Old 03-20-2007, 09:06 PM   #1
space OP
a.k.a. Jake
space's Avatar
Oddometer: 2,630
Balancing tires -- tools needed?
So I'm setting out to put new tires on my 1150GS and DRZ400S. My guiding principle is minimal tools. First off, I'm short on cash right now. But more importantly, I want to know how to change my tires while on the road. (OK, not literally on the road. That would be stupid. But you know what I mean.)
After looking into balancing, I found plenty of pages like this one:
http://www.largiader.com/balancer/
Looks great and probably makes the job really easy. But why not just PUT THE TIRES BACK ON THE BIKE AND SPIN 'EM?? Seems like the common-sense approach, and no money or extra tools are required. I'm just wary that I must be missing something. Please enlighten a tire changing noob.
space is offline   Reply With Quote
Old 03-20-2007, 09:25 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,955
The main reason you can't do it on the bike is drag.
The wheel bearings and dust caps/bearing covers create enough drag on the axle that you would not get anything near accurate for balance.
On the other hand, balancing a wheel on a dirt bike isn't critacal, and some feel the same way about street bikes as well.
If you are on the road changing a tire, you can skip the balance and just fix the tire. Doubtful you will notice untill you are at speed on the road. And even then it wont be dangerous or dramatically affect handling.
Jim
Old 03-21-2007, 05:05 AM   #3
swjohnsey
Oddometer: 3,568
I disagree. It has been my experience that if you take the caliper off (which I usually do anyway) the wheel bearings are adequate to balance the wheel/tire. I'm not sure about the BMW set-up with the rear wheel. You can probably do it with the wheel on the bike. I usually support the wheel on the axle between a couple of chairs/milk crates/cement blocks.
swjohnsey is offline   Reply With Quote
Old 03-21-2007, 08:02 AM   #4
kerhonky
Adventure Poser
Oddometer: 1,158
The one and only time I've changed a motorcycle tire myself, I balanced it using the axle, but not on the bike. I supported both ends on speaker cabinets. I have had no issues with balance of that tire, even up to highway speeds.
If you're in doubt as to whether there's too much drag using the axle, I would suggest adding a little weight (maybe a 0.25 oz weight) to the rim before you change the tire, and see if it's enough to make the tire spin on the axle. In other words, support both ends of the axle, and turn the tire until the added weight is at the 3:00 or 9:00 position, and let go. If the minimal weight is enough to make the tire spin until the weight is at the 6:00 position (or better yet, enough to make it go past 6:00 and then swing back, like a pendulum), the drag on the axle is probably not enough to affect your balancing.
All this comes with the caveat that you'd be taking the advice of someone who:
a) is not a motorcycle mechanic;
b) has minimal experience balancing tires; and
c) does not go over 75 miles on his motorcycle, so balance issues might not show up.
FWIW.
You learn something new every day if you're not careful.
"When you have to shoot, shoot, don't talk."
Tuco Benedicto Pacifico Juan Maria Ramirez, otherwise known as "The Rat."
kerhonky is offline   Reply With Quote
Old 03-21-2007, 08:15 AM   #5
Papa Dulce
Old Enough to Know Better
Oddometer: 190
The Marc Parnes product set up on simple auto jack stands has worked well for many a tire arond here. Take your time and sip a beer while you spin the wheel. Successfully used on maybe close to 50 tires between several rider buddies. Make sure the jack stands are level.
Papa
Trust Me
'01 R1150GS The Big Bitch
'03 XR650R El Gallo Rojo
'71 R75/5 Old Gentleman
'03 Tiger (Mama Dulce's)
'99 DR 350 (Mama's too)
Papa Dulce is offline   Reply With Quote
Old 03-21-2007, 03:44 PM   #6
space OP
a.k.a. Jake
space's Avatar
Oddometer: 2,630
Thanks for the advice. I'll try it on the bike, and if that doesn't work maybe I'll invest in one of the Mark Parnes balancers. Look good, and I like a multi-bike tool. (That way I can have my friends give me beer in return for balancing their tires. Everyone wins.)
Old 03-21-2007, 04:00 PM   #7
pecos
BAM!!
pecos's Avatar
Oddometer: 549
I use a manual balancer. Is it accurate? Yeah, I think so. Of course nuematic ones are the best.
I place the weight in the what I think is the right spot. When mounting the tire I try to offset the heavy part of the tire. You know the red or yellow spot. There is a science to it but I do not fret over it.
pecos is offline   Reply With Quote
Old 03-21-2007, 05:29 PM   #8
Lurch II
Lurch II's Avatar
Oddometer: 615
Papa
+1
I, too, have the Marc Parnes product. Trick little balancer. I spin the tires between two chairs in the kitchen, never had an issue. Have done both my bike and MrsL's F650GS, front and rear, no problem.
Shawn
2007 R1200GSA - Lurch II (his)
2007 R1200GS - Wickd (hers)
"Dying is a very dull, dreary affair. And my advice to you is to have nothing whatever to do with it." - W. Somerset Maugham
Lurch II is offline   Reply With Quote
Old 03-21-2007, 07:14 PM   #9
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,472
Originally Posted by sbryan
+1
+1 here too. Works just fine.
SR1 is offline   Reply With Quote
Old 03-21-2007, 08:21 PM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 53,955
Just an FYI, at both VIR and Summit Point last year both Michelin and Dunlop tire sales were using the Nomar tire machine and balancer. Both manual types. Powered spin balancers are complete overkill for even racing bikes according to them.
I like either Marc Parnes or Beamer Balancer for tire balancing. I still don't think, for true accuracy, just using the axle and wheel bearings are sufficient.
Jim
Old 03-21-2007, 08:53 PM   #11
murgatroid42
Great Adventurer
Oddometer: 4,185
Put the axle through the wheel, put it on a pair of jackstands, and spin it slowly until it rests on the heaviest part. Stick the weights on the opposite side and repeat. Yes, the wheel bearings have drag, but you can estimate the heavy part by nudging the wheel, then observing the rate at which it slows down. Maybe not good for 100+ mph, but it worked for my DRZ and my former XR650L. Some people never balance dirt bike wheels so this approximation is far better than most.
"We hang around people who think these activities are normal."
"Me and gravity, we are really, really good friends." - Streetbike Tommy, Nitro Circus
"I'm a dude in his mid-40s, who acts likes he's in his 20's. But I don't plan on stopping any time soon." - Ken Block
murgatroid42 is offline   Reply With Quote
Old 03-27-2007, 10:22 PM   #12
Hooliganrick
Adventure seeker
Oddometer: 86
What kind of weights do you guys use, and where can they be purchased. I've tried every auto store in my area for the strips, but no luck
rick
"It's not about speed.....it's the ride and scenery"
DL1000 V-Strom
XR650L
Hooliganrick is offline   Reply With Quote
Old 03-27-2007, 11:55 PM   #13
bmwktmbill
Traveler
Oddometer: 5,218
+1 for Von Baden. No need for balance. If you balance anything balance the wheel without the tire on an Adventure bike.
Keep it under 90, enjoy yourself.
Bill.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 03-28-2007, 02:44 AM   #14
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,232
I'd add the rimlock to that. They're heavy. Someone else posted ages ago that they added 2.5oz to the front and 4oz to the rear on a drz, exactly opposite the rimlocks. That looks about the same as I added to my XR. I don't know exactly, because I made my own weights. I don't reccomend doing that. What a PITA.
Luke is offline   Reply With Quote
Old 03-28-2007, 05:41 AM   #15
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
balance the rim + rimlocks, then MARK THOSE WEIGHTS and don't take them off.
then it is fairly quick to balance the tire, or throw balance media in there.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Times are GMT -7.   It's 02:23 AM.
