Old 04-08-2007, 06:11 PM   #1
Stretch67 OP
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,306
Raising a Tiger Seat
Here's a little mod I did yesterday to raise the seat another inch and a quarter.
I made these out of 1/8-inch thick steel, 2 inches wide, 7 1/2 inches long. I didn't measure the holes, I just clamped them to the seat frame and traced the hole placement with a scribe.
Bolted to the seat frame (unpainted for clarity)
The frame on the seat
I cross-drilled the seat pins and installed cotter pins to keep the frame from slipping off the seat pins.
And on the bike. Yes, It's kind of... up there. But when you're 6'7" (a hair over two meters), the seat isn't the only funny-looking thing on a bike. They don't call me "Stretch" for nothin'.
I think some black foam glued to the bike's frame might do well to hide the open space that's visible under the seat.
And spacers under the front end of the pillion will help to reduce the 'step-down' effect from the front seat to the rear.
Stay tuned. Chapter 2 will be lowered footpegs
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 12-30-2008 at 10:24 PM
Stretch67 is offline   Reply With Quote
Old 04-10-2007, 12:26 PM   #2
Northwoods Yeti
Almost house broken
Northwoods Yeti's Avatar
Oddometer: 2,672
Talking that's the bomb
Stretch you took an idea that's been floating around in my grey matter for some time and did it. It looks super simple. I'm 6'9" and even with a gel pad added to the seat my 00' tiger gets a tad cramped over the long haul. The only draw back that I can see is sticking that grey matter higher in the air stream (plus nobody else can ride it, oh waite that's a plus). Have you noticed an incease in buffeting?
Northwoods Yeti is offline   Reply With Quote
Old 04-10-2007, 03:49 PM   #3
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,306
No, but I'm running a sport fairing (practically none). My skull was in the clean air beforehand.
It is. It took me longer to go to Lowe's and buy the steel than it did to make them.
Also, I ordered a pair of Buell Ulysses footpegs this afternoon. Installed, they're an inch lower than the Tiger pegs, so that will free up a little legroom as well.
They're not a drop-in installation like on V-Stroms, but it won't take much. I'll post pics.
IBA # 33113
Alaska
XR400 Index
Old 04-10-2007, 03:54 PM   #4
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,427
Nice work there Stretch. I'm 5'11, so raising the saddle has never occured to me
The Uly pegs though...i'll be waiting to check that out
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 04-10-2007, 04:02 PM   #5
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,306
Heh. I found the bike here on the 'Flea Market'. Jamboa is 5'8" or so, and had the seat all the way down. I don't think he could do much with it like this.
Have I told you I love my Tiger?
IBA # 33113
Alaska
XR400 Index
Old 04-10-2007, 04:20 PM   #6
Northwoods Yeti
Almost house broken
Oddometer: 2,672
I bought a touring screen to replace the standard. I got the buffeting on the chest and shoulders with stock and now with the taller screen what do you know it's right in the face. A Laminar lip should fix it.
Aren't you worried about the lose of ground clearence ? I'm no Mat Miladin by any stretch of the imagination but I do touch down from time to time. If the pegs were an inch. lower I'd be grinding all the time.
Old 04-10-2007, 04:23 PM   #7
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,306
Thanks for the tip about the Laminar Lip. We're close enough to being the same size, that what works for one should work for the other. I have a touring screen (Jamboa threw it in with the bike), but I haven't put it on at all.
I had been riding a Honda Super Magna. Compared to it, the Tigger has a mile of clearance under the pegs. But I won't go lower than an inch. Also, the 'feelers' on my Tiger pegs are quite a bit longer than those of the Uly pegs, so the actual reduction in lean angle will be only slightly less.
I'm probably fifty pounds heavier than Jamboa, so I could probably crank up the preload and help with any potential peg dragging problems.
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 04-10-2007 at 06:50 PM
Old 04-10-2007, 04:28 PM   #8
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,427
Thanks for the tip about the Laminar Lip. I have a touring screen (Jamboa threw it in with the bike), but I haven't put it on at all.
The Gustaffson? I've never seen one of those.
Old 04-10-2007, 04:36 PM   #9
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,306
Yeah, it is a Gustafsson.
I don't have a standard Tiger shield to compare it to, but total height is 18 inches, width is 19 inches. No tint.
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 04-10-2007 at 04:42 PM
Old 04-10-2007, 04:49 PM   #10
Idahosam
Set Adrift
Idahosam's Avatar
Oddometer: 4,126
At 5'8 I'd like to drop down another 20mm or so.
My Ride South of the Border
Riding Nevada's Pony Express Trail May 2013
To travel is to discover that everyone is wrong about other countries.
Aldous Huxley
Idahosam is offline   Reply With Quote
Old 04-10-2007, 05:01 PM   #11
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,427
Look for an 02-04 swingarm.
Old 04-13-2007, 07:10 PM   #12
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,306
Here you iz...
Clicky
IBA # 33113
Alaska
XR400 Index
Times are GMT -7.   It's 06:57 PM.
