Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 03-16-2007, 06:55 PM   #16
bitterjoe
killing the fatted calf
bitterjoe's Avatar
Oddometer: 2,050
I am doing something wrong. Total n00b to autorouting, please bear with me. I am using a Legend CX with CN8. A couple of things going on that I cannot understand.
I create a route in CN8, very basic, a start and finish point. It autoroutes on the PC perfectly. I upload it to the gps and it appears as a straight line when I view it. Why? Shouldn't it look the same as what is displayed on the PC?
I create a route on the gps using two already established uploaded waypoints for the start and finish of the same route; it displays as a straight line.
I create a route on the gps by placing two points from the start and finish and click navigate and it creates the route perfectly... all the way from my current location.
Shouldn't I be able to see just that route, not it being routed from my current position? Kind of like how a track is displayed (which is what I have used up until now).
Any pointers will be much appreciated.
2005 DR650, 2010 Triumph Scrambler
bitterjoe is offline
Old 03-16-2007, 07:45 PM   #17
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
When you select your route in your first two examples, are you actually hitting "navigate"?
Not sure about the eTrex Legend Cx, but the 60 and 76 will calculate the route every time you hit "navigate". Only the points transfer.
Mike S.
'09 Bonneville Black
AMA MSTA STOC
http://autos.groups.yahoo.com/group/...orcycleriders/
tbirdsp is online now
Old 03-16-2007, 08:07 PM   #18
bitterjoe
bitterjoe's Avatar
Oddometer: 2,050
Well, it looks like I can get it to route by hitting navigate in all three scenarios, but the problem remains is that it always navigates from my current location. Can't I get it to just show me the single route that was autorouted without having it start from my current position?
I guess what I really want is an autoroute to display just like a track. Can that be done?
Old 03-17-2007, 04:00 AM   #19
Vstromdek
Vstromdek
Vstromdek's Avatar
Oddometer: 141
Yep, you can view it only by just hitting the map option; but you can't route the route at that point, you must navigate to use it.
Vstromdek is offline
Old 03-17-2007, 06:47 AM   #20
bitterjoe
bitterjoe's Avatar
Oddometer: 2,050
I have found a workaround by converting the autoroutes to tracks using wingdb which will give me what I need.
I am still getting the same straight line and am curious if I have a setting wrong. I am including all the route calculation information when uploading the maps.
bitterjoe screwed with this post 03-17-2007 at 06:54 AM
Old 03-17-2007, 03:12 PM   #21
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
On a 60Cx - no- and sounds like your Legend is the same way. If you really want to view a route that doesn't start at your current location, you have to put it in "GPS off" mode and manually designate your route start waypoint as your new position.
Mike S.
AMA MSTA STOC
Old 04-19-2007, 10:58 AM   #22
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 73,600
Originally Posted by nomiles
*Bump*
because I'm a n00b to using my GPS and need to figure this stuff out.
Thanks cmwoodys and others.
+1
thanks for the info.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
2010 Latin America Route
Misery Goat is offline
Old 04-21-2007, 08:47 AM   #23
duckrider
duckrider's Avatar
Oddometer: 992
Thanks for posting this. I'm still near the bottom of the learning curve.
duckrider is offline
Old 04-22-2007, 05:29 AM   #24
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,129
This is a great thread. Thanks, cmwoodys!
I had no idea about the Google Earth thing. I just tried it, and it opens up Google Earth just fine, but my Mapsource route is not there. Browsed the MapSource help, but no joy there. Any idea what I am doing wrong?
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Emoto is offline
Old 04-22-2007, 06:45 AM   #25
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,129
Originally Posted by cmwoodys
Are you getting anything in ge? straight line?
I seem to be getting a very thin turqoise straight line.
Emoto is offline
Old 04-22-2007, 07:23 AM   #26
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,129
Yeah, the thing about GE is that it doesn't perform any routing. You have to set via points in Mapsource first and then transfer them over to GE. Once waypoints and vias are in GE, it'll draw that turquoise line from one to the other. Not an ideal application but its all there is currently.
Download the gpx file I attached to the first post and try it out. Its a loop of Deal's gap and the Cherohala parkway so theres LOTS of via points.
Thanks!!
If I grab and "rubber band" one of my routes, will that cause MapSource to add the via points necessary for GE to do its thing?
How do I transfer waypoints and via points to GE? Is that done automagically when I go VIEW>VIEW IN GE in MapSource, or is there more to it?
Emoto is offline
Old 04-22-2007, 03:21 PM   #27
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,129
On Mapsource the route is shown pink. click on it and it turns yellow, click on it again and it will rubber band to wherever you click place it. Vias and waypoints will be auto transferred to GE.
Fantastic. Thank you very much! Can't wait to try it.
Emoto is offline
Old 04-23-2007, 01:47 PM   #28
munchmeister
Grow'd Up Mini Trail
munchmeister's Avatar
Oddometer: 1,277
Thumb
Ditto, man. And I like your original example. That may be my ride plan to get to the Beehive Beemers Red Rock Rally in June.
Munchmeister
2002 R1150GS - It's not about the knockdown, it's about the recovery.
munchmeister is offline
Old 04-24-2007, 12:25 AM   #29
Dessert Storm
Dances With Drunks
Dessert Storm's Avatar
Oddometer: 722
Excellent tutorial - many blood pressure points saved! Your time taken to post this is much appreciated.
'You like motorcycles, beer, and ladies. I'm afraid I have the same illness' - Thierry.
Dessert Storm is offline
Old 04-24-2007, 08:18 AM   #30
duckrider
duckrider's Avatar
Oddometer: 992
Thanks for the tips guys, this will go a long ways in shortening the learning curve.
07 Ducati 1100 S Multistrada
07 Suzuki SV 650
05 Suzuki DL 650
01 Suzuki DRZ 440
00 KTM MXC/EXC 453
98 Ducati ST2
96 Ducati SS/SP
95 Ducati 900 Elefant
78 Ducati 900 SD Darma
Closed Thread
Times are GMT -7.   It's 06:36 PM.
