Old 03-27-2007, 11:03 PM   #1
TexBiker OP
TexBiker's Avatar
Oddometer: 815
Paint Stripper for Plastic Parts?
I have some plastic parts (R1100GS beak/rear fender) that I need to strip and repaint. I know some chemicals will melt/soften certain types of plastic and I'd like to avoid that particular issue. What chemical strippers are safe for use on these plastics?
Thanks for any info.
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself.
-Mark Twain
TexBiker is offline   Reply With Quote
Old 03-27-2007, 11:38 PM   #2
RiverRat280
RiverRat280's Avatar
Oddometer: 751
I wouldn't use chemicals, they can leach into the plastics and cause problems. If the paint on it now isn't lifting or any other problem there is no need to strip it just sand it for adhesion. I'm in auto body and you don't strip old paint unless there's a problem with it. If the paint is sticking good then its a good base to paint from and will be less chance of lifting then if you strip it to bare plastic.
If your going to seal it then base coat scuff the old paint down with 320grit or there abouts and if your going to spray base coat strait onto it sand it with 500grt, biggest thing is to sand any shiny paint till dull so the new paint has small scratches to adhere to.
"Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who niether enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat"
-Theodore Roosevelt
RiverRat280 is offline   Reply With Quote
Old 03-28-2007, 06:05 AM   #3
Spode
Malcontent
Spode's Avatar
Oddometer: 5,511
I agree with RiverRat280, don't remove the paint unless it's failing. Scuff the old paint up with 320 grit until it's dull. Then I like to shoot a coat of epoxy primer, mainly because it sticks like crazy to anything and gives a strong chemical bond with the following paint without further sanding needed. Then I either shoot base/clear or I might shoot some high build 2k primer if the surface needs sanding/leveling first.
Spode is offline   Reply With Quote
Old 03-28-2007, 08:44 AM   #4
TexBiker OP
TexBiker's Avatar
Oddometer: 815
I appreciate the advice, but this paint needs to come off. It's bubbled, flaking and peeling. No amount of sanding will work unless I wanted to wear out my elbow and sand it all down to the plastic. I'm trying to skip that step if possible.
-Mark Twain
Old 03-28-2007, 12:56 PM   #5
rruugger
formally rruugger
rruugger's Avatar
Oddometer: 1,280
Not a painter or body guy, but like you I'am going to try to be. If you have new factory decals with clear coat, is it o.k. to sand litely with out removing and spay?
rruugger is offline   Reply With Quote
Old 03-28-2007, 08:05 PM   #6
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,876
Walnut shell blasting. Seriously. The shells wont's hurt it as long as you move it around.
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 03-28-2007, 08:43 PM   #7
D.Kinsey
D.Kinsey's Avatar
Oddometer: 388
plastic stripper
They have a plastic/soft parts paint stripper...think automotive bumpers. Here is a product link.
http://www.kleanstripauto.com/autocatalog.pdf
D.Kinsey
Diavel Carbon
K1200LT
KTM300
Triumph Sprint ST1050
D.Kinsey is offline   Reply With Quote
Old 03-29-2007, 07:06 AM   #8
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 4,992
+1 ...Beat me to it. I have a can I was going to take a pic of
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Times are GMT -7.   It's 08:18 PM.
