally Posted by tvrla
My concern using a silicone pan gasket is the bolts falling out. There's no way the bolt will bind in the hole with the gasket being soft and squishy. Do you use loctite? Those suckers fall out easy enough with the stock hard one.
You could always spend several hours drilling the bolt heads and saftey wiring them! Or not.
I've replaced exactly one oil pan gasket. I generally just grease them before assembly. I don't have any leaks, and the gasket parts gracefully if of some silly reason I need to drop the pan. The one I had to replace was glued to the pan by a DPO.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 12-26-2007, 07:16 AM   #92
Gasket
Wandering Samurai
Oddometer: 195
Excellent string gentlemen....Some great information here.
Since 1983 I have purchased parts for my vintage Brit bikes from Domiracer but they have added airhead to their inventory. I just purchased a "aftermarket" set of stock handlebars for my R90/6. Made in Taiwan but of excellent quality and a perfect fit...They have several other styles.
www.domiracer.com
Mike
Pacific Northwest
2007 Triumph Rocket III Classic Tourer
1967 Triumph TR6C
Gasket is offline   Reply With Quote
Old 12-27-2007, 02:52 AM   #93
DucatiPete
In denial
DucatiPete's Avatar
Oddometer: 162
Thumb Hell Effect sensor
For those who've got/get a fried sender I just discovered our local electronics parts store (Jaycar) has spitting-image replacements for $AU20!
Sure beats paying through the nose at a dealer for a replacement unit... the best price i could find for a reco unit was $AU110.
From what I can see the sender is the only thing that can fail...
I'm still waiting to test mine: when i pulled it apart it looked like it'd been assembled in a sand storm!
DucatiPete is offline   Reply With Quote
Old 01-05-2008, 09:59 PM   #94
Tim McKittrick
Oddometer: 1,446
non OEM air filter replacement
Does anyone know if there is a non-OEM air filter out there that'll fit a /5? Has anyone been able to determine if any of the thousand or so filters available from Fram and the like are similar enough to the stocker to work?
I'm looking for a replacement which I don't have to mail order or get from a BMW dealer, if that's possible.
Tim McKittrick is offline   Reply With Quote
Old 01-06-2008, 01:42 AM   #95
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,239
Here's where I sourced one when I needed a replacement. Around AU$20 indeed. http://content.honeywell.com/sensing...log/c20050.pdf
On a trip around the world.... details here: www.nohorizons.net
Malindi is offline   Reply With Quote
Old 02-04-2008, 08:38 PM   #96
DucatiPete
In denial
DucatiPete's Avatar
Oddometer: 162
starter relays: stop the ripoff
The starter relay on my r80g/s started not working... and the outer cover would come off when i pulled it from it's socket.
Time for a new one, said i...
Quick call to local BM shop $AU84! What the... are those spades platinum! BM wreckers: $45
There's no way I'm gonna splash that sort of payola for a simple relay.
Well, of course, it's not just a "simple" relay. Turns out that BMW wanted a diode in it so you had to get that specific ($BIG$) one. Bugger that!
Why can;'t the diode be wired externally?
Well, as it turns out, it can.
I bought a basic Bosch four pin 30amp relay, a relay socket, a few spade connectors, and 12v5w diode. Wired 'em up - as per the diagram on the old relay - and Bob's yer uncle...
All components from local electronics store (Jaycar).
Cost: Relay $4.50, Socket $3.80, Diode $4.80 (had to buy 4), spade connectors $~1.20.
Total: $14.30
And if i ever need another relay i can get one at any car parts joint.
Another small victory for the little guy.
2002 1150GSA (non-ABS) - 21st C Highway Adventures
1982 R100RS - new rolling project
1980 R80G/S - gearbox still needs attention + & etc
1973 R75/5 - Black Beauty - love @ 1st ride
1972 Ducati Sport - must look at the 'ol girl again soon
Old 03-15-2008, 04:28 PM   #97
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 1,998
Send a message via Yahoo to StephenB Send a message via Skype™ to StephenB
Alternative Piston Rings
Motorworks sent me Goetze pistons rings, P/N 08-700900-00 for std bore '77 1000cc barrels (iron lined). Goetze is a trademark of Federal Mogul Corp. This complements Lornce's information on his Volkswagen cast rings, I believe.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 03-16-2008, 07:15 AM   #98
Hi Viz Guy
www.hivizstore.com
Hi Viz Guy's Avatar
Oddometer: 278
Send a message via Skype™ to Hi Viz Guy
Murph's For My R100 GS
Just picked up my first BMW, a 91 R100 GS. I currently own a concours and a klr. For the concours i go to murph's and for the klr i go to happy trails for all of my goodies.
My question is this... is there a go-to place for farkles for my bumblebee?
What i am searching for is oil filters, blank keys, and the possibility of putting a givi box on my back.
Where shall i search for the holy grail of GS Parts?
03 klr 650, 91 R100 GS Bumblebee, 74 Jawa Californian, 85 K100 Hi Viz Machine, 81 CM 250C
www.hivizguy.com
Hi Viz Guy is offline   Reply With Quote
Old 03-27-2008, 09:13 AM   #99
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,847
Rocker Arm Needle Bearings
EDIT: I HAVE A PROBLEM WITH THESE. STAND BY FOR FURTHER info.
I screwed up an OD measurement, apparently. Its 20, not 21.
crapola.
What to do... What to do...
Stagehand screwed with this post 03-29-2008 at 09:10 AM
Stagehand is online now   Reply With Quote
Old 03-28-2008, 04:27 AM   #100
Beemerboff
Oddometer: 2,051
Thanks for that. The first supplier I called wanted $22.65 for one or $16- each if I wanted eight. Special order , 3/4 weeks . Bummer.
Second supplier , $A3.97 each, in stock. Yes!! I picked them up straight away , and got a neeedle roller small end for my B44 at the same time for $6.20 , against $36- for the bronze bush plus reaming, if I could find someone with a jig to do it insitu.
Now I just got to find someone in Oz with a six piston caliper who wants less than $250.00 for it------
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 03-28-2008, 04:50 AM   #101
johno
johno's Avatar
Oddometer: 2,893
Beemerboff, what brake setup do you currently have?
Do you think the 6 is an overkill?
I have the 4 spot on my GSPD with braided line, and it is certainly better than stock.
I am going to look at a bigger disc, rather than the 6 spot.
I wish the rear was easy to upgrade.
I will let you know how my shaft job goes, and the price, when it is finished.
johno is offline   Reply With Quote
Old 03-28-2008, 06:27 AM   #102
Beemerboff
Oddometer: 2,051
At present I have the stock set up with a braided line and DP 620 GG sintered pads , which I bought on Ebay for $20-
They were advertised as HH but it says GG on the pad.
No problem , they are a mile in front of the Galfer Greens , and they were supposed to be GG too.
With this set up I can lock the front wheel with a good hard squeeze , and I dont really need much more, but when Guy announced his sensibly priced adapter for big callipers I thought I would upgrade a little, and get up to date two finger braking at a reasonable cost.
Last time I was in Churchill Dismantles all the callipers were $25.00 but they now have a new sales manager and he is as stupid as the guys at Show and Go - $250- for one second hand calliper , with no pads or hose.
The reason for going with the Tokico six piston is to keep the M/C - caliper ratio as close to stock as possible , as IMHO this is the critical part of the exercise.
If Ray Potter was still working I could have got my M.C. sleeved to 11 or 12 mm which would have made the two piston viable , but with a 13mm MC the Tokico six piston is the only one I would fit
I have a 11mm on my twin disc R75/7 and it works really well , no problems with excessive pull etc so I have no problems with high ratios.
Old 03-28-2008, 07:29 AM   #103
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,970
Good stuff here Boffo,
Hydraulic ratios are seldom understood by folks switching bits and pieces around. I'm a bit confused by some of what you've suggested re. keeping piston ratios as close to stock as possible. As you won't realise any braking improvement until you increase your master cylinder vs. slave cylinder piston ratios. ie: reduce the m/c swept area or increse the slave cyls swept area. You seem to be aware of this when mentioning your intention to sleeve your MC down to 11 or 12mm. Did I miss something?
I've got a 4-pot Brembo from my wrecked 1150GS doing duty on my GS/PD and it's provides a noticable improvement over the stock two pot Brembo. Easy to fit, too, simply required filing a bit off the caliper's boss to centre it on the GS/PD's disc (0.125" iirc). Currently running whatever the 1150 was using for pads, which I believe were stock BMW bits.
Having said all that, with the stock set up I could howl the front tire at any speed the bike was capable of if I gripped it tightly enough. All you're doing with a fancier brake is easing the effort it takes to howl the tire - so you're not actually getting any greater ultimate breaking force.
The tire's the final factor in the braking force equation, as I'm sure you know.
fwiw,
Lornce
Old 03-30-2008, 08:43 PM   #104
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
Revisions added.
Waiting on Stagehand to get his data straight.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 05-02-2008, 08:38 PM   #105
tathambenjamin
tathambenjamin's Avatar
Oddometer: 563
Question 2 into 1 exhaust ?'s
So... I have been searching and Searching for information about 2 into 1 exhaust to fit on a '78 R100/7. I found the MAC setup onine, but am interested in the luftmeister or other custom options....
Does anyone have any links or information about how these improve performance and where I can buy them? Also, anyone out there whu runs one of these 2 into 1 set ups? Do you need to rejet? any other changes to make or consider?
Any information would be appreciated, my endless google searching has produced nothin....of course if anyone has one for sale I would be happy to hear about it too.
tathambenjamin is offline   Reply With Quote
Times are GMT -7.   It's 08:06 AM.
