Old 06-29-2007, 10:31 PM   #166
gweaver
Wandering between rooms
gweaver's Avatar
Oddometer: 1,597
I was surfing around looking for gear possibilities, and noticed that on the Firstgear website, there's a KTM in the background of the Denali Jacket page. Anyone have any idea what screen is mounted? From the looks of it, it's tall enough to deflect most of the wind, and it appears to have some sort of ducting just above the speedo cluster. Does this screen look familiar to anyone? Any experiences?
G
gweaver is offline   Reply With Quote
Old 06-29-2007, 10:36 PM   #167
idahoskiguy
idahoskiguy's Avatar
Oddometer: 1,126
The windshield in the picture looks like a Cee-Bailey KTM#!. Cee-Bailey has two model for the 950, one covers the headlight with flowing lines the other has a cut out for the headlight and is more anglular.
idahoskiguy is offline   Reply With Quote
Old 06-30-2007, 10:32 AM   #168
Doug Matson
Doug Matson's Avatar
Oddometer: 1,937
Thats the biggest screen that C/B makes. Whip has one on his bike and he just got done with a 4K trip last month, I am sure he could give you some good input on it.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 06-30-2007, 06:42 PM   #169
gweaver
gweaver's Avatar
Oddometer: 1,597
Thanks guys!
So then...paging Whip to the white phone. Whip to the white phone, please!
G
Old 06-30-2007, 09:45 PM   #170
KDCanyonRanch
Twist it, twist it!
KDCanyonRanch's Avatar
Oddometer: 216
another simple idea
I drilled four corner holes with a 1/16" drill bit, used a dremel with a cut off wheel to cut the naca duct, leaving the bottom attached. Heated slightly and pushed the duct in 1/2" and finished with some fine sand paper on the edge, works great and looks pretty factory. Picture is rough but gives you the idea.
KDCanyonRanch is offline   Reply With Quote
Old 07-01-2007, 03:58 PM   #171
gweaver
gweaver's Avatar
Oddometer: 1,597
That looks good. A pretty clean mod and it does look factory, like you said. Maybe I'll give that a whirl first- I like the cash-free option. If that doesn't do it, I'll start exploring other options.
G
Old 07-06-2007, 01:50 PM   #172
spiwirider
spiwirider's Avatar
Oddometer: 30
had a go at this tonight
i took ricardos design and had a go the only real difference is that i also added another spacer on the bottom of the screen so i could slide a little something extra in. so instead of just two spacers there are 4 i had a piece of mesh lying around and i had seen the headlight protector on the touratech site and though i could get the best of both worlds
thaks ricky for the initial design without that i wouldnt of dreamed of the exta bit
if you cant be a good example be a terrible warning ...
spiwirider screwed with this post 07-06-2007 at 02:58 PM
spiwirider is offline   Reply With Quote
Old 07-06-2007, 02:01 PM   #173
spiwirider
spiwirider's Avatar
Oddometer: 30
still got to trim it down to size and finish attaching it to the 2nd screen
late.. need beer
Old 07-06-2007, 02:04 PM   #174
spiwirider
spiwirider's Avatar
Oddometer: 30
more
Old 07-06-2007, 02:06 PM   #175
spiwirider
spiwirider's Avatar
Oddometer: 30
more
Old 07-06-2007, 02:08 PM   #176
4bikes
Oddometer: 226
I have one of those, and for highway use it sutes me far better than the original KTM. Even with my pretty high Renazco seat (I'm pretty happy with that....!) there's no problem getting out of the wind, and most of the turbulens, if I need to.
Jens
4bikes is offline   Reply With Quote
Old 07-07-2007, 05:45 AM   #177
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,614
Originally Posted by spiwirider
more
But does it work ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-08-2007, 09:52 AM   #178
spiwirider
spiwirider's Avatar
Oddometer: 30
imvho yes it does!!!
Originally Posted by DockingPilot
But does it work ?
i tested it today and no real buffeting until 90-95 mph its not 100% perfect but with my arai tour x ( or xd in the us) it was a huge improvement and i got a headlight protector at the same time !!
just some painting to do and it will be done i think its gonna work ok no movement from the screen at speed and my ears are not ringing after 2 hours of riding (no plugs) ..
all pretty simple really and im pretty stoked with the results
cheers
Old 07-08-2007, 09:54 AM   #179
spiwirider
spiwirider's Avatar
Oddometer: 30
more
Old 07-08-2007, 09:59 AM   #180
spiwirider
spiwirider's Avatar
Oddometer: 30
more2
Times are GMT -7.   It's 09:20 PM.
