Go Back   ADVrider > Riding > Mapping & Navigation
Old 12-04-2008, 04:18 PM   #1
husky123 OP
Oddometer: 1,454
60CSX and switching maps?
Please oh please gps gods tell me there is a better way.
My situation: I have City Select and Topo installed on my 60CSX. I have most of VA, MD, PA, WV, NJ and NC installed for both CS and Topo.
Question: Is there a faster way of switching from CS to Topo then going to map setup and unchecking EACH mapset 47000 times?!
Please someone give me the good news?
husky123 is offline   Reply With Quote
Old 12-04-2008, 04:33 PM   #2
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
There is a way ... if the map sets are set up ok (to do with the map authors .. not you)
Try .. when you get to the check boxes .. hit menu again and see what comes up - you want the screen with
Hide base map
Hide City Select
Hide topo
Hide all
It is around there some where. If it does not disply Ciy Select and Topo as 2 items then blame the map authors .. if the one you want has the lesser number of maps - select hide all then check the boxes of the ones you want to see... PIA but there is no other way...
Frank Warner is offline   Reply With Quote
Old 12-04-2008, 04:56 PM   #3
husky123 OP
Oddometer: 1,454
Frank, you sir are a genius. If I ever get down under I owe you a beer!
Old 12-04-2008, 11:00 PM   #4
mcnut
Oddometer: 1,384
Another Hint
Leave the Topo set to "Show" and only toggle the City Select between "Show" & "Hide". When CS is set to "Show" it will overwrite the Topo and then by switching CS to "Hide" Topo will be displayed. No need to toggle the TOPO which reduces the number of key strokes. Only down side to this is the overwrite process will slow the redraw somewhat.
Bruce
mcnut is offline   Reply With Quote
Old 12-05-2008, 01:52 AM   #5
easyriver
easyriver's Avatar
Oddometer: 82
With the price of memory sticks now you can get a 2mb very cheap. What I do is have different maps sets on different sticks. Very easy to change and 2 mb will hold a LOT of maps.
easyriver is offline   Reply With Quote
Old 12-05-2008, 05:52 AM   #6
husky123 OP
Oddometer: 1,454
Thanks mc and easy. Very good points.
Old 12-05-2008, 11:53 AM   #7
ZZR_Ron
Looking up
ZZR_Ron's Avatar
Oddometer: 8,186
I think you mean Gb, but otherwise good advice!
Great minds think alike;small minds seldom differ...
ZZR_Ron is offline   Reply With Quote
Old 12-06-2008, 02:09 AM   #8
Myway
Myway's Avatar
Oddometer: 3,241
Don't switch
Do this.
http://forums.groundspeak.com/GC/ind...owtopic=130439
http://www.gps-info.nl/handleiding9_uk.html
Myway is offline   Reply With Quote
Old 12-07-2008, 08:51 PM   #9
Countdown
Oddometer: 5,916
Originally Posted by mcnut
Leave the Topo set to "Show" and only toggle the City Select between "Show" & "Hide". Only down side to this is the overwrite process will slow the redraw somewhat. Bruce
"Somewhat" is an extreme understatement. I always leave Topo off because I almost never use it and it makes zooming in and out so slow it is useless.
Jerry Counts
Countdown is offline   Reply With Quote
Times are GMT -7.   It's 07:25 PM.
