Old 07-30-2012, 04:20 AM   #5146
Squily
Squily
Squily's Avatar
Oddometer: 1,224
Originally Posted by waalex View Post
So who has a press that can take off a steering head bearing and press the new one on? Or can anybody suggest a shop that would take on a small job like that?
As it so happens, Supacheap has a special that starts tomorrow where you can get a 6 ton workshop press fopr $99
Time to invest?
Squily
Squily is offline   Reply With Quote
Old 07-30-2012, 04:20 AM   #5147
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
Cold chisel
As you probably know - Out of the sterring head is straight forward (hammer and punch).
Off the shaft a block of wood to rest on, a hammer and cold chisel - that's how most shops do it
I was horrified first time I saw this (happening to mine), but it works - with a bit of care.
Of course a press would be nicer.
I need to re-pack or replace the steering head bearings on my Tenere (most likely replace, the way they feel at the moment). I am keen to do the job myself, but I don't have a press to get the old bearing off and the new bearing on. I have asked a couple of shops how much to just do the "pressing", but nobody will do it as apparently the MTA has advised they shouldn't take on part jobs. They are worried they will be held liable if I don't finish the job correctly...
Smugmug $5 discount coupon # 2ucrtCWwf7D7A
KTM Pilot is offline   Reply With Quote
Old 07-30-2012, 05:05 AM   #5148
bully1
bully1's Avatar
Oddometer: 4,611
Paves SPOT link http://spotwalla.com/tripViewer.php?...04fddd085bc0b9
Guzzimikes SPOT http://share.findmespot.com/shared/g...mCbnz6qW0UkXHI
didn't get Allords but he's travelling with Guzzi at the moment
Who else was going ???
'02 GSX 1400 outfit........lot's of grin factor
'11 Husky TE 630.......tyre shredder
'06 HUSKY TE610 x 2............ for the boys
'92 R100GSPD ( modified)...........slow and easy
bully1 is offline   Reply With Quote
Old 07-30-2012, 05:12 AM   #5149
vk6yjs
The answer is yes
vk6yjs's Avatar
Oddometer: 604
2nd that
I'm with Konrad. I have done the TTR with a hammer and "used" larger screwdriver. Just a bit of common sense and you won't damage anything. Just nibble at it round and round . Easy does it. Think about it.. Even if you did scratch the head tube you can file the nick out easy , It's the new bearings that count . Give it a go.
Cheers Jay
1995 Yamaha TTR250 OE (rebuilt and loving it .....Again)
2011 Zook DRZ400E (Deceased)
2013 Zook DRZ400E (New one arrived) Wish I could ride it properly.
vk6yjs screwed with this post 07-30-2012 at 05:59 AM Reason: Typo
vk6yjs is offline   Reply With Quote
Old 07-30-2012, 06:17 AM   #5150
waalex
waalex's Avatar
Oddometer: 156
Time to invest?
I like the way you're thinking Squily, I definitely think its time to invest.
I don't seem to get SCA catalogues at home, and I can't find one on the web. Is this the press that is going on special tomorrow?
http://www.supercheapauto.com.au/onl...67#Description
Alex
2010 Yamaha Tenere
waalex is offline   Reply With Quote
Old 07-30-2012, 06:21 AM   #5151
waalex
waalex's Avatar
Oddometer: 156
Thanks for the input. I am happy with getting the top bearing out of the steering head and getting the old bottom bearing off the shaft, it's mainly getting the new bottom bearing onto the shaft I am worried about. I am told you can tap it onto the shaft gently with a hammer, but I am concerned about damaging a new bearing (me/hammer/gentle don't belong in the same sentence).
I think I might check out the press that SCA have on special tomorrow.
Alex
2010 Yamaha Tenere
Old 07-30-2012, 06:24 AM   #5152
Squily
Squily
Squily's Avatar
Oddometer: 1,224
Yip, I think that be the same one. But I got my dates wrong- special starts 1 August (day after tomorrow)
Squily
Old 07-30-2012, 06:43 AM   #5153
waalex
waalex's Avatar
Oddometer: 156
Found a 20T press on Gumtree for $220
http://www.gumtree.com.au/s-ad/hamil...lic/1005023567
Or a brand new one on ebay for $200 plus delivery
http://www.ebay.com.au/itm/Workshop-...ht_3967wt_1165
I think the one on gumtree might be the same as the ebay one. I wonder what the quality is like on all of them, given they are probably cheap made in china stuff. But for the small amount I am likely to use it they would probably all do the job.
Alex
2010 Yamaha Tenere
Old 07-30-2012, 06:55 AM   #5154
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Steering Head Bearings
Hi Alex
I've just gone thru the process of removing my Africa Twin steering head bearings and upgrading them from ball & race to tapered.
If you're gunna buy a tool, buy a Dremel (if you don't already have one).
As you can see in the pic below, I tried 2 different methods of removing the bottom race. Firstly I tried the heat'n'cool process by welding a couple of snots on the race. No good. Then I got out the trusty Dremel with a worn down cutting disk (smaller radius). Very very carefully cut a nick into the race, stopping often to check my progress. When I thought the nick was deep enough, I got out the cold chisel. Two firm whacks and the race split easy. No worries if yours are tapered bearings, the same process works on tapered. There are clips on Youtube.
When it came to pressing the bottom tapered bearing on, I went to Bunnings and found a large washer with the same diameter as the steering stem. Stick the bearing in the freezer overnight. Next day, slide the bearing on the stem, then the large washer, then use a piece of pipe over the stem and gently tap the bearing into place. The washer protects the bearing. A gympie is better than a hammer.
I always seem to make the easy look hard when tinkering in the shed, but I surprised myself how well (easy) this job was. Currently doing all the bearings on the wheels... and getting the same easy result. I'm happy.
If you're not comfy having a crack at it yourself, bring it round home and I'll show ya. Put a pic of yours up here first though. Make sure you've got replacement seals too.
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 07-30-2012, 07:26 AM   #5155
Squily
Squily
Squily's Avatar
Oddometer: 1,224
Might be the way to go= it took two of us, an oxy-torch and a chisel to get my AT's bearings out. Wasn't pretty...
Back on was easier: heated the bearing in oil and gently tapped it on.
Squily
Old 07-30-2012, 07:42 AM   #5156
Dave Ward
Not enough riding...
Dave Ward's Avatar
Oddometer: 1,760
Stick the bearing in the freezer overnight. Next day, slide the bearing on the stem, then the large washer, then use a piece of pipe over the stem and gently tap the bearing into place. The washer protects the bearing. ]
With respect, this makes no sense. You would put the steering stem in the freezer (cooling shrinks) and heating the bearing (hot oil as Squily said) to make the job easier.
Cooling/shrinking the bearing would be counterproductive, no?
I usually find a piece of pipe/tube that will fit over the stem and bear only on the bearing inner, to drive the bearing on. Or, if it hasn't been cut in half , the inner part of the old bearing.
Dave.
F650 GS Dakar
Light travels faster than sound, which must be why when I meet some people they seem bright - until I hear them speak.
Dave Ward is offline   Reply With Quote
Old 07-30-2012, 05:57 PM   #5157
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Exactly my thoughts when I read about that tip elsewhere... and honestly, still doesn't make sense to me.
I tried a test fit before freezing and then after... there was a poofteenth difference in it. Anyway, it slid on easy with a couple of taps of the gympie (and the bearing suitably pre-greased), so I got on with other rebuild stuff instead of trying to figure out the merits/logic of frozen bearings or not.
And... all is not lost in cutting one cup in half. The clever m/c engineers give us clowns another one to use, courtesy of the upper bearing which is removed in tact. Aren't we lucky.
05 HP2
11 K1600GTL
Old 07-30-2012, 06:09 PM   #5158
oziexplorer
fugarewe tribe member
oziexplorer's Avatar
Oddometer: 1,170
Perth HP2 for sale
Hi Guys
my HP2 is now up for sale, check out the classifieds section
Cheers
Dave
0417 936 855
Cheers,
Dave
KTM 950sm
oziexplorer is offline   Reply With Quote
Old 07-31-2012, 12:58 AM   #5159
Paves
Beetrt/liver sausage
Paves's Avatar
Oddometer: 1,663
Think of it like this: When the bearing is heated the inner race expands and starts to fill the hole it surrounds. So in reverse, when the bearing is cooled the inner race contracts into itself and the hole in the centre gets bigger. See, I'm not just a pretty face
What's that you have in your eye?
Oohh! it's nothing but a sparkle
"All the freaky people make the beauty in the world" - Michael Franty. Weird, odd and proud of it
Paves is offline   Reply With Quote
Old 07-31-2012, 01:07 AM   #5160
Squily
Squily
Squily's Avatar
Oddometer: 1,224
Very funny Paves, but not sure it works like that. Sort of saying if you want to get rid of a hole, you need to cut it out cause it'll be removed...
As far as I know, you cool the shaft and heat the housing/bearing.
But lets see what the professionals say: http://www.lubsys.com/knowledge/knw_heatmnt.htm
Squily
Times are GMT -7.   It's 07:50 PM.
