Old 10-04-2012, 01:46 PM   #16006
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by focallength View Post
oh I will, I am most likely going to have to do a complete rebuild top and bottom end. Ill check everything along the way, oil pump, water pump, bearings, thermostat...
I would have noticed a leak that big, if the pump failed then oil would have still been in the engine. Some how it got burnt up...
Losing 2 quarts of oil surely had to result in excessive smoking while running or one big puddle somewhere.....Its not gonna disappear. Unless someone drained it for you without your knowledge. Is the oil catch can still in place?
bobbed06 is offline   Reply With Quote
Old 10-04-2012, 01:46 PM   #16007
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,045
Drained the frame too, right? Check to make sure the screen isn't clogged and preventing oil from draining back down to the case.
Starchamp is offline   Reply With Quote
Old 10-04-2012, 01:46 PM   #16008
WayneJ
LFC Nobody
WayneJ's Avatar
Oddometer: 5,963
So...went to drsin the oil and...there was none, I put 2 quarts in it a couple of days ago and some how the bike burned it all up...
Nobody else is stating the obvious, so I will.
There is no major oil leak from the engine.
There was no massive smoke cloud behind you while riding it, so the oil didn't some how get burned up.
Unless someone else drained the oil when you were not looking, you probably didn't put the 2qts of oil in it you think you did.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 10-04-2012, 01:53 PM   #16009
GPrairie_Rider
Dirt Junkie
Oddometer: 931
Originally Posted by See-Three View Post
Here it is for those that haven't seen it.
Uploaded with ImageShack.us
I gotta have me one!! Goin down to talk to the local Zuki dealer. Pre-Order mine!
Chris
Current Bike: 2013 Triumph Tiger 800XC
I deserve the best, anything less is unacceptable.
GPrairie_Rider is offline   Reply With Quote
Old 10-04-2012, 02:11 PM   #16010
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 509
Also check the screen in the crankcase.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Old 10-04-2012, 02:50 PM   #16011
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,033
Actually it was 1700 ml, not quite 2L every 9th oil change is free.
focallength is offline   Reply With Quote
Old 10-04-2012, 05:36 PM   #16012
JustGreg
Fast as Molasses
JustGreg's Avatar
Oddometer: 325
Does your sister possess the knowledge/ability to drain the oil out of your DRZ?
JustGreg is offline   Reply With Quote
Old 10-05-2012, 02:31 AM   #16013
Brakelate
Supermoto Adventurer
Brakelate's Avatar
Oddometer: 165
Eek You Can't Kill a DRZ, but it can Kill YOU!
While out playing with my GoPro's at Willow Springs Kart Track, I high sided and knocked myself unconscious.
Despite walking, talking and answering questions from medical aid, I have no recollection of the crash or anything from just prior to the event, until about half way to hospital.
*Warning; Not Graphic, but some may find the audio track entertaining, while others may find it disturbing as I apparently quit breathing for a while.
http://www.youtube.com/watch?v=JVk7u...LW4X4F6BXM5nSA
Current Ride: '09 DRZ 400SM
Brakelate is offline   Reply With Quote
Old 10-05-2012, 11:30 AM   #16014
Ryel
Ryel's Avatar
Oddometer: 246
Originally Posted by 955616846 View Post
In the workshop oil pressure is measured at the main oil gallery - check the workshop manual for its location.
that appears to be right off the oil pump, good information but I am also interested in what pressure is available to the cams.
Anyone know the size/threads for the galley and what sensor might fit?
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is offline   Reply With Quote
Old 10-05-2012, 05:04 PM   #16015
bobbed06
Oddometer: 1,236
The oil drain bolt directly under the oil filter housing is a test port for an oil pressure gauge. Remove that bolt and get a sending unit that fits in that galley, and you have a accurate oil pressure gauge sending unit.
Old 10-06-2012, 02:26 AM   #16016
Muddler
Muddler's Avatar
Oddometer: 779
Foot Pegs
My handlebars are CR bend fat bars, with a small rise in the adapters. I had to re-route the cables to get them to work, so I don't reckon I would be able to get much more rise. I'm 6'3" and still feel a bit too bent over when standing. Looking at the foot pegs, there is heaps of room to lower them without protruding below the bashplate. I reckon I could get 30-40mm easy, with the added benefit of lowering my overall CoG. Im thinking i would cut the pin from the peg and weld the pin higher with a vertical piece of flat steel. Anyone done this? Would it work or am I talking bollocks?
Muddler is offline   Reply With Quote
Old 10-06-2012, 02:30 AM   #16017
Muddler
Muddler's Avatar
Oddometer: 779
Seats
Anyone use the SDG HI seat? How would you rate it for comfort on longer rides? I notice on rocky mountain this complete seat is cheaper then a seat concepts replacement cover.
Old 10-06-2012, 05:40 AM   #16018
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,850
Check here http://www.wheelingcyclesupply.com/cgi-bin/public.cgi for footpegs. They have "high", "mid" and "low" sets that may work for you, .
I really love my Seat Concepts seat, allthough the "gripper" top is really grippy! I got the "add 1 inch" height as I too am 6' 3" and it's good addition.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is online now   Reply With Quote
Old 10-06-2012, 05:55 AM   #16019
Muddler
Muddler's Avatar
Oddometer: 779
Originally Posted by MotoBoss View Post
Check here http://www.wheelingcyclesupply.com/cgi-bin/public.cgi for footpegs. They have "high", "mid" and "low" sets that may work .
Thanks for the tip. They don't seem to list a low peg for the DRZ, though they do for the RMZ. I wonder if they are interchangeable
Old 10-06-2012, 05:55 AM   #16020
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,850
OK, I just bought a new (to me) 2011 DRZ400S. I'm putting several new farkles on it and have a question. Putting new handle bars on I am replacing the grips (obviously) and I can not get the throttle side grip off. I have cut, pulled and done almost everything necessary to remove a grip, but it won't budge. Both ends a hard and I can't even get a small blade between the grip and throttle tube on the bar end.
Is the throttle side grip permanently fused to the throttle tube from the factory?
Do I need to buy a new throttle tube just to replace the grip?
Thanks for the help..........................
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Times are GMT -7.   It's 04:54 PM.
