Old 07-30-2012, 03:27 AM   #4801
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,593
Originally Posted by Fixnfly View Post
I've been looking for someone to build a garage for me since my construction skills are not so great and I found a local contractor who specializes in garages. He is only offering a 1 year warranty on workmanship. Does anyone else think this is a little low?
I am a builder in Maine and I will tell you that if you have any issues with your garage they should appear within the first year.
Check his references and maybe have a look at a past job of his..
Garages are really very simple for a competent builder.
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is online now   Reply With Quote
Old 07-30-2012, 04:20 PM   #4802
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,418
As a builder are you familiar with the reflective type insulations like TEKFOIL?
I thinking of using this type between my ceiling rafters and the roofing and wonder if there needs to be a air gap between the roof decking and the foil?
Thanks.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is online now   Reply With Quote
Old 07-30-2012, 05:05 PM   #4803
Gerg
Cupcake
Gerg's Avatar
Oddometer: 8,368
I'm not a builder nor do I play one on TV but they make plywood sheeting that has foil bonded to one side now. In California if you build with it and insulate you have yourself a "Green Roof" and get a tax credit for it (I did not use it but I did insulate to R38 in the ceiling and installed an attic fan).
Gerg
Greg
Certified Ole Fart
Gerg is offline   Reply With Quote
Old 07-31-2012, 07:19 AM   #4804
ducnut
Oddometer: 3,317
Thanks.
You have to have airflow, underneath your roof sheeting, to allow for moisture removal and cooling effect. I've seen frost, on the bottom-side of sheeting, in the winter. Not having that airflow, will void some shingle warranties, depending on the company and their inspector.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 07-31-2012, 04:32 PM   #4805
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
I am not a builder either, but have used Tekfoil both in my garage and in an addition to my house (under a slab, as well).
You staple it to the bottom of the rafters, not to the top near the roof decking, so there's plenty of space.
It's easy to install and works great, keeping the heat in in the winter and out in the summer. I wouldn't build anything without it.
HapHazard is offline   Reply With Quote
Old 07-31-2012, 04:57 PM   #4806
plateau
plateau's Avatar
Oddometer: 72
Haphazard,
did you use the Tekfoil with traditional fiberglass insulation in the walls and ceilings?
plateau is offline   Reply With Quote
Old 07-31-2012, 05:41 PM   #4807
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
In the garage, no. I just stapled it over the empty wall cavities and the bottom of the trusses. Very quick, works great and REALLY brightens up the interior.
In my addition, yes. The only thing to be aware of is that Tekfoil is a vapor barrier. If your fiberglass insulation has a vapor barrier (like Kraft paper) slash the paper with a knife so you don't have 2 vapor barriers and get trapped moisture.
Also, the foil/bubble wrap/bubble wrap/foil material I used is quite thick - if your are sheetrocking over it, use longer screws, and plenty of them.
Old 07-31-2012, 05:48 PM   #4808
richarddacat
abnormal character
Oddometer: 3,418
Mid-TN Tag Riders
Old 08-01-2012, 07:57 PM   #4809
Patrol
VALE 46!
Patrol's Avatar
Oddometer: 1,366
Epoxy question. Previous owner of my new pad did the garage floor with the Rustoleum epoxy kit from Home Depot. He must have done something incorrectly because it's basically turning to dust. All of the better quality products seem to want you to have pristine cement. The Rustoleum product, while not the best quality, says you can apply it over top of an existing Rustoleum floor. If I recoated it then sealed it with an atrocious amount of clear coat would this hold up or am I just creating a shit show?
Somewhere between One Love and Molon Labe
Patrol is offline   Reply With Quote
Old 08-01-2012, 08:36 PM   #4810
Tech23
Tech23's Avatar
Oddometer: 470
Do some research but when I had my ( brand new) homes garage floor epoxy coated in PA they etched the floor with a muriatic acid wash the night before the epoxy finish went on. This was on a new concrete floor. I had spilled some motor oil on it and I told them was concerned the epoxy may not adhere to the area of the oil spill so they first washed the floor with muriatic acid. Not the kind of stuff you want to have a mishap with...dangerous stuff. The floor looked good for the 12 years I lived there. Sounds like you have some stripping to do before etching the floor. You may only have to strip the loose stuff, but you gotta think the more you remove the better the floor will look and the longer it will last. Maybe rent a rotary floor scrubber with a big 3M scotch brite pad to remove all the old Rustoleum.
http://www.naturalhandyman.com/iip/infxtra/infmur.html
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 08-02-2012, 05:53 AM   #4811
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,009
From here: http://garagejournal.com/forum/forumdisplay.php?f=20
Pretty much you need a very well prepped floor for Epoxy to stick over the long haul. Most of the professionals (they allow vendors to post what they want there) say it is best left up to a pro to get lasting results. From lurking there for a while it has become obvious that even pro work is a bit hit and miss.
The prevailing trend has moved towards Porcelain Tile as the most durable, and DYI friendly, flooring system.
Jim
Old 08-02-2012, 08:54 AM   #4812
ducnut
Oddometer: 3,317
Nearly every finish failure I've seen is a result of poor prep. As another stated, the concrete must be etched with acid, even new concrete. I always spray the acid with a pump sprayer (use a respirator), keeping it wet. I pressure wash it off. Leaving it sit 3-4 days, with fans on it, will ensure it dries. If there's moisture in the concrete, your finish product will lift. In your case, you need to chemically strip it. Those Rustoleum kits are crap, so you gotta' get it off the concrete.
I've seen numerous epoxy kits, on the market. But, I've not seen a DIY kit that'll do what a professional can with industrial grade products. This is one area where "You get what you pay for." applies.
'96 Ducati 900SS
Old 08-02-2012, 07:58 PM   #4813
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,403
Can you clarify the "turning to dust" part? Could be an inadequate film build just wearing out, or UV affecting the top of an epoxy surface. Some epoxies are not UV resistant and will chalk when exposed to sunlight or reflected UV's. Will appear as a dusty surface but is actually an appearance issue and not a coating failure.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is offline   Reply With Quote
Old 08-05-2012, 06:34 PM   #4814
JimVonBaden
"Cool" Aid!
Oddometer: 53,009
A little update, sort of gargae related (you can see the side of it)!
After a month the grass has come a long way.
Still working on the grass closest to the pavers. I should have seeded it at the same time as the rest of the yard. I also added a fence and a gateway to grow a vine on that I made out of the crushed canopy. Maybe grapes.
Jim
Old 08-05-2012, 06:45 PM   #4815
lightfighter
where does this go?
Oddometer: 2,277
hey, i have that table!
i should put pavers under it.
lightfighter is offline   Reply With Quote
Times are GMT -7.   It's 03:07 AM.
