Old 09-22-2012, 03:05 AM   #16261
955616846
Oddometer: 1,690
Originally Posted by Mike_drz View Post
what kind of mount/protector is that on your drz side panel? I have a pair of saddle bags, can't find a cool enough hard point for tiedown near the exhaust pipe. do you also use that to tie down carryings?
Steg Pegz..
Gadgets bike has a different sub-frame if yours is an E
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is online now   Reply With Quote
Old 09-22-2012, 03:33 AM   #16262
Gadget678
Gadget678's Avatar
Oddometer: 777
Originally Posted by 955616846 View Post
Steg Pegz..
Numbers is onto it. When I had soft luggage, I did use them as anchors.
If you didn't know, this is what Steg Pegz do (lifted from their web site)
"Sep 22 2012
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is online now   Reply With Quote
Old 09-22-2012, 04:47 AM   #16263
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,255
My friend has a 2012 DRZ400 (purch Apr/12) with an hanging idle problem.. He's done a DJ jet kit and it ran fine after, Now, it won't idle down. He wants to take it to the dealer for warranty work, but because of the jet kit figures he's gonna have a problem. Is there a common problem that happens to these bikes that he should be aware of? Thanks.
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 09-22-2012, 04:48 AM   #16264
Mike_drz
Mike_drz's Avatar
Oddometer: 402
"Sep 22 2012
that seems like pretty stud built stuff, I just want to use it to tie luggage
Mike_drz is offline   Reply With Quote
Old 09-22-2012, 06:05 AM   #16265
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 433
[QUOTE=59DEN;19651577]
Originally Posted by The Recycled Teenager View Post
You are right no support truck with a cooler full of beer and thick steaks for the BBQ.
The bike set up was for doing the Canning Stock Route in Western Australia, which we completed in August this year.
I would imagine you would have trail rides in the Canada that would require an extended fuel range, maybe not water which is an issue in travelling in Australia.
After seeing the pictures of trails and tracks in this thread, I must admit to feeling a little jealous of the fantastic and varied terrain you have and Lord willing to be able to do some adventure riding in Canada and the USA.
Cheers
Dennis
Well I have to say I really enjoyed my short visit to OZ a few years ago(on my way to NZ for kitesurfing) and would like to visit for a longer trip sometime, its a wonderful piece of the planet.
So you would be very welcome to the great white north anytime but the 5 month of winter we have other FUN in.
In the meantime keep doing the unsupported rides its a great achievement
A good time to keep your mouth shut is when you’re in deep water!
DRZ400S
BMW R100/7
BMW1150GS
Yamaha TY 175 trials
KLR650sold
The Recycled Teenager is offline   Reply With Quote
Old 09-22-2012, 06:25 AM   #16266
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 102
There is nothing that I've heard of that is generic to these DRZ S or SM models that would cause this issue.
If it were my bike I would make sure the throttle cable is closing down all the way as soon as the twist grip is released. Lube the cable and throttle system. Check free play. Make sure the grip or handguard isn't interfering. If it doesn't work talk to the dealer mechanic or service manager about what you have modified to see if it's going to be a warranty stopper.
coarsegoldkid is offline   Reply With Quote
Old 09-22-2012, 06:29 AM   #16267
mrprez
KJ4WMZ
Oddometer: 1,263
Send a message via Skype™ to mrprez
Try turning down the idle as low as it will go and still run. This has worked for me in the past.
Sent via morse code
mrprez is offline   Reply With Quote
Old 09-22-2012, 06:37 AM   #16268
JoCo
JoCo's Avatar
Oddometer: 27
Make sure the choke isn't on.
2008 DRZ-400S
JoCo is offline   Reply With Quote
Old 09-22-2012, 11:14 AM   #16269
JustGreg
Fast as Molasses
JustGreg's Avatar
Oddometer: 324
My guesses would be , either the throttle cables arent properly adjusted or the carb wasnt reseated properly in the boots.
JustGreg is offline   Reply With Quote
Old 09-22-2012, 11:29 AM   #16270
markjenn
Oddometer: 9,698
Hanging idle is often an intake air leak. Sure the vacuum line to the petcock is kosher?
- Mark
Old 09-22-2012, 11:38 AM   #16271
the big c word
the badass noob
Oddometer: 8
Originally Posted by bobbed06 View Post
My Dizzer
what are the forks off of?
the big c word is offline   Reply With Quote
Old 09-22-2012, 12:46 PM   #16272
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,687
Send a message via Skype™ to blaster11
Gouge in fork tube/
So I recently picked up a DRZ400S and it had a leaking fork seal. Since it was leaking I figured I would freshen up the oil and spring it for me. Upon inspection of the tubes I found one with a gouge in it that the previous owner tried to clean up. I suspect that's where the leak is coming from...either from when the damage occurred or it tore up the replaced seal. The owner acted like he had never been in the forks so maybe he just tried to clean up the damage and never replaced the seal. Either way if I run it with the gouge should I just expect it to leak or is there any chance that it will be fine? If its going to leak most likely then I will just start looking for a replacement.
Anyone got a spare left fork lying around that's straight and useable?
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 09-22-2012, 05:23 PM   #16273
phoneman
Oddometer: 45
Got the new drz off in some dirt and woods today. First gear is definitely too tall for much riding woods trails.
What sprockets are yall using to slow this thing down ? I'm not too worried about losing speed on the top end--it seems to have way more than I'm likely to use very often.
phoneman is offline   Reply With Quote
Old 09-22-2012, 05:58 PM   #16274
TerraUnFirma
Fair/Not Balanced
TerraUnFirma's Avatar
Oddometer: 332
Phoneman,
For mostly dirt riding, whether I ride a few miles or trailer, I run a 13/48 sprocket set (3:69 ratio) vs the stock 15/44 (2.93 ratio). With that setup I can run 60mph on pavement fairly comfortably without the feeling I've got a grenade between my legs.
When I went to the 48 rear sprocket, I also bought a new chain, 116 links and had to take one or two links out of it to get proper adjustment range to be able to switch between 15/14/13 CS sprockets. The stock chain is a little short for the 48 rear sprocket. If you want to stay with the stock rear sprocket, you can find as low as a 12t CS sprocket, but those are very hard on your chain. Stick with the 13t CS sprocket and that will give you a 3:38 final ratio, which does help.
Lots of options out there and I've got an Excel spreadsheet that I'll be glad to share if you want to look at all the permutations of CS/Rear sprocket ratios.
Cheers
Tom Stites - Dawsonville, GA -
'11 Triumph Tiger 800XC ABS
'97 BMW R1100RT
'06 Suzuki DRz400s
'08 Yamaha WR250R
TerraUnFirma is offline   Reply With Quote
Old 09-22-2012, 05:59 PM   #16275
ifixfords
ifixfords's Avatar
Oddometer: 241
I like 14/47 combo (stock E setup), works quite well off road. It will still run a steady 70mph if necessary, although I don't make it a habit. Pulls 3rd gear wheelies nicely.
DRZ400E Tagged
KTM200XC-W
Why does trespassing have to be so much fun?
2001 DRZ400E - tagged
2008 KTM200XC-W
ifixfords is online now   Reply With Quote
Times are GMT -7.   It's 05:14 AM.
