Old 05-13-2013, 06:30 AM   #5656
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Well,,,it wasnt all wide open.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 05-13-2013, 09:39 AM   #5657
jrozar
jrozar's Avatar
Oddometer: 618
$200 Shipped US....complete front rim, hub and spokes
Originally Posted by jrozar View Post
Bump- $250 Shipped
jrozar
Las Vegas NV
www.my2wheels.com
jrozar screwed with this post 05-13-2013 at 09:53 AM
jrozar is offline   Reply With Quote
Old 05-13-2013, 04:59 PM   #5658
Gearhead001
Nut
Gearhead001's Avatar
Oddometer: 74
You have to mix the bad with the good and at least, it was not straight up a hill.
I plan to ride this Sunday so I will send you one back...
Gearhead001 is offline   Reply With Quote
Old 05-15-2013, 07:23 AM   #5659
yzu
yzu's Avatar
Oddometer: 27
Question
How can I adjust the correct tension of the chain, because it seems that, whatever I do, there is a difference between the lines of the chain tensioner/ adjustment ?
Some pictures of your rear axle would help me a lot.
Thank you !
Now.2010 BMW G 450 X
Gone.2 x Suzuki GSr 600 BMW F 650 CS Honda XR400R '99 Husqvarna 610 SM. '97 Yamaha XT.600E '08 Suzuki GSR 600. '98 Malaguti Fifty. '92 Husqvarna Cr250. '91 Mobra S50. '91 Izh Jupiter 5
yzu is offline   Reply With Quote
Old 05-15-2013, 09:37 AM   #5660
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,145
does not matter so much if the lines match up, so much as you look straight down the chain from the back, and adjust so the chain is straight.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 05-16-2013, 12:44 AM   #5661
yzu
yzu's Avatar
Oddometer: 27
Exactly that's my problem...the lines does not match, even if I look at the rear wheel that's looks straight.
Thank you for your answer.
Tomorow I will upload pictures with my rear axle adjustments.
Old 05-16-2013, 06:59 AM   #5662
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,145
Ignore the lines, i dont think the axle blocks are the same size, which would mess up a visual measurement. Just make sure the chain is straight, and neither the sprocket or spokes/rim are damaged :)
Goodluck!
Old 05-17-2013, 12:40 AM   #5663
yzu
yzu's Avatar
Oddometer: 27
I didn't think that : '' the axle blocks are the same size '' ...
From the pictures, it seems that the right block it is a little too open. Am I right ?
Old 05-17-2013, 12:44 AM   #5664
yzu
yzu's Avatar
Oddometer: 27
Let me ask you something else : what point do I have to consider to match with the lines? The head of the screw, the front/ end of the block...that's my problem.In the service manual it's not specified WHAT to align with the lines.
Thank you once again.
Old 05-17-2013, 01:15 AM   #5665
yzu
yzu's Avatar
Oddometer: 27
Wicked Pictures
And my toy ...
Old 05-17-2013, 05:25 AM   #5666
Gearhead001
Nut
Oddometer: 74
Using the center of the axle as the reference point, it is off.
Make sure the swing arm is located correctly. Make sure the swing arm bearings are OK.
Keep us posted.
Old 05-17-2013, 05:58 AM   #5667
jrozar
jrozar's Avatar
Oddometer: 618
Dropped price to $225 rim is true, less than 25 hours on the complete front if it isn't sold off the the metal bin to recycle. Great for a spare for a racer or just to have a front for when you taco your current rim.
Hub, rim spokes and all!
$225 Shipped US
I have a used front rim off of a G450X and it may fit the Husky line also.
The rim started getting a crack in the factory seam and BMW warrantied the crack with a NEW complete assembly so I had this one rewelded and kept as a spare. I no longer have the bike so its time for it to go.....
jrozar
Las Vegas NV
www.my2wheels.com
Old 05-17-2013, 06:10 AM   #5668
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,145
Its a good idea, and a decent price, but of course the weld makes me nervous.
Old 05-17-2013, 06:55 AM   #5669
GSMarc
GSMarc's Avatar
Oddometer: 1,006
Now that BMW has sold Husqvarna to KTM, I wonder if the new models will still use the CTS feature (coaxial traction system) seen on G450X & HQV TE 449 / 511
http://www.bennetts.co.uk/bikesocial...s-in-november/
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 05-17-2013, 08:17 AM   #5670
DESERT SCORPION
SINGLE TRACK
DESERT SCORPION's Avatar
Oddometer: 124
Axle Block Index Marks
"What point do I have to consider to match with the lines? The head of the screw, the front/ end of the block...that's my problem.In the service manual it's not specified WHAT to align with the lines."
The problem is BMW forgot to include index marks on the axle blocks. Based on the location of the marks on the swingarm, it looks like there should be an index mark on the axle blocks directly above the actual axle centerline. I added these marks to my axle blocks with a tri-corned file. Then I filled in the mark with red paint to spot them easily. See pic. I do believe that the blocks are the same size (easily checked when off the bike) so one could just measure the adjuster bolt exposed length as an alternative. Hope this helps.
THE SCORPION
DESERT SCORPION is offline   Reply With Quote
Times are GMT -7.   It's 01:07 AM.
