Old 04-25-2007, 11:00 PM   #1
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
XL600 Restoration - sorta
And so it begins...
Many of you may know me from my Honda XR600R rebuild this winter. What you may not know is, I purchased a nearly-identical XL600R around the same time, and have been slowly amassing an army of OEM parts from various sources, to turn the bike back into the sexy beast it once was.
This is what it looked like last fall, when I rescued it from the clutches of a stripper - a bike stripper...
'13 BMW R1200GSA 90th Anniversary, '03 Honda XR650R, '83 Honda XL600R Supermoto (Project)
XR600 rebuild http://www.advrider.com/forums/showthread.php?t=188797
XL600 rebuild http://www.advrider.com/forums/showthread.php?t=224984
ere109 screwed with this post 04-25-2007 at 11:33 PM
ere109 is offline   Reply With Quote
Old 04-25-2007, 11:04 PM   #2
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Incredibly, even with a missing fuel screw, and with the stock wiring harness gone, the guy had gotten the bike running. But I envision more of this little gem. I want it to have all that it was meant to have and more, like a speedo, and lights.
But there will be a few modifications. And this little darling is going to have a sleek black facade before this thread ends.
But now, to the story.
After some inquiries about sandblasting, our good friend BeemerPat offered to sneak me into his workplace for an afterhours session with the hose!
BeemerPat
Old 04-25-2007, 11:05 PM   #3
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Shamless plug
Old 04-25-2007, 11:06 PM   #4
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
This is my innocent little white frame, scarred by years of abuse and grease. Let's start the bath.
Old 04-25-2007, 11:11 PM   #5
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
The sandblaster made quick work of the frame. Pat checked. We were blasting at 900 psi!
Old 04-25-2007, 11:11 PM   #6
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
The next time we opened the door, the frame looked like this:
Old 04-25-2007, 11:12 PM   #7
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
But what's this? Pat!
Old 04-25-2007, 11:12 PM   #8
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
If you want anything done right, you've got to do it yourself.
Old 04-25-2007, 11:15 PM   #9
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Ok, I kid. BeemerPat is a great guy, and he did an amazing job. He even cleaned the excess sand off for me. Thanks again, Pat.
Old 04-25-2007, 11:19 PM   #10
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Now, back at the secret E-cave, I spent the next three hours building myself a temporary paint booth out of some 13' x 16' plastic sheeting. I've already installed hooks in the ceiling, and also spread newspaper over the floor to keep the rest of the cave clean, so my cavegirl doesn't find paint on her Jeep and kill me.
By the way, after my frame, if anyone needs a clean place to paint something, let me know. It won't be up for long, but it's here now.
Old 04-25-2007, 11:25 PM   #11
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Finally, this is the bulk of what I have so far. Most of it is Ebay winnings, although some generous folks have offered to kick in leftovers from their garages.
So far, I've purchased/replaced all of the following:
spare frame (seen above), speedo, speedo cable, speedo wheel gear, 2 turn signal switches, full set turn signals, horn, airbox, 2 regulators, rectifier, choke, toolbox, headlight, taillight, ignition.
Old 04-25-2007, 11:31 PM   #12
ere109 OP
Ride On!
ere109's Avatar
Oddometer: 2,951
Attention: I'm still missing a few genuine Honda parts. If seen, please contact me. A reward has been offered (by way of blessings in the afterlife.) I really could use some help with the following:
Plastic ignition cover (mounts below speedo, over key, says Honda),
Stock rear fender,
Stock front brake lever assembly - or just the front brake switch,
Lower headlight mounting bracket (attaches to lower triple tree),
Idle carb fuel screw,
and lots of assorted nuts and bolts to re-attach the departed.
If you've got anything to share, I'd appreciate a PM.
Old 04-26-2007, 07:44 AM   #13
BikerDave
Greybeard Rider
BikerDave's Avatar
Oddometer: 335
Not All Who Wander Are Lost....
KLR 'in along!!!!
BikerDave is offline   Reply With Quote
Old 04-26-2007, 07:47 AM   #14
smash81
smash81's Avatar
Oddometer: 463
oh boy here we go! ere on another quest to rescue yet another bike! lol good luck buddy.
smash81 is offline   Reply With Quote
Old 04-26-2007, 08:24 AM   #15
bitsnpieces
Oddometer: 7
Hey, I'm in the process of rebuilding a Xl600R as well (83), but certainly am not putting it back to stock. If you still need them, you can have the
ignition cover, brake switch and headlight brackets for shipping cost (I'm located in ME). Do you by any chance have an extra set of engine mounts? Shoot me a PM if you'd like those parts.
Good luck!
bitsnpieces is offline   Reply With Quote
Times are GMT -7.   It's 01:04 PM.
