Old 09-29-2008, 09:26 AM   #1531
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,304
TKC: Tubed or Tubeless?
Need some quick but quite urgent advice: I am trails riding at the w/e, and a set of TKCs are due to be fitted tomorrow as I had trouble getting hold of D606s (I'd previously had TKC on an xtz750, and liked them).
However, a friend advises me that the TKC (tubeless?) is a bad idea as the DRZ rims are not airtight.
So, um, I have no idea what to do..
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 09-29-2008, 09:30 AM   #1532
slide
A nation in despair
Oddometer: 21,122
I suppose you can run tubes in the tubeless tires if you can't get tires made for tubes by trip time.
slide is offline   Reply With Quote
Old 09-29-2008, 09:36 AM   #1533
ekaphoto
ekaphoto's Avatar
Oddometer: 765
Umm put tubes in your tire
If it's worth doing, it's worth over doing.
ekaphoto is offline   Reply With Quote
Old 09-29-2008, 09:56 AM   #1534
MOTARDJUNKIE
MOTARDJUNKIE's Avatar
Oddometer: 163
Originally Posted by 06wrx
Standard forks(S and E model) work well if the bike is an 03 or newer. I'm stuck with the crappy 2001 forks. :(
Originally Posted by dr zook
I guess youre refering to the upside down forks on the motard (DRZ400SM) models. Standard E's and S's come with the standard forks, up to 03 the E had better forks(more adjustable) than the S, now they are the same fork. Horses for courses , the sm upside down forks are valved for more of an onroad/motard bias, but do work well off road by report. The standard forks work well everywhere althogh if your a big bloke you may need heavier weight oil and or respringing.
Thanks to both of you. I too have the stock 2001 forks. They will work for now but as my skill level increases I should look at upgrading these? Who has done an RM swap?
Originally Posted by Oscar
Adventure begins when your plan goes to shit.
MOTARDJUNKIE is offline   Reply With Quote
Old 09-29-2008, 10:44 AM   #1535
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,304
It's that simple? I am such a goober
Thanks guys.
IBA #40578
Old 09-29-2008, 03:20 PM   #1536
Chilipepper
Baja wannabe
Chilipepper's Avatar
Oddometer: 831
Thanks guys.
Sometimes you might need to fill it up with air that has fatter molecules so it doesn't leak out the spoke holes but yeah that's all there is to it.
The SM's come stock with tubless tires they just install tubes and use them.
Yes, this is my camera. No I won't shoot your freakin' wedding.
Chilipepper is offline   Reply With Quote
Old 09-29-2008, 09:31 PM   #1537
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Thanks guys.
Yep, that simple. Don't feel bad though. I was given a lightly used TKC80 front once and wondered if would work with a tube. I knew that spoke rims had to have tubes so I stuck a tube in it and it was fine.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 09-30-2008, 02:15 AM   #1538
byewayman
Oddometer: 10
Hi folks! been reading this great thread, heres my 2002 drz400e enduro.
Its pretty stock apart from tag bars, seat mod, disc guard,and carbon fibre exhaust guard.
byewayman is offline   Reply With Quote
Old 09-30-2008, 02:34 AM   #1539
MOTARDJUNKIE
Oddometer: 163
What are the holes in the number plate for??
Old 09-30-2008, 06:43 AM   #1540
slide
A nation in despair
Oddometer: 21,122
It's the common Buick mod for the DRZ.
Old 09-30-2008, 07:28 AM   #1541
byewayman
Oddometer: 10
Modded airbox
Hi mj, i got the idea from a pro supamoto rider (stephan chambom) . they modify the air box.
A guy who worked for suzi gb told me that when a drz was on the dyno they could get more power out of it by lifting the seat up (lets in more air) apparently its a mod they do.
Old 09-30-2008, 07:29 AM   #1542
CATCH-22
Sublime ADVenturer
Oddometer: 1,294
CATCH-22 is offline   Reply With Quote
Old 09-30-2008, 09:47 AM   #1543
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,304
What's the seat mod? Lower/gel?
IBA #40578
Old 09-30-2008, 10:42 AM   #1544
byewayman
Oddometer: 10
seat mod
Hi ray, i m about 5" 8 so couldnt touch the ground without leaning to one side. Most people put lowering links on the rear suspension but that loses valuable clearance and changes the fork angle, so i took the cover off the seat, cut a couple of inches out of the seat foam and re stapeled the cover back on. works a treat.
Old 09-30-2008, 12:12 PM   #1545
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,304
Immobiliser
I have a Meta immobiliser on the DRZ (keyless fob), which the previous owner installed at it's one of the most commonly stolen bikes in the UK.
My question is, how much of a liability is this off-road. I've been told it might leave me stranded.
IBA #40578
Times are GMT -7.   It's 04:19 PM.
