Old 03-24-2011, 08:37 AM   #1891
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,364
Originally Posted by larryboy View Post
You've got to run miles and miles and miles of wire before it wears out. If it feeds and welds, leave it alone...it ain't broke.
My thoughts exactly.
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is offline   Reply With Quote
Old 03-24-2011, 08:50 AM   #1892
bobivey
Oddometer: 39
Don't recall ever seeing one that "wore out". Usually they get kinked or plugged up. We would blow them out with compressed air every time we changed a spool of wire and replace them every 10 spools. Of course this was a dirty shop and we would go through 10 spools in a week.
Bob
bobivey is offline   Reply With Quote
Old 03-24-2011, 02:50 PM   #1893
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,538
I have some kind of wiper on the wire between the roll and the feeder. It keeps crap out of the liner. It works. Keep the liner as a spare, when you need you will know it.
David :)
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 03-24-2011, 03:30 PM   #1894
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,436
Nomad Welding Table from Stronghand Tools
Got one of these? Pros and Cons? Flimsy?
From
http://www.weldingtipsandtricks.com/portable-welding-table.html
Factors to consider for alternatives:
A plate 24" x 48" x 1/4" is about 80 pounds.
http://store.cyberweld.com/webehabe300.html
Cyberweld also sells a connector plate
http://store.cyberweld.com/sthanowetaco.html
According to:
http://www.stronghandtools.com/pdf/welding_table_2007.pdf
TS3020
Table Height Range 26” - 32”, Tabletop Size 30” W x 20” L, Slots in Tabletop 1.1”
Table Positions Horizontal, 30, Folded, Weight 44 lbs, Load Capacity 350 lbs.
Review: http://www.carcraft.com/techarticles/ccrp_1105_nomad_economy_welding_table/index.html
George
"Honeste vivere, alterum non laedere, suum cuique tribuere"
Plug and Plug.
Old_Lion screwed with this post 03-25-2011 at 10:18 AM
Old_Lion is offline   Reply With Quote
Old 03-24-2011, 03:51 PM   #1895
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,436
Originally Posted by David R View Post
I have some kind of wiper on the wire between the roll and the feeder. It keeps crap out of the liner. It works. Keep the liner as a spare, when you need you will know it. David :)
Somewhere I read that one can take a foam earplug, poke a hole in it and run the wire through it.
George
http://www.articlesbase.com/tutoring-articles/mig-welding-gun-the-number-one-cause-of-swearing-and-cursing-when-mig-welding-2626818.html
Plug and Plug.
Old_Lion screwed with this post 03-24-2011 at 04:19 PM
Old 03-24-2011, 10:51 PM   #1896
Carl
Carl's Avatar
Oddometer: 768
George
I've used one extensively for going on two years. It works fine as a light duty table. It has its pluses and minuses. The pluses are its many features. The minuses are it is not robust enough for 'serious' welding projects.
I definitely got my payback on it for what it cost. It takes some time and money to make a really decent welding table in the footprint size of the Nomad. These units appear to be very user-friendly: http://www.millerwelds.com/products/...ns/arcstation/ Though they are a bit pricey.
Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 03-25-2011, 05:54 AM   #1897
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,436
How much money is the Miller Arcstation?
I definitely got my payback on it for what it cost. It takes some time and money to make a really decent welding table in the footprint size of the Nomad. These units appear to be very user-friendly: http://www.millerwelds.com/products/...ns/arcstation/ Though they are a bit pricey. Carl
http://www.millerwelds.com/products/workstations/arcstation/#tabs-why-f-series
On YouTube
http://www.youtube.com/watch?v=FAu_bE-qDkI&feature=player_embedded
Features
X-pattern tabletop on FX models makes clamping trouble-free.
1 1/2-in diameter steel tube frame offers stability and support.
Wheels and a handle make the 74-lb bench easy to transport.
Removable gun holder provides a convenient place to store your welding gun.
Weight capacity is 500 lb (227 kg).
30 x 30 inch work surface with 3/16-in X-pattern.
$235.00 at Cyberweld
http://store.cyberweld.com/miar30weta30.html
same price at Amazon by Cyberweld (free shipping)
Wondering how much it weighs? 74 lbs
http://www.millerwelds.com/products/workstations/arcstation/pdfs/arcstation_brochure.pdf
Rebate: http://www.millerwelds.com/arcstationcontest/pdfs/arcstation_rebate.pdf
George
Plug and Plug.
Old_Lion screwed with this post 03-25-2011 at 11:12 AM
Old 03-25-2011, 06:12 AM   #1898
Carl
Carl's Avatar
Oddometer: 768
Once again, the Nomad has some nice features for a small footprint table. Its main negative is being very light duty. It also has one major drawback as a TIG table in that its legs lower crossbar prevents the ability to have your foot pedal in a convenient spot.
The Miller arcstation 'F' series for a $100 in more in cost appears to be far more robust. The weight difference between the Nomad And Miller 'F' series table makes the Miller the clear winner in some aspects.
Carl
Old 03-25-2011, 08:22 AM   #1899
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,097
Since you have a welder why not make one?
The portable tables are nice but their payloads are not very good.
We use tables with a 1/4 inch thick flat top with female pipe nipples welded to the bottom so you can screw in threaded pipe legs. If you want you can thread pipe caps to the bottom of each pipe leg so they don't get mud and dirt in the hollows of the pipe.That way you can screw the four legs in and out for easy dissasembly and its still good for heavy weldments.
A very easy project.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 03-26-2011, 11:02 AM   #1900
side-wayz
See Ya in the twisties
side-wayz's Avatar
Oddometer: 151
Just found this thread, cool, I'm about to finish welding school at Lanier Tech. I have a question, where's a good place to find a job around Atlanta in the next 3 or four months?
Oh, and I agree, those tables are nice, but we have welders, let's build one!
Side-Wayz
'00 KLR
side-wayz is offline   Reply With Quote
Old 03-26-2011, 01:00 PM   #1901
Old_Lion
Crotchety Biker
Old_Lion's Avatar
Oddometer: 3,436
welder search on Atlanta Craigslist
http://atlanta.craigslist.org/search/?areaID=14&subAreaID=&query=welder&catAbb=jjj
other lists in Georgia
http://geo.craigslist.org/iso/us/ga
George
Plug and Plug.
Old 03-26-2011, 08:02 PM   #1902
side-wayz
side-wayz's Avatar
Oddometer: 151
Thanks.
Side-Wayz
'00 KLR
Old 03-27-2011, 11:08 AM   #1903
Carl
Carl's Avatar
Oddometer: 768
well...
...The small 'off-the-shelf' tables fit the ticket in many applications. As I clearly stated they are light-duty in certain applications. Some of them have features that are very convenient, and generally will not be in any 'custom' self-built unit.
Making a 'custom' can be very straight-forward at times. The issue is most likely you'll spend a very decent amount of time sourcing what you need to build it, and then time to complete it. Plus, unless you have a decent source for material it will cost a bundle for that monster steel top plate.
If you expect to to do some 'serious' welding/fabricating then a custom table might be the ticket. If you want to get up and going ASAP the 'off-the-shelf' tables can make that happen.
Carl
Old 03-28-2011, 10:20 PM   #1904
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,045
Ok
I have some experience in Acetylene torches as well as arc welding. I am curious as to what is the best all around form of welding for my small shop. I will be doing, motorcycles, tube fabrication, misc trailer fixes etc
Hell I've been thrown into better places and got friends I ain't even used yet.
Hug those you love often And turn life up !!!
I really like what your are trying to do. I'm just not sure about how you are trying to do it. It's been a pressure working with you and the pleasure was all yours. If you need me I'll call ya..
TourPros is offline   Reply With Quote
Old 03-29-2011, 03:52 AM   #1905
802mike
802mike's Avatar
Oddometer: 437
Cadmium
Is cadmium still used in tools and hardware such as car components?
mike
802mike is offline   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
