Old 03-19-2007, 08:21 PM   #91
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,017
Hearing loss!
Me too on the hearing loss thing but that I can handle, Its the ringing in my ears 24/7 that is really annoying. Wear hearing protection always but still find the wind roar from the 950 screen hard to take for any length of time.
Fine if I stay under 60mph but who can do that on this brusier.
RED CAT is offline   Reply With Quote
Old 03-19-2007, 09:59 PM   #92
scottr OP
scottr's Avatar
Location: Pedernales R., Tx Hill Country (Ihadthisavatar1st)
Oddometer: 1,768
Take it off. Take it all off. Ride nakid.
scottr is offline   Reply With Quote
Old 03-31-2007, 07:19 AM   #93
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,017
Wind Noise!
OK, as Scottr said, "take it off". Wow, silence is golden. What does a stock 950 wind screen cost? I definitly want to to cut down my stocker. A little worried about long trips though. Short is quiet but push back is annoying at speed. Might be worth it though. Did it on my Tiger awhile back with poor results but realize now that I didn't cut it down enough. Any ideas on how much to take off for a 6 foot guy for optimum performance, that is, just enough air flow to keep just my head in the breeze? Guess I'll experiment today. Thanks for the tip.
Old 03-31-2007, 07:59 AM   #94
codys
Lost in the Vizcaino
codys's Avatar
Oddometer: 1,261
THe windscreens are cheap for windscreens. I paid 45 dollars shipped from www.elitektm.com . As far as how much to chop, I dunno. Take a inch off at a time till it works for you. I'm sure someone will chime in.
05 ktm 950 adventure
11 Husqvarna TE630
codys is offline   Reply With Quote
Old 03-31-2007, 11:39 AM   #95
Karl-KTM
Oddometer: 34
Had prolem with turbulence and the std windscreen, I'm 6'1"...
I cut away about 4" off and found this to be okay to me.
I use Arai or AXO cross helmet depending of the season.Name:  990S plexi 002.jpg
Karl-KTM is offline   Reply With Quote
Old 03-31-2007, 11:40 AM   #96
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,017
4"
Cut off 4 inches this morning and took a spin. Quieter but not as good as no screen. Little more wind about the shoulders. Too cool today for a good ride. Will try that for awhile and maybe try another 2 inches. My dealer quoted me $85. for a new screen. Also have the Touratech 3 inch extender to play with.
Old 03-31-2007, 12:02 PM   #97
codys
codys's Avatar
Oddometer: 1,261
I use Arai or AXO cross helmet depending of the season.Attachment 109685
Any more pics from side or front and farther away. Looks pretty clean what you did.
Here's the elite link but what's30- 40 bucks between dealers?
http://216.165.193.20/elitektm/ , select 03, fairing pieces and it's number one on the list.
11 Husqvarna TE630
Old 04-01-2007, 01:51 PM   #98
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,493
Originally Posted by fnckr
Not to go against the common wisdom but the NACA ducts at the front don't seem to be real NACA ducts. They're just a hole with an airstream redirecting wall.
Yes, technically true but but we're also dealing with one one of the most aerodynamically retarded forms of transportation there is. The 950 maybe more so than most.
Check out the Buell below. They have a ton of money in their wind tunnel testing and that duct is for high pressure intake - far more than just reducing the pressure behind the screen. You're not looking to do anything but reduce the pressure differential which will reduce the buffeting. While endless speculation is fun (and what the internet is built on after porn of course) I've done this and it works - 24,000 miles so far with an XD.
Gregor
sakurama is offline   Reply With Quote
Old 04-01-2007, 03:24 PM   #99
fnckr
Do you wanna play too?
fnckr's Avatar
Oddometer: 79
Gregor
Well, since I'm having no luck finding anything on the web that can be custom molded without too much technical knowledge I'm going to go with what's been proven on this board by you and others. I'll try it for a couple of weeks. Then maybe I'll try adding some holes on the side with a bit of flat plastic bonded behind. We'll see. Anything will be better I'm sure.
fnckr is offline   Reply With Quote
Old 04-01-2007, 04:44 PM   #100
Rock_93
Oddometer: 121
This is a little off topic but has anyone landed on the wind screen. I did now I'm thinking of cutting down my stock wind screen It might be easier on the ribs.
Rock_93 is offline   Reply With Quote
Old 04-01-2007, 05:52 PM   #101
East Coast
East Coast
East Coast's Avatar
Oddometer: 144
NACA ish Holes.
As a simpler mod I wonder would it work if I were to cut a few holes in the window with a hole saw, but not cut the lower 25% of the hole. This may act like a flap directing the air up / out..... or would this be a completly stupid idea. I have had completly stupid ideas in the past.
Life's too short to spend it complaining!
East Coast is offline   Reply With Quote
Old 04-01-2007, 09:13 PM   #102
rickf
oldfatguyMAN
rickf's Avatar
Oddometer: 1,695
NACA ducts
http://www.mckinneycorp.com/catalog/.../bodycomp.html
http://www.nimac.biz/
http://www.cscracing.com/page42.pdf
http://www.hrpworld.com/index.cfm?fo...ction=category
2005 KTM 525EXC, 2006 Triumph Sprint ST, etc., etc.
"Begin at the beginning and go on till you come to the end: then stop."
Originally Posted by rickf
Oh no, Robby's still a pendejo, but he's OUR pendejo!
rickf screwed with this post 04-01-2007 at 09:29 PM
rickf is offline   Reply With Quote
Old 04-02-2007, 04:48 AM   #103
fnckr
fnckr's Avatar
Oddometer: 79
rickf thanks for posting those. Yikes, those prices are higher than some of the similar things I came across. Maybe it's worth contacting them about doing something in plastic and specifically designed.
Old 04-02-2007, 08:28 AM   #104
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,671
This has been discussed endlessly for a few years. Try a search on NACA ducts. Or you can check my old post here or a page I put up on our site here.
Basically this is what you want to do:
This solves the problem.
Woopie, I've found my spring time project !!! Got the parts on order !!! Looks real nice too !!
2015 BMW R1200RT 600 miles
2003 Harley XL883 CAFE
1stiski is offline   Reply With Quote
Old 04-02-2007, 09:28 AM   #105
East Coast
East Coast
East Coast's Avatar
Oddometer: 144
90 deg air deflectors
What would one do with those deflectors cut it off and insert the round end flush with the window and the thin end as close to the inside of the window pointed up and out?
Looking at those cf air deflectors, why not put a 3" pvc plumbing elbow somewhere unobtrusive but into the wind in the lower fairing pointed up in the general direction of the windshield. Closer to the windshield would be better, but we still want to look profeshional.
Times are GMT -7.   It's 09:40 AM.
