Old 04-15-2007, 08:05 PM   #1
OlyRider OP
Oddometer: 1,293
Plumbers solder vs. Electrical solder..Does it Matter?
OK, so I screwed up and used plumber's solder to join two wires. Actually, I didn't know there *were* two kinds! Does it matter? Will I have to redo this?
Paul
OlyRider is offline   Reply With Quote
Old 04-15-2007, 08:11 PM   #2
Cauldron
Now in DESMODROMIC!
Cauldron's Avatar
Oddometer: 2,939
The plumbers union does not get along with the electrical union. Use the right stuff or Vinnie and Guido will visit you.
And now your wires will leak...
and sorry about the D-con sprinkles on your strawberry shortcake.
Cauldron is offline   Reply With Quote
Old 04-15-2007, 08:19 PM   #3
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,785
Yes, it matters. Solders contain a chemical to clean the surface of the metals being joined. Plumbing solder uses an acid (it's also know as acid core solder). The acid will corrode electrical wiring, so electrical solder uses a milder chemical. Electrical solder is also called rosin core solder because the chemical used to be pine rosin. I don't think they actually use rosin any longer, but the name is still around.
You probably do not have to redo the connection, but I would spray something on it which will wash away the acid. Electrical contact cleaner will probably work.
RedUly is offline   Reply With Quote
Old 04-15-2007, 09:41 PM   #4
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Nance has it mostly right-
You DO have to redo the connection-- and I would actually clip the wires back an inch from the junction, on each side, as the acid core solder has wicked up into the wire. At some point, it WILL fail.
also-- use heatshrink to cover the connections-- it's infinitely superior to electrical tape.
(I solder to milspec, and have built cables for everything from radar systems to missile control systems. I have a bit of experience in this area ;) )
JAFO is online now   Reply With Quote
Old 04-16-2007, 07:10 AM   #5
torags
torags's Avatar
Oddometer: 2,469
what's your opinion of the paint on electric tape.
Rags
'02 BMW R1150R now
'04 BMW R1150RS/// Gone, but not forgotten
'07 HD XR 883R Sportster "Widow Maker"///Gone!
IBA #17225
torags is offline   Reply With Quote
Old 04-16-2007, 02:07 PM   #6
peterman
cop magnet
peterman's Avatar
Oddometer: 13,878
Nail polish works.
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 04-16-2007, 02:26 PM   #7
JAFO
JAFO's Avatar
Oddometer: 3,975
paint on electric tape has it's place-- and that is to put OVER regular plastic tape to provide a weather seal, particulalry with the lower grade tapes.
3M 33 is the only tape I'll use. It's expensive, but it works.
If you're trying to seal something that you need to work on again at some point in the future, do this:
put a layer of electrical tape on the item, sticky side OUT.
layer of rubber tape over that
layer of electrical tape, sticky side down, over the whole mess
paint it with the liquid stuff.
This is really good for RF cables on antennas. In fact, it's how the US Navy taught me to do it.
Old 04-16-2007, 02:29 PM   #8
the kaz
has become "FERAL"
the kaz's Avatar
Oddometer: 1,691
HOLY just about fell off my chair
Electrical tape and vehicles equals bad news but heat shrink is great. I have had some success with the brush on stuff when heat shrink wasn't practical but it is always a last resort for me ....
As far as the solder goes ??? what brand and model was it ???
I use both rosin core and silver here at work but always thought the only difference between rosin core plumbing solder and rosin core electrical solder was the alloy percetanges as well the diameter ... could be wrong
< spell cheqeur is bustimicated >
the kaz is offline   Reply With Quote
Old 04-16-2007, 02:37 PM   #9
DREW823
DREW823's Avatar
Oddometer: 320
Solder
As a Plumber for 30yrs....I have to agree with Jafo....
06 Concours 03KLR 650 02 VulcanClassic 81 KE 100
DREW823 is offline   Reply With Quote
Old 04-16-2007, 03:35 PM   #10
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 1,008
Since so much plumbing solder is solid and meant to be used with paste flux, I've got to wonder if the job was done without flux or if a paste was used instead of acid core.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 04-16-2007, 03:42 PM   #11
CBR900RR
CBR900RR's Avatar
Oddometer: 73
The best insulation (IMHO) is marine heat-shrink. It contains an adhesive that melts to form an excellent seal, as well as shrinking when heated.
CBR900RR is offline   Reply With Quote
Old 04-16-2007, 03:54 PM   #12
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
In the old days it was simpler. Electrical solder was 60:40 or 63:37 with rosin core and plumbing solder was 50:50 tin:lead and often had an acid core. It is even more complicated than it used to be because plumbing solder in the last 10 years or so contains no lead. Soon electrical solder will also be lead free and there are lots of possible replacement alloys. Also plumbing solder may or may not have an acid core. So the answer to his question is not simple, but the conservative answer would be to redo it because it might have been done with acid core solder.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 04-17-2007, 07:41 PM   #13
Kraftsman 73
Oddometer: 157
Looking for a source of the afore-mentioned marine heat-shrink. Also, being a soldering neebie, I am looking for a source of regular heat-shrink tubing. I have recently purchased a Weller 8400 soldering gun (for $23!!!), 60/40 rosin core solder 1/16" dia. and an assortment of heat-shrink. In my search for soldering supplies I was unable to locate any rosin flux . Found that to be rather odd. I trust the Gurus will point me in the right direction.
I have learned a few things from reading the various posts on this thread. Many thanks to all
Kraftsman 73
PS, just won an auction on E-Bay for a spare rear wheel for my KLR 650. I will now be able to switch between dedicated road wheels and dedicated off road wheels.
Kraftsman 73 is offline   Reply With Quote
Old 04-17-2007, 08:33 PM   #14
JAFO
JAFO's Avatar
Oddometer: 3,975
unless you're working on a nuclear submarine or something aerospace, I wouldn't sweat the flux issue. There's enough flux in the solder itself.
Not sure what type of iron the Weller you bought is-- but if it's not a pencil iron, get one. they're MUCH easier to use.
Google "how to solder" will tell you all you really need to know. Also, you want the high-grade non-PVC heatshrink. It stays flexible after shrunk, where the PVC type doesn't. The tubing with the adhesive in it is really overkill for anything not left in the weather/not carrying RF. Better to just give yourself about a 1/2" on each side of the joint, size the shrink properly to the wire, and shrink it down thoroughly. I suggest getting a cheap heat gun for the task, as well. Try your local model airplane store-- they use heatguns to shrink down the plastic film on aeromodeling projects.
Times are GMT -7.   It's 03:24 AM.
