Old 03-27-2007, 04:56 PM   #1
SFmax
Guest
Oddometer: n/a
640 adventure fork seals changed by noob?
Here is the scenario.
Just put about 1500 miles on my newish 03 adventure that I just bought. Unfortunately the leftside fork seal is shot. I was wondering if replacing the fork seals could qualify as a saturday job. Or if its more like a Saturday/Sunday job? It would be in my friends garage who I'd have to bribe with a case of beer.
In simplified form:
Is this a two man job or can my buddy drink while I work?
Is this doable for a first timer on a Saturday?
Would I be crazy to try and change the oil as well?
Am I better of paying the guy at Scuderia to do it?
(the reason I ask is I will be going out of town and can't afford to have the thing laying in pieces in my friends garage all weekend.)
Old 03-27-2007, 05:06 PM   #2
cedric
Oddometer: 218
There is no way to change the seals without changing the oil. Well I guess you could pour the old oil back in, but that kinda be like drinking your own piss!
It's not a really hard job to do, but I wouldn't recommend it unless you are already comfortable working on most other parts of your bike. It can certainly be done in one afternoon. Make sure you have a service manual to show you the steps needed. Read it carefully before you begin, and if you think you can handle it, go for it. You will need to buy/make/jerry rig a special seal driving tool to seat the seals in the tubes.
I need to do this on my YZ very soon. I've done this task about 5 times before, but I still need to be very careful while doing it.
As an alternative, you can pop off the dust seals, and work a thin film up underneath the oil seals and wiggle it all around. Often times this will remove some grit and keep your forks from leaking for a while.
Good luck!
cedric is offline   Reply With Quote
Old 03-27-2007, 05:27 PM   #3
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Go check out the LC4 Index Thread. Lots of stuff on forks there, including this:
http://www.advrider.com/forums/showthread.php?t=68442
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 03-27-2007, 05:32 PM   #4
cevquit
maphead
cevquit's Avatar
Oddometer: 637
If you dont have the tools you are much better off having someone who knows what they are doing do it.
On a side note, the front axle has a floating right side, that is that the axle slides freely through the right side while the left side threads to a stop to tighten. There is no "dead length" position for the right leg, it doesnt tighten against the hub or bearing spacer although the axle does tighten against the bearings.
When my buddy got his 03 sxc the first thing he did was get a set of motard wheels, after changing them a couple of times and a few rides he got a seal leak. Just a little weeping not much, it bugged him so he got them replaced by a qualified suspension shop. Rode it a few times, couple more wheel changes and ,voila, they seep again. takes it back to the shop that did them and they tell him "well KTM's are known for seepy seals". I've been involved with suspension enough to know that they shouldn't have gone bad that soon, maybe a bad seal,it happens.When he changed front tire the next time I noticed that when he loosend the pinch bolts on the right side the fork sprung out a few mm. Then it dawned on me the forks were compressed towards each other and not running parrallel, causing the fork seals to leak.
So, tighten the axle first then the left side pinch bolts, give the right fork leg a little jiggle to let it "seat" then tighten the right side pinch bolts.
Since we found the error in his method of mounting and corrected it, there has been no weepage from the seals in 6,000 miles.
So, if anyone has chronically seeping fork seals on there WP forks look closely at how you mount your front wheel.
I know there is a road up here somewhere
cevquit is offline   Reply With Quote
Old 03-27-2007, 05:38 PM   #5
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Nice tip maphead! Thanks
I went the seal saver, grease, neoprene boot route
Will check the axle for sure
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 03-27-2007, 07:10 PM   #6
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,232
Good luck!
+1 all around. The plastic under the seal worked for me, but not for the last person I reccomended it to.
If you had done it before, it would be a short afternoon job, but since you haven't I'd call it a long afternoon job.
In addition to the usual sockets, you will need a seal driver tool, this manual, a 24mm wrench or socket (A big adjustable works too) a low profile 22mm open end wrench and 2 quarts of 5wt fork oil. edit.... and a ruler and a piece of tubing+syringe or mityvac for setting the oil level.
The manual covers a complete tear-down and re-assembly. The bike manuals don't have this kind of detail. You won't be doing it all, but I'd recommend reading it beforehand so you know what you're getting into.
I'm not too far away, so let me know if you want help. I'll be riding this Sat. though.
Luke screwed with this post 03-27-2007 at 07:17 PM
Luke is offline   Reply With Quote
Old 03-27-2007, 08:53 PM   #7
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
lc4 forks is fun.... get a manual and follow wp instructions and you'll be fine.
be happy you didn't fuck up a tube like i did... that was some shitload of dickin around.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 03-27-2007, 10:15 PM   #8
bmwktmbill
Traveler
Oddometer: 5,218
Just did my seals.
The manual called for tools I did not have.
Use clear packaging tape around the end of the fork tubes to protect the seals when you slip them on the tubes.
Get the order right the first time and use your fingers to start them. Lube with fork oil. that helps.
For a seal driver I used a piece of radiator hose I slit long ways and slipped over the tube.
Tht worked great for pushing the seals into legs.
I used red grease between the dust seal and the fork seal.
Some swear it helps.
Back all adjusters to zero for reassembly.
Recent thread on that one.
On the axle problem I had that too and it caused me a leak. Pull the axle out and clean it with a scotchbrite pad or somesuch and get in the axle tunnel too on the fork leg. Clean clean clean.
Follow the owners manual for mounting the front wheel.
What a difference.
No stiction.
Bill.
Bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 03-27-2007 at 10:30 PM
bmwktmbill is offline   Reply With Quote
Old 03-27-2007, 10:21 PM   #9
Zerodog
Oddometer: 1,233
Before you worry about it too much do the film strip thing to try to clean the seal. Also put some heavy grease under the dust wiper. This usually fixes a seal unless it is totally shot.
Fory changing seals you will need a seal driver too. You can make one or buy one. Or you can get synergy seals. They come with a little plastic strip and you put them in with your fingers. They are more expensive but I guess that is the trade off of not buying a tool you will rarely use. Loosen your basevalves before you take the forks off. An o ring seals it so as long as you just loosen them you won't puke oil everywhere. Having your bike straped down a bit helps this. It keeps the cartride from spinning. Do the same for the final torque down them too.
Don't buy the MSR seal kit. You will be doing your fork seals again in a short while. Don't ask how I know.........
Zerodog is offline   Reply With Quote
Old 03-27-2007, 10:21 PM   #10
Zerodog
Oddometer: 1,233
Originally Posted by bmwktmbill
Just did seals on mine.
You can get them started into the tubes with your fingers. Lub em up per the manual and get the order and orientation right. Use clear packaging tape around the end of the fork tubes to protect the seals when you slip them on the tubes.
Bill
Good tip on the seal driver Bill.
Old 03-28-2007, 06:02 AM   #11
Surlyguy
Guest
Oddometer: n/a
You MADE a tube
I have an 18" brand new rear wheel, I'm going to send it to you to shrink to a 17"
Old 05-08-2010, 06:39 PM   #12
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 773
Alright guys, just pulled my left fork apart because it's leaking. The 4357 model. Noticed a nick in the fork leg which I cleaned up with 1200 grit W&D sandpaper. I have looked at the seal and there are indentations in the seal where it was sliding over the nickl so I have to get a new seal.
Now the big question is, which way does the seal go? i.e. which way is up, as I may have forgotten?
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is online now   Reply With Quote
Old 05-12-2010, 12:45 PM   #13
Zerodog
Oddometer: 1,233
The smoother side goes out. It is also the one with the writing on it. Grease the inside and outside of the seal when installing. Also use some plastic wrap from the kitchen or packing tape over the end of the fork tube when installing the seal. This will protect it from the end of the tube and more importantly the super sharp bushing groove.
Old 05-12-2010, 06:31 PM   #14
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
A nick in the fork tube can be filled with JB weld and lightly sanded level.... It will hold for a long time...
gunnerbuck is online now   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
