Old 03-18-2007, 04:54 PM   #1
mnagher OP
04 R1150 GSA
Oddometer: 70
Satellite Radio Signal Strength
Does anyone know why the signal strength on my satellite radio would be less on my bike then in the car even when they are right next to each other? The signal is always weaker on the bike.
mnagher is offline   Reply With Quote
Old 03-18-2007, 05:17 PM   #2
gelandestrasse
Fidem Scit
gelandestrasse's Avatar
Oddometer: 20,237
If you are using an automotive antenna you are missing the ground plane provided by the sheet metal of the car body. You will get better results on the bike by using a home window sill style antenna like this:
They are ok for outside mounting so weather resistance isn't a problem.
I have Sirius. XM probably has the same style antenna.
"The trouble with quotes on the Internet is that you can never know if they are genuine."
- Abraham Lincoln
gelandestrasse is offline   Reply With Quote
Old 03-18-2007, 05:40 PM   #3
mnagher OP
04 R1150 GSA
Oddometer: 70
Thanks, I will give a try.
Times are GMT -7.   It's 01:10 AM.
