Old 07-01-2013, 12:49 PM   #211
DirtBikeDaddy
DBD
DirtBikeDaddy's Avatar
Oddometer: 16
decomp?
what is that???
hahaha...made you look!
Yes, I did!
*waits for a mechanic
DirtBikeDaddy is offline   Reply With Quote
Old 07-01-2013, 09:55 PM   #212
bmwktmbill
Traveler
Oddometer: 5,178
Willit turn over with the kick starter?
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-02-2013, 02:27 PM   #213
DirtBikeDaddy
DBD
Oddometer: 16
Yep, spins the shift anyways.
Sounded Norman bit didn't keep kicking until she started or anything.
Sent from my Nexus 7 using Tapatalk 4 Beta
Old 07-04-2013, 02:45 AM   #214
DirtBikeDaddy
DBD
Oddometer: 16
So no mechanic ah?
Oh well!
Old 07-22-2014, 02:52 AM   #215
Reset1
640-24-7
Reset1's Avatar
Oddometer: 72
after all this, when reassembling, how much newtons should the engine case blots (4 outer M8 ones) be torqued?
'05 KTM 640 ADV
there is only one kind of adventure, the lc4 kind!!
Reset1 is offline   Reply With Quote
Old 08-05-2014, 07:19 PM   #216
F1paul
Oddometer: 46
I believe somewhere above was said the four M6 (8mm) should be torqued to 8nm
F1paul is offline   Reply With Quote
Old 08-05-2014, 11:58 PM   #217
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,598
Please! stop calling the bolts M8. They are M6. The number refers to the thread diameter in mm. NOT the bolt head size. I'd really hate for someone to skim-read this stuff and try to torque an M6 up to M8 values.
Most M6 are 10 Nm.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 08-23-2014, 09:53 AM   #218
F1paul
Oddometer: 46
So finally had the time to pull my flywheel off to inspect sprag clutch and it is definitely my problem... The spring is visibly stretched looks worse than loisus...
I was wondering tho if it would be OK to run the bike without the sprag installed back onto the flywheel as I'm still sourcing the oils seal for the spring...first one I bought was their skf#19993 interchange part but the spring was too thick ....I have on order an skf but have to wait a week and I'm jonesing to ride.
Haven't been able to ride cause kick start was turning starter motor and all and my quads are just not big enough ��
F1paul screwed with this post 08-23-2014 at 10:16 AM
Old 04-10-2015, 10:20 AM   #219
LoopGaroo
Oddometer: 210
I'm about to tackle this project on my '02 640Adv. I just wanted to confirm that that it's okay to use the bolt from the front of the engine to lock the crankshaft in place when removing the flywheel?
And, will I need any special tools besides the flywheel puller?
LoopGaroo is offline   Reply With Quote
Old 04-10-2015, 12:37 PM   #220
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,247
No, the 02 has the newer ignition with a high flywheel torque value. Using the locking bolt may damage the crank
gunnerbuck is offline   Reply With Quote
Old 04-13-2015, 08:04 PM   #221
LoopGaroo
Oddometer: 210
I can't get this 24mm nut off! This is reversed threaded right? I went at it with an air gun and it's not budging. I expected it to come right off... any advice?
Old 04-14-2015, 09:24 AM   #222
LoopGaroo
Oddometer: 210
I'm wondering if there might be some red locktite under the nut.
Old 04-14-2015, 12:05 PM   #223
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,247
Yes it is reverse thread.. You may need to try a different impact gun, not all are created equal...
If I have a tough time to crack something with my craftsman air impact I just switch over to my big electric powered impact tool and it usually has little trouble spinning it off..
Old 04-14-2015, 12:39 PM   #224
LoopGaroo
Oddometer: 210
Yeah. I tried my cordless impact and the pneumatic. Nadda. I think I might push the bike down to the tire shop a couple blocks away to see if they'll give it a "shot."
Old 04-14-2015, 01:55 PM   #225
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,486
Try a little heat then hit it with the impact again. 200 degC is enough to soften Loctite, a heat gun will do it.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Times are GMT -7.   It's 01:55 AM.
