Old 05-01-2007, 01:57 AM   #1
ozadvntr OP
Planning that trip, again
ozadvntr's Avatar
Oddometer: 1,175
UHF Radio Questions
After some information as to the best UHF to purchase.
What brand is preffered?
What wattage, 1W, 3W or 5W?
Are there handlebar mounts available for the radio itself?
reliability?
I saw the add in Trailzone from Days Motorcycles in Victoria and thought the deal looked pretty good, any advice would be appreciated.
Mick
ozadvntr is offline   Reply With Quote
Old 05-01-2007, 02:10 AM   #2
Major
Major Catastrophe
Oddometer: 793
I have a GME tx6200 5W - Melissa has a Uniden 2W.
I made a cradle and had it powdercoated. HAve the cradle mounted via a Ram mount. Melissa has hers in her rear bag.
reliability? Haven't had a problem with either radio.
We run ours through Autocom units permanently mounted and hardwired to bike. Pretty good range in thopen. Probably around 5km's.
Hope this helps.
Can post pics if needed.
Cheers,
Grant
__________________________________________
"I like enjoying my anality" - R1150Gfun -Yerranderrie 2007.
Live for today, because yesterday is gone and tomorrow may never come......
On my way to wherever a 2litre cask will take me.......
Major is offline   Reply With Quote
Old 05-01-2007, 02:32 AM   #3
Dirt Doctor
Geographicallyembarrassed
Dirt Doctor's Avatar
Oddometer: 1,135
Gman640 and I both run gme tx6200 with the ptt button attached to our camelbag chest strap and carry the radios in our camelbacks.
Both have the trailzone set up and they work well up to about 70km/h after that you know when somebody is speaking but not much else. good for warnings about oncoming cars, stock on the road etc etc
Found that if there are 2 many cables (such as the ptt and/or power cable) attached between you and the bike you will break one the first time you have a lay down.
ktmajor has a good set up.
range depends on the terrain 10-15k out west 1-2k in really hilly areas.
2014 KTM 300 EXC
2006 KTM 950 Super Enduro
2002 KTM 640 Adventure
2001 KTM 400 EXC Motard
1989 U1700 Unimog Doka-The ultimate support vehicle
Dirt Doctor is offline   Reply With Quote
Old 05-01-2007, 02:35 AM   #4
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
reliability?
Mate I wouldnt piss around with anything less than a 5watt. I take a
Uniden UH-052XR. Can be switched from 1 watt to 5 depending on your distance. Those 1 watt jobs are useless if you are in thick trees. I do believe that Days motorcycles is doing great deals on 5watt units with PPT setups.
Cheers
Craig
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 05-01-2007, 02:44 AM   #5
Dale950
Dale950's Avatar
Oddometer: 986
I finally hooked my helmet/ mic set up I got from Day's Motorcycles ( 12 months ago ) , turns out they have a two pin plug , so it will only fit a UHF radio with a two pin setup , it did fit a Gme but didn't perform to it full potential . Phoned Day's , they said go for the 2 watt Uniden UHO44 , it turns out it's pretty much a discontinued model but managed to get my hands on one . The new model is not released till next month .
Havn't fully tested it yet as it's for a trip leaving this weekend .
Cheers
Dale950 is offline   Reply With Quote
Old 05-01-2007, 02:46 AM   #6
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,505
I have a Uniden UH075 which is water resistant and also an Autocom system..
Don`t know how they work cause I`m too bloody lazy to get off my ass and hook them up..
The only down side to the Uniden is that the battery only lasts for 12 hours between recharges.. As far as I know there is no power supply that can be hooked direct to this unit.. It can sit in it`s own recharge cradle but that would be no good for traveling..
nevgriff64 is offline   Reply With Quote
Old 05-01-2007, 02:49 AM   #7
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Yeah the 52XR has the same battery set up, but it does have a DC plug outlet. However Im having trouble finding one for it.
Old 05-01-2007, 02:52 AM   #8
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,505
I bought all the UHF stuff off ebay Hunsta.. I can give you the store details if you want..
Old 05-01-2007, 02:55 AM   #9
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Fire away sir. What I been search for.
Cheers
Craig
Old 05-01-2007, 02:59 AM   #10
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,505
Cheers
Craig
This is the store that I dealt with and seem pretty good with posting and delivery.. Hope the link works..
http://myworld.ebay.com.au/uhf_gps_plusmore
Old 05-01-2007, 03:22 AM   #11
Autostream
Autostream's Avatar
Oddometer: 5,833
I'm running the GME TX6200 - chosen because it has a bullet proof chassis, 5w, great battery life.
Running through my Starcom system which incorporates the PTT button as well as letting me plug in GPS, Phone and Ipod... can get a bit busy in my helmet at times...
I leave the radio and Starcom unit in the Glovebox on the 950.
I have the radio connected to an in car kit with a medium gain aerial mounted on the rear of the bike. The incar kit connects the aerial as well as trickle charges the battery via the aerial socket. I have cut up the original housing that is also a Mic bracket so it is about 60x20x30mm
I use a medium gain aerial as the higher gain you use the less the angle of transmission which can limit range on hilly terrain.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 05-01-2007, 03:25 AM   #12
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Yeah link worked. Didnt see anything for mine, but fired off an email to them to see if they can source the stuff(with part numbers) I want.
Thx Nev
Cheers
Craig
Old 05-01-2007, 03:28 AM   #13
Andrew2
Team 250
Andrew2's Avatar
Oddometer: 5,290
Hve Days M/C got a web site?
Andrew2 is offline   Reply With Quote
Old 05-01-2007, 03:30 AM   #14
Autostream
Autostream's Avatar
Oddometer: 5,833
Not shown in Trailzone offer so I doubt it.
Old 05-01-2007, 03:31 AM   #15
Andrew2
Team 250
Andrew2's Avatar
Oddometer: 5,290
Thanks mate.By the way did you get your packet from me Ben?
Times are GMT -7.   It's 05:39 AM.
