Old 03-21-2007, 10:12 AM   #1
davidpetersen OP
BestRest Adventurer
davidpetersen's Avatar
Oddometer: 772
Send a message via AIM to davidpetersen
BestRest's New TireIron BeadBrakR
Update Dec 25 '09. We've compiled some of the various postings we've made about the BestRest TireIron BeadBrakR. Scroll down to the 4th page to see what we've written elsewhere. There's also links to the various threads.
Also.... we're putting together a step-by-step slide show on how to dismount and remount your tires in the field, with nothing more than a BeadBrakR. It's a work in progress, constantly being refined. Click this link for those photos:
http://bestrest.smugmug.com/Motorcyc...14228772_VSrhZ
Update 11-22-08 - Please check the page 3 of this thread for information on a product improvement.
We just released our newest project, the TireIron BeadBrakR (TIBB). You can find it here:
http://www.bestrestproducts.com/c-98-beadbrakr.aspx
We've tried most of the portable bead breaking devices on the market and found that they produced limited results. Some were impractical, some just plain failed. We pounded one plastic wedge with a hammer but it still wouldn't work. Most were too big or too heavy to carry on the bike and belonged in the garage. We looked at steel C-clamps, cast iron pincers, modified vicegrips, etc, etc, but nothing did what we wanted. A device from Oz looked promising but wasn't up to the task and bent when tightened.
Of course there's the old trick of using your buddy's sidestand or centerstand, if he's around. Or if you're riding solo you might be able to use your own stand, if you can manhandle the bike on one wheel, with one hand, while you break the bead with the other hand. We can't. That's why we wanted an independent breaker tool. And we didn't want to bend our sidestand, a common problem with the lighter components on the R12GS.
We knew that if we found a device that would break the bead, we also had to carry a full set of tire irons to finish the tire repair. Hmmm, double the weight, double the size, etc.
So we asked ourselves, "Why not combine all the bead breaking components into one unit? Why not make the tire irons an integral part of the bead breaking device itself? Why not make a compact, collapsible, purpose-built device that’s designed for the solo adventure rider?" So we went to the drawing board and made a better mouse trap. The design had to be small, lightweight, sturdy, multi-functional, and it had to be something you could easily carry on your bike. It took almost 2 years before we came up with the answer…
The BestRest TireIron BeadBrakR is a levering device that incorporates a trio of tire irons into the mechanical design of the breaker. When the bead is free you disassemble the device and use those same tire irons to remove the tire from the rim. What could be more simple, more efficient, more utilitarian?
Photo at left shows the device fully assembled, line drawing at right shows the cross section of the tire (hub to the left). The BeadBrakR is stainless steel, compact, lightweight, and easy to assemble using quick release pins, the entire kit fits in your hand and rolls up nicely in the Cordura storage pouch.
We've tested and proven the BeadBrakR on a variety of tires and rims, including the R1150GS and R12GS. KTM's double-locking rim design makes bead breaking a bit more difficult, especially if you're running Metzler Karoos, or another stiff sidewall tire, but it's still do-able.
Overall size of the BeadBrakR is less than 2” thick x 5.5” wide x 12” long. (We left plenty of room in the pouch for your own tire patches and plugs.) Total weight is 49 ounces (3.1 pounds). Remember that this includes three tire irons and a number of other accessories. Weight of the actual device is only 20 ounces.
The BeadBrakR kit contains the following items:
3 - Tire Irons (8.5” long) gold zinc plated
1 - BeadBrakR assembly (Corner, Lever, Plunger, Lock Bar)
2 - Plywood rim blocks to protect your rim from scratches
1 - Plywood sand foot for working on soft surfaces
2 - Plastic rim protectors for use during tire mounting / demounting
1 - Bottle BeadGoop tire mounting lube to make tire removal easier
1 - Valve stem multi-tool that tightens or removes cores & inserts new stems
1 - Laminated instructions with bead breaking and tire mounting tips
Price is $150 with steel tire irons. No, it's not cheap, but we made it like all our other BestRest gear - the highest quality components, designed for years of service.
Update - The TireIron BeadBrakR is also available with a trio of Aerostich Titanium Tire Irons in lieu of the heavier steel tire irons. Price is $245. These titanium irons are the same ones manufactured and sold by Aero. Aero also sells our BeadBrakR. Same price too.
PS. Of course the BestRest TireIron BeadBrakR design is Patented.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
davidpetersen screwed with this post 12-25-2009 at 07:27 AM
davidpetersen is offline   Reply With Quote
Old 03-21-2007, 10:17 AM   #2
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,988
Wow! Sweet design.
Old 03-21-2007, 01:04 PM   #3
Bounce
Bounce's Avatar
Oddometer: 1,484
Will it work on tubbed rims other than KTMs? I'm thinking specifically about my GF's f650gs.
the other Skip
r1200gs
If you won't stand behind our troops, please stand in front of them
Bounce is offline   Reply With Quote
Old 03-21-2007, 02:40 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,497
Sweet looking tool! It should work well for off roaders, especially with tube type tires.
One question, do the tire irons mate together for leverage removing and installing tires?
Jim
Old 03-21-2007, 03:38 PM   #5
davidpetersen OP
BestRest Adventurer
Oddometer: 772
Yup, it'll work perfectly fine for tubed tires. Breaking a bead on the F650 is a slam dunk piece o'cake in comparision to the R12GS.
The tire irons are 8.5" long. No, they don't link together to get more leverage.
We've always used these 8.5" irons to mount and demount tires on the R12GS, and although longer irons might make tire mounting or demounting a bit easier, we've found we really don't need a longer iron. It' more about proper technique than brute force. (Kinda like good riding skills can make up for a lack of horsepower and displacement)
We've included some pretty good tire mounting tips which make the mounting process easy(er). Admittedly, tire mounting's never really "easy", but with a few tricks it can be surprisingly painless.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
Old 03-21-2007, 04:06 PM   #6
TymeRider
TymeRider's Avatar
Oddometer: 320
What's the material? Steel?
When's the titanium version coming out?
(I'm in love with the Aerostich (RiderWearHouse) titanium 9.25" irons.
Any chance those can work with your unit by drilling the two holes in them in the right spot?
2007 BMW G650X Challenge
2005 KTM 950S Adventure
2002 BMW R1150GS Adventure
TymeRider is offline   Reply With Quote
Old 03-21-2007, 04:17 PM   #7
davidpetersen OP
BestRest Adventurer
Oddometer: 772
Update - Aero Design and BestRest have partnered to offer you the best of both worlds. Now you can get the TireIron BeadBrakR with Aero's titanium irons.
Materials for the main BeadBrakR components are 303 and 17-7 stainless alloy. The tire irons are mild steel, gold zinc plated. If you bend them during the tire mounting process, you're doing something wrong.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
davidpetersen screwed with this post 11-23-2008 at 05:15 AM
Old 03-21-2007, 05:24 PM   #8
LongWays
Skiing up a hill...
Location: City of Subdued Excitement.... no really it is!
Oddometer: 4,981
Hey David - you ever get around to doing a demo Saturday? Had a good look at South Sound's vendor fair and all I can say is
85 per cent of the children killed by guns in the world are American.
http://americansforresponsiblesolutions.org/
If you don't like my sig line - don't read it.
LongWays is offline   Reply With Quote
Old 03-21-2007, 05:59 PM   #9
davidpetersen OP
BestRest Adventurer
Oddometer: 772
Yup, we demo'd at noon, and several times thereafter.
I suppose I shoulda done the dog-and-pony-show every 30 minutes after opening, but hindsight's 20-20.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
Old 03-21-2007, 06:19 PM   #10
Bentley
Wannabe Adventurer
Bentley's Avatar
Oddometer: 234
Funny how I thought a $100 for a pump was silly, but I will very likely pay $150 for a set of tire irons and a bead breaker.
Very nice work!
Cheers,
Ben
Bentley is offline   Reply With Quote
Old 03-21-2007, 09:04 PM   #11
kildala2000
The GS Store.
kildala2000's Avatar
Oddometer: 2,013
Send a message via Skype™ to kildala2000
Thumb Well done.
Hey David,
That sure looks great.. You will sell a ton of those I'm sure.
Rick
kildala2000 is online now   Reply With Quote
Old 03-22-2007, 05:58 AM   #12
GB
Mod Squad
GB's Avatar
Oddometer: 53,462
Looks great!! Finally a complete kit! Maybe you can post a demo video on your website?
Old 03-22-2007, 06:17 AM   #13
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 25,810
Hmmm.
Lobby is offline   Reply With Quote
Old 03-22-2007, 06:31 AM   #14
davidpetersen OP
BestRest Adventurer
Oddometer: 772
We're interviewing swimsuit models for the BeadBrakR video now. Unfortunately the only people who responded to the newspaper ad were short, fat, balding men.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
Old 03-22-2007, 06:38 AM   #15
GB
Mod Squad
GB's Avatar
Oddometer: 53,462
Track down Naomi from the GS's that suck fame thread!! You'll sell a lot more of those kits if she's demo'ing it!
Times are GMT -7.   It's 08:42 AM.
