Old 03-13-2007, 05:39 PM   #1
Pro_Marinero OP
Carbon Sasquatch
Pro_Marinero's Avatar
Oddometer: 2,090
Sealing hard compressed air lines
I'm in the process of plumbing hard air lines in my garage/shop. Everything is plumbed and now I'm seeing bubbles while doing the soapy water test at a couple of fittings. Is there a way to seal this without taking everything apart... like Permatex Aviation sealant? I happen to have some and I know it's tough but I'm looking for a second opinion. Thanks.
Pro_Marinero is offline   Reply With Quote
Old 03-13-2007, 05:58 PM   #2
KTM640Dakar
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,089
Teflon tape.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 03-13-2007, 06:10 PM   #3
Lone Rider
Registered User
Oddometer: 25,130
Originally Posted by KTM640Dakar
Teflon tape.
I thought it was a requirement....
Better than dope....pipe dope, that is.
Lone Rider is offline   Reply With Quote
Old 03-13-2007, 06:59 PM   #4
Pro_Marinero OP
Carbon Sasquatch
Oddometer: 2,090
I forgot to say I have teflon at all the fittings. Still having issues. Any good ideas beyond teflon?
Old 03-13-2007, 07:11 PM   #5
Harrington
Harrington's Avatar
Oddometer: 376
What kind of piping are you talking about?
Harrington is offline   Reply With Quote
Old 03-13-2007, 07:28 PM   #6
Pro_Marinero OP
Carbon Sasquatch
Oddometer: 2,090
1/2" Galvanized
Old 03-13-2007, 07:34 PM   #7
comes naturally
renewed hope
comes naturally's Avatar
Oddometer: 1,894
Originally Posted by Pro_Marinero
1/2" Galvanized
That's what I used...did you tighten it with a pipe wrench?
comes naturally is offline   Reply With Quote
Old 03-13-2007, 07:34 PM   #8
normsworld
Oddometer: 65
I work with gas pipe for a living , sounds like its steel threaded pipe .I use teflon pipe dope , the taper in threads SEAL the joint and the dope is more or less a lubricant, possibly compressing in a gap . Unless you wanna weld it , take it apart ,check the threads and tighten it good this time . I've seen copper type M , PEX and heard of cpvc used for 100 psi air . I'm gonna use pex when I do mine .Love the shit it is not Quest at all !
normsworld is offline   Reply With Quote
Old 03-13-2007, 07:36 PM   #9
comes naturally
renewed hope
Oddometer: 1,894
How much is leaking?
Old 03-13-2007, 07:36 PM   #10
normsworld
Oddometer: 65
Just saw it's galvinized , don't weld it!
Old 03-13-2007, 07:48 PM   #11
Harrington
Harrington's Avatar
Oddometer: 376
1/2" Galvanized
I'm a plumber. You shouldn't be having air leaks if the threads are good and you are making them up correctly. A good rule for threaded pipe is the 3 turn rule. You should be able to make up a threaded joint 3 full turns by hand before a wrench is needed. You can make an improper thread seal but it's harder, especially with over 100psi air.
Here's how I make up threaded joints. Start with good clean threads. I then put on a full swabs of teflon pipe dope. I then put on a few laps of telflon tape. It's important to put the tape on clockwise when you are looking at the end of the pipe. I then put more teflon dope over the tape. I use this method when I do most natural gas piping.
With that being said, I'd rather install copper air piping. It's faster to install and it works just the same.
DON'T USE PVC PIPING FOR AIR LINES---IT WILL EXPLODE UNDER PRESSURE IF HIT HARD ENOUGH---
Old 03-13-2007, 07:51 PM   #12
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,754
You should be able to run threaded pipe into fittings halfway by hand, I've used teflon tape and rectorseal both on some stubborn stuff, tape first, then the pipe dope. On air lines if the threads are cut right, usually just rectorseal.
Loctite also makes hydraulic sealant I've used successfully after others had tried, it's not coming apart without heat.
As far as compressed air, If I can't hear it, it's not a leak, unofficially.
katbeanz is offline   Reply With Quote
Old 03-13-2007, 07:51 PM   #13
Pro_Marinero OP
Carbon Sasquatch
Oddometer: 2,090
I followed the clockwise rule and thought I wrenched them on pretty good. Obviously not.
Old 03-13-2007, 08:37 PM   #14
hardybaker
Oddometer: 338
You did use tapered couplings didn't you? Somewhere, I have run across straight couplings that have caused me problems.
hardybaker is offline   Reply With Quote
Old 03-13-2007, 11:36 PM   #15
Pro_Marinero OP
Carbon Sasquatch
Oddometer: 2,090
Went back and did it right. Rectorseal and teflon tape all the way around and tightened 'er down good. I love doing a job twice.
Times are GMT -7.   It's 05:58 PM.
