Old 04-23-2007, 08:20 AM   #1
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
LC-4 shimming the Crankshaft
I'm in the process of installing a new crankshaft on my 03 Adventure and have a quick question on the crank shims. With the shims I have on hand I must use 2 - 0.3 mm shims + 1- 0.1 mm shim in order to get the correct play. I know that the shims on either side should be equal but does it matter that 1 side has 0.1 mm more shimming than the other? I would think not when you take into acount the conrod play as well as the play at the wrist pin.
gunnerbuck is offline   Reply With Quote
Old 04-23-2007, 06:20 PM   #2
halfcab
Oddometer: 681
The small end of the crank rod does not have to be 100% in the center of the wrist pin boss.
halfcab is offline   Reply With Quote
Old 04-23-2007, 06:43 PM   #3
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The crank will still find it's center, it just has less lateral travel to the thrust surface on one side vs. the other.
As long as you have your 0.03mm ~ 0.12mm total lateral play (and I'd be prone to lean toward the loose side of the spec) that 0.1mm shorter side shouldn't be an issue.
By the way, what is your total EP with the shims you have?
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 04-23-2007, 06:45 PM   #4
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
how are you taking your measurements ???
0.1 isnt that much of a diference, so id be really thourough about checking my numbers. make absolutly shure they are correct, and make sure you always use the loosest numbers, not the tightest or averages.
if i was you, id just use the 2- .3mm shims and call it good. i made the mistake of trying to add that extra shim when i rebuilt my engine and ended up making it too tight. everything was fine and the cranks turned smooth and easily till i torqued the case bolts, then it tightened up and wouldnt turn. then i was stuck trying to remove the cank bearings again to re-shim it. not the easiest thing in the world to do unless you have special tools.
i personally dont like the idea of having diff measurements on either side of the crank either, i dont think its a good idea. the manual is very specific about that.
good luck,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 04-24-2007, 10:25 PM   #5
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
Slapped her together and she's too tight, so I manufactured 2 pullers to get the bearing races back off. I used a borrowed digital caliper to take the original measurements which gave me .04 play, this time I'm going to use my own dial caliper to do the recheck. I'm thinking that even .6 may be too tight judging by how things looked when the cases went together. Probably turn out needing a .10 mm + .15 mm on each side for a total of .50 mm but I'm going to spend a long time measuring to make sure because getting those races back off is major ass pain. This time I'm going to use a small piece of rod to measure the bearing to case centre straightedge contact, I will cut the rod a slight bit long, file a bit off at a time and then mike it when the length is correct.
Old 04-25-2007, 01:25 AM   #6
jfn68
Oddometer: 620
Just a thought,im sure you know,you got the gasket between the case halves when you do your measurements?
jfn68 is offline   Reply With Quote
Old 04-25-2007, 05:41 AM   #7
halfcab
Oddometer: 681
Not to hijack this post....but is it easy to press the crank pin (main rod bearing) out of the LC4 crank shaft.
Old 04-25-2007, 07:32 AM   #8
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
I never bothered pressing out the crankpin as the price for a whole new assembly is only about $100 more and you get an updated crank {improved?}.
jfn 68- If I forgot to take the gasket in acount when measuring the play would be greater.
Old 04-25-2007, 08:18 PM   #9
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
Did the method of measurement I mentioned in the above post with the rods and it seemed to work pretty good. I was way over on the last measurement as the new measurement showed me needing a .15 mm shim on each side. On the plus side I have made the tools so if I ever need to play with the crank again it shouldn't be so difficult. I pulled the races off my old crank and the shimset was also .15 mm on both ends so I'm pretty confident that shes ready to go back together.
Thanks for the feedback and advice.....
David...
Old 04-25-2007, 08:36 PM   #10
halfcab
Oddometer: 681
I understand your thinking and would do the same...but what is updated and improved about the newer cranks.
I ask about pressing the crank pin out because I was thinking about balancing the crank if I ever had to pull the motor apart.
Old 04-26-2007, 07:30 AM   #11
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
The new crank is definetly different than the old. The old crank side plates were round as to where the new crank has cutouts on both sides. From the side it looks like a 2/3 moon with a spur jutting up in the middle where the crank pin attatches. The new crank could possibly be lighter and I should of weighed the difference but now it's in the engine and shimmed properly. I'm just assuming that this crank is improved. Why does KTM make changes? Usually they try to change things to improve the design. I have found one advantage so far with the new crank and thats with the cutouts you can fit a normal size dial caliper to measure crank width. Another could be that the cutouts may scavenge more oil off the housing floor and bring it up to give additional oil to the bearings.
I was lucky to have the original crank run pretty smooth but if you have a real shaker version I can see trying the balance idea.
gunnerbuck screwed with this post 04-30-2007 at 09:28 PM
Old 04-29-2007, 10:19 AM   #12
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
Well I fired her up for the first time this morning after yesterdays marathon reassembly session and a half second push on the button was all it took. I adjusted the idle and waited for the frame to overflow oil and then put the plug in. No funny sounds coming from the engine so I took it for a spin around the block and then checked for oil leaks. I noticed right off that the engine runs very smooth considering the new parts are not set in yet. This leaves me wondering if the new cranks are better balanced right from the factory or if I had the luck of the draw. I then went for a 40 KM ride and everything seems ok with the engine running quiet and no unusual sounds. I am running regular 10/40 M/C oil for the break-in period and then will switch back to synthetic after that. The shifting is still very good with the standard oil as I notice no difference. One thing that did happen in the time that the bike sat idle is the fork seals let go as I forgot to bleed the air from them when I parked it and when I did after I noticed the leakage there was quite a pressure build up in them. So new seals will be here Tuesday. Anyways so far so good.......
Old 04-29-2007, 11:13 PM   #13
halfcab
Oddometer: 681
Glade to hear it's up and running.
From what you said the difference in the two cranks were I thought it would be smother. I was surprised to here they had that much weight at the crank pin to start with.
Old 01-06-2008, 11:45 PM   #14
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,134
Badda-bump.
I'm finally getting my lazy, procrastinating butt in gear and putting my 97 Adventure back together. I'm now facing the crank bearing removal and came looking for advice.
Can anybody describe to me what this magical bearing-heating tool looks like? Is it just an oven-heated clamshell of aluminum or steel that you clamp around the bearing? It seems like it would be tough to deal with a 350-400F lump of metal while trying to bolt it to the crank.
I'm tempted to just grind a lip into the edge of the old bearing race and use that to clamp & pull it off. My worry is needing to go back and shim the new bearings afterward.
Help?
Donkey Hotey is offline   Reply With Quote
Old 01-07-2008, 07:43 AM   #15
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
I made 2 pullers {1 for each bearing race} out of 1-1/2" steel pipe. I cut 2- 8" sections that were threaded on one end and installed end caps with drilled centers so I could screw them to my slam puller. With the open end of the pipe I cut 6-8 lengthwise slots and installed an automotive muffler clamp over the pipe. For the one race this worked like a charm, heat the pipe and slip it over the cool race, tighten the clamp and a couple slide hits and off she comes. For the other race you must heat and expand the pipe to get it to fit and install a larger clamp as I think the race has about an 1/8" larger D.
I first tried to make a copy of the KTM puller and gave up after a couple tries. It looks like a chunk of flat steel with the correct D hole drilled to the edge with a cutoutslot to allow it to pinch the bearing. 2 handles allow you to slip it over the bearing and put twisting pressure to pinch the race and lift it off.
I will post a couple pics of my puller later today.....
Times are GMT -7.   It's 08:10 PM.
