Old 03-05-2007, 06:37 PM   #1
ednorton OP
Oddometer: 80
Garage lighting
I'd like to take a step beyond hanging ballast and tube, any sugestions for surface mount lighting systems.
LTR
ednorton is offline   Reply With Quote
Old 03-05-2007, 06:59 PM   #2
Canukwaco
I stole this avitar
Canukwaco's Avatar
Oddometer: 131
Send a message via ICQ to Canukwaco Send a message via AIM to Canukwaco Send a message via Skype™ to Canukwaco
I wouldn't toss out the ballast and tube idea....have you looked at electronic ballast with E8 bulbs?
www.lansharx.com
2002 BMW R1150GSA
1992 Mini Cooper (Rover) 1300 RHD
1999 Toyota 4Runner Highlander
Canukwaco is offline   Reply With Quote
Old 03-05-2007, 08:00 PM   #3
chain
chain's Avatar
Oddometer: 4,753
good call on the eballast w/e8's . are you looking for something that looks better, lights better or both. directional task lighting, general lighting? I come across alot of cool lighting doing demo on retail projects, might be able to help you out. drop me a pm.
chain is offline   Reply With Quote
Old 03-05-2007, 08:39 PM   #4
Apxgrndr
In the snow
Apxgrndr's Avatar
Oddometer: 707
lighting
Fluorescent lighting mounted high on the wall as well as on the ceiling works great.
You're stronger than you think.
Apxgrndr is offline   Reply With Quote
Old 03-05-2007, 11:50 PM   #5
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 13,492
If you're into tweako try getting color corrected lamps. Standard cool white lamps suck for proper color balance. It's amazing what happens with really good lighting.
JJ
QUOTE from vermin
I lie to myself because I am the only one who continues to believe me.
johnjen is online now   Reply With Quote
Old 03-06-2007, 06:48 AM   #6
porterdog
untitled
Oddometer: 251
I don't know anything about lighting but I do need more light in the garage.
Can you point me at what you're talking about?
porterdog is offline   Reply With Quote
Old 03-06-2007, 07:18 AM   #7
SpeedStar
XT1200Z and DL650
SpeedStar's Avatar
Oddometer: 528
I have some questions about ballasts for fluorescent fixtures.
I have two six foot twin bulb lights in my garage. I have replaced the fixtures once already. I bought the regular ones sold at Home Depot for about $50 each.
One just died on me recently. It was always loud when on.
My question is should I replace just the ballast or go with the whole fixture and just replace with a similar one?
Do these usually only last a few years with normal use?
Thanks.
FS: XT1200Z Super Tenere Gas Tank Side Panel Guards, Rear Tank Guards, Fork Tube Guards, Headlight Masks and Exhuast Shield Masks
http://advrider.com/forums/showthread.php?t=714789
FS: V-Strom Frame guards, triple-clamp guards and THE ORIGINAL Headlight Masks
http://www.advrider.com/forums/showthread.php?t=356383
SpeedStar is offline   Reply With Quote
Old 03-06-2007, 06:05 PM   #8
Canukwaco
I stole this avitar
Canukwaco's Avatar
Oddometer: 131
I use the T8s in my business. You can see them at Home Depot or Lowes. Sorry about the typo in my earlier post I meant T8 not E8....anyways. I am not sure what you are looking for but here is my .02: I am presuming you don't like them because the hum and sometimes they just won't come on! I mentioned the T8 because they are instant on and have no hum. (not to mention they last MUCH longer than a standard fluorescent)
Here is a link:
http://www.lowes.com/lowes/lkn?actio...0AE&lpage=none
If you want to learn more just google T8 and Electronic ballast. Good luck!!
www.lansharx.com
2002 BMW R1150GSA
Old 03-07-2007, 08:06 AM   #9
Pete™
Published.
Pete™'s Avatar
Oddometer: 9,333
has anyone done anything with the portable halogen work lights? I saw some at costco awhile back and it got me to thinkin....
Pete™ is offline   Reply With Quote
Old 03-07-2007, 08:24 AM   #10
Canukwaco
I stole this avitar
Canukwaco's Avatar
Oddometer: 131
You have to be careful with halogen...it gets REALLY hot!
You can just buy some cheap track lighting made for halogen.....you would spend about 30-40 bucks and you can adjust them!
www.lansharx.com
2002 BMW R1150GSA
Old 03-07-2007, 09:03 AM   #11
pecos
BAM!!
pecos's Avatar
Oddometer: 466
I believe what Waco has is that I have. Just make sure you do not get ones that buzz in cold weather. It will drive you nuts when you are working on your bikes.
pecos is online now   Reply With Quote
Old 03-07-2007, 10:15 AM   #12
Boatman
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,399
When I built my shop I was on a budget and ended up going with the "standard" 8' flourescent fixtures. The noise drives me fickin' crazy sometimes. What I found out was these fixtures are industrial rated (high noise) and had I spent a little more on the T8's they would be quieter. This summer I plan on switching them over.
Also there was a ggod tip on the color corrected bulbs. A little pricey but worth it if you plan doing any type of finish work.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 03-07-2007, 11:13 AM   #13
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,582
Send a message via Yahoo to Ricardo Kuhn
you can always try something like this(I have tread somewre but I can not find it)
ussing old wasted camara tripods
fully adjustable, you can even diffuse the light inwards into the corner of the wall, or directed anywere you want in to the ceailing a wal or directlly into the work space.
cost ...
pretty much nothing to make, Damage tripods from fleamarkets and salvation army, the light come from the stupid "light towers", that everybody used to have at their houses and you find them on the street all the time (were I live at least),plus a few wood screws and cable tyes..
the cost of operation is kind of high if you use the stock 500Watt bults, I use 300W and is plenty
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Old 03-07-2007, 12:02 PM   #14
FixxiT
Lunitic Fringe
FixxiT's Avatar
Oddometer: 774
I use T5 fluorescent fixtures here...no flicker...no hum...54W light output from a tube thats 15mm in diameter!
20,000 hr lamp life, 90% maintained light output, electronic ballast.
(I think the T8 lamps 32W...I need more light for MY old peepers)
Survivor
CC04*CC05*CC09*CC10*CC11
EC10 EC12
FixxiT is offline   Reply With Quote
Old 03-07-2007, 12:45 PM   #15
ReCycled
ReCycled's Avatar
Oddometer: 373
T8's are a great choice. Quiet, cold weather starting, longer lasting, and brighter than the old style T12's. There are some easily available bulb options now too. Generally, the higher the temperature of the gas, the brighter, whiter the light output. Try a couple of different kinds, you may find a preference.
ReCycled is offline   Reply With Quote
Times are GMT -7.   It's 06:50 PM.
